It is currently May Sun 20, 2018 8:41 pm
 Post subject: Antennas for AM DX and SWL
PostPosted: Feb Thu 24, 2011 10:56 pm
I use 2 radios daily. My main receiver is the Eton E1 and then I also have a Panasonic RF-4800.
Living in an urban environment and with lots of electronics in the house, I have a severe interference problem that varies from day to day, it seems to depend on what my neighbors are doing as well.
I was going to treat myself to a magnetic loop antenna next month, when I turn 65. The antenna I am considering is the Shielded Active Broadband Magnetic "Moebius Loop" , model: RF PRO-1A made by Pixel Technologies,
My previous research had pointed me to a Welbrook, but recently I have seen excellent reviews on this Pixel loop.
Anyone have any experience with either antenna?
Frank
PostPosted: Feb Fri 25, 2011 12:26 am
Tough question....
What may work for me may not work for you. After doing all the research you can do when you have a choice, you may want to try both types.
That's the fun part, albeit the more expensive way, of antenna farming even if it's the indoor variety.
Then, you could build you own as well.
Good luck on the project and keep us posted.
"Resistance may be futile but capacitance has potential"
PostPosted: Feb Fri 25, 2011 3:32 am
The first thing to do is ID and tame all the noise sources in your house. Be prepared to spend some money on ferrite toroids and aluminum foil.
I question many of those "commercial" indoor antennas. Its so easy to scam an unknowing person with a fancy ad loaded with hi tech words and a fancy price. Hey for all that money it has to work....right.
PostPosted: Mar Tue 08, 2011 11:13 pm
Make sure you have a good solid uncorroded mains ground and rod.
Then invest in a eight dollar Radio Shack outlet tester. Check all outlets. One with a missing or poor ground can overload the whole house wiring with noise.
PostPosted: Mar Wed 09, 2011 3:02 am
I'm with Burnt Fingers on this one. If the noise is coming from within your house, then throwing dollars at a fancy antenna ain't going to do diddley.
Fid the source of the noises, then throw as much wire as you can out the window and attach a good earth to the radio. Even skinny transformer wire will do if you want it to be invisible.
Cost to performance ratio compared to a Wellbrook, Pixel or any fancy-shmancy? Infinite!:)
The US CB band is booming in here, and all I have is 60feet of wire! (Not that I want to listen to those blabbermouths, but the reception is interesting. Listened to T88ME this morning who is up in Palau - I couldn't make out the Japanese guy he was talking to though!)
Cheers - Martin ZL2MC
PostPosted: Mar Wed 09, 2011 6:02 pm
I appreciate all the replies, good information, but my question still remains, does anyone have any experience with high end magnetic loop antennas?
A lot of of my interference comes from my neighbors and I have no control over it. Not 100% sure what they are doing but I have my suspicions that it involves indoor hydroponic gardening.
frank
PostPosted: Mar Thu 10, 2011 6:37 pm
Ah, hydroponic gardening especially with high intensity lighting is a popular Vancouver pastime :lol:
A loop will only be able to reject interference from its null direction as it is ineffective in other directions. Its better than a random wire but dont expect miracles.....those only occur after you sample some of the neighbors product:wink:
PostPosted: Mar Thu 10, 2011 7:50 pm
And remember....
The antenna will have to be as high as it can get.... :wink:
PostPosted: Mar Thu 10, 2011 9:14 pm
I am on a 7200 square foot corner city lot with "side yard" setbacks of only 5 feet. So my shack is on the second floor on the neighbors side, his walls only 10 feet from mine. So you can see the problem, anything from plasma tv's, routers, dimmers, high intensity lights used for "recreational gardening" and associated amateur poor wiring practices, to fluorescent lights and all kinds of wall warts that can be used anytime of day, just 10 feet away from my radios. I have been using a "snake in the grass" with limited success as I can't get away from the interference. I guess its the price we pay for living in a tolerant society. :D
I know a magnetic loop is not a cure-all, but it has to be better than what I currently have by a wide margin. My CCrane Twin Coil Ferrite antenna does a great job on AM, but I really want to improve my SW reception.
Frank
PostPosted: Mar Fri 11, 2011 7:44 am
Understood, but even so, wire outside is going to pick up more signal than any amount of loops inside where the interference is.
Have you got a roof or a roof space under ceramic tiles? There's a good spot for your antenna.
PostPosted: Mar Sat 12, 2011 4:45 pm
As testimony to the fact that almost any outdoor AM antenna beats almost any indoor AM antenna, listen to any AM station on your car radio sometimes and compare the reception to an indoor AM radio. The outdoor antenna-based AM car radio will always beat the indoor AM radio in reception.
PostPosted: Mar Sun 13, 2011 12:25 am
Thats not a very good comparison. A good car radio has higher sensitivity to start with. Its benefit....with the engine off....is possibly being far enough away from house noise sources.
Take the cheap home radio outside and compare and unless you are in a steel cave the cheap home radio will still be inferior.
PostPosted: Apr Fri 01, 2011 8:33 pm
I ordered the Pixel Technologies Magnetic Loop RF PRO 1A today.
I will let you know how it works out for me. Initially I will try it indoors, but I intend to install it outdoors on a rotor as soon as we move in 3 months or so. That will give me a good comparison between indoor/outdoor use. The advantage of a magnetic loop of course, is that it only amplifies the magnetic wave portion of the radio signal. Should cut down a lot on my indoor interference problems I have currently.
Frank
PostPosted: Apr Sun 03, 2011 6:14 pm
I solved my interference problems by locating my outdoor antenna as far away from my house and neighbor's house as I could. It is a random wire up as high as I could get it. I used a homebrew 9:1 balun (actually unun) and a ground rod at the antenna as well as one at the house. I fed the whole mess with RG-6 CATV coax which is very low loss and has great shielding. Yes I know it is 75 ohm but the minor mis-match for a receiver is minimal. Signal levels are somewhat down from just a regular antenna but the s/n ratio is much higher. It all but eliminated my noise problems here and I did have noise levels from an S5 up to an S20 prior to this!
Bill
PostPosted: Apr Sun 03, 2011 9:13 pm
I don't remember you sneaking round to my house and copying my antenna......... :D :D
Post New Topic Post Reply  [ 15 posts ]  Moderator: Sandy
Users browsing this forum: Tom Herman and 6 guests
