It is currently Mar Fri 23, 2018 11:57 am
Post New Topic Post Reply  [ 1 post ]
 Post subject: Seeburg LPC-1R jukebox does not pick up records Have manual
PostPosted: Feb Sat 24, 2018 7:40 pm
Recently working, this Seeburg LPC-1R jukebox jammed motor carriage and finger on the V-8 selection - took out the record which was fine except for scratched now from being jammed in on the side of the delivery finger instead of in front - and found a piece of broken record that didn't match anything I had.
Presumably it fell in from somewhere else.
Took the back off (small 2x3 ft panel) removed it, turned it back on, motor and carriage was unjammed and resumed, carriage scanned for other records of which there were none selected and parked.
Flipped it around raised the lid, pressed a couple selections but the only thing it would do is stop at the first 10 selections A sides and B sides - skip some - do the same to 4 or 5 more and so on and so on down the stack - but no records would load.
The records come out of the stack by about an inch or so but don't load.
The lever on the right is in PLAY position, the little L shaped release arm under the tonearm is in the NORMAL position (pushed down) and I don't understand enough of the service manual it came with to go much further.
But it worked fine before it got jammed.
Post New Topic Post Reply  [ 1 post ]  Moderator: Alan Voorhees
