It is currently Dec Wed 12, 2018 10:50 pm
 Post subject: Magnavox Collaro changer
PostPosted: Mar Fri 02, 2018 1:51 am
This is part of a Magnavox radio / phonograph. Reading between the lines, the changer was made by Collaro for Magnavox. The changer looks like this one, but with a Magnavox badge:
https://www.radiomuseum.org/r/collaro_54.html
Note the lever at the front of the tonearm for switching between 78 and LP. (A fairly conventional approach)
What we have in the Magnavox version is this:
Instead of turning the cartridge withing the headshell, there is a "thumbwheel" that rocks the cartridge in line with the tonearm, bringing 2 different needles into play. The bottom view shows the two needles:
In this unit, the cartridge does not respond to the "scratch test". I've never seen on like this before and I don't know if is reluctance, ceramic, crystal, or.....
Anyone have any clues?
-Mark http://pixellany.com
 Post subject: Re: Magnavox Collaro changer
PostPosted: Mar Fri 02, 2018 2:13 am
Most Magnavox changers were made by Collaro. Magnavox eventually purchased the Collaro company.
The cartridge is most likely crystal and most probably dead!
-David
PostPosted: Mar Fri 02, 2018 2:27 am
Any ideas what cartridge we might use?
PostPosted: Mar Fri 02, 2018 4:58 pm
Those tilting cartridges (Philco had something similar) present a particular challenge because there is no modern cartridge anything like them. Most people would probably try to adapt a P228 or something like it. Gary at www.thevoiceofmusic.com would be a good resource.
-David
PostPosted: Mar Fri 02, 2018 5:05 pm
I am coming to the same conclusion......and, yes, Gary is my next stop. So far, he has solved 100% of my R/P issues.
PostPosted: Mar Sat 10, 2018 3:37 am
FWIW those plug in Collaro Head Shells are available with the more conventional mounting screw type arraignment which would make fitting it with a different cartridge a lot easier.
PostPosted: Mar Sat 10, 2018 11:35 am
Indeed....I have seen pictures of these. Do you know a source?
( I have discussed how to proceed with Gary at V-M, but this option did not come up.)
EDIT--- seeing some on EBay, but not have not yet confirmed what model(s) they fit.
PostPosted: Apr Mon 30, 2018 5:39 pm
I got a cartridge kit from VM.....that was the easy part. (As always, Gary was super helpful.)
I just finished the mechanical overhaul. I did a complete disassembly to make cleaning and lubrication easier.
DO YOU KNOW HOW MANY PARTS THIS THING HAS.???!!! Seems like 2x any other changer I have worked on.
Pretty routine except for a special screw that I had to make...and I have no parts left over...;)
I'll eventually post a few pictures....
Post New Topic Post Reply  [ 8 posts ]  Moderator: Alan Voorhees
Users browsing this forum: Google [Bot] and 3 guests
