Page 1 of 1
[ 14 posts ] |
| Author |
jrs
Post subject: Volume pot question Posted: Feb Thu 09, 2012 6:11 am |
| Member |
Joined: Sep Tue 28, 2010 4:13 am Posts: 732 Location: Hamilton, Ontario
I am just finishing up a Canadian Phonola and everything is recapped, out of spec resistors removed, aligned and thoroughly cleaned. The radio is working well but I still have low volume at zero volume level. At one point during the recap I know the volume control was fully functional. The pot has been cleaned, C34 has been replaced and R11 checks out alright. Any ideas?
_________________ John
Every expert was once a beginner
| Top |
glasdave
Post subject: Re: Volume pot question Posted: Feb Thu 09, 2012 8:57 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
When the control is all the way to the low position, do you still show some resistance? If so it may be normal
_________________ I move the world just one step on...
| Top |
radiotechnician
Post subject: Re: Volume pot question Posted: Feb Thu 09, 2012 10:38 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 4078 Location: Powell River BC
Did you change the bias cell ? It might be dried out and acting like a very small capacitor leaving the grid of the 6FS5 open and subject to crosstalk from adjacent wires to the top of the pot from the detector.
| Top |
Oldbear
Post subject: Re: Volume pot question Posted: Feb Thu 09, 2012 2:03 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3814 Location: St. Louis, MO, USA
I think Steve's on the right track; there's a high probability the trouble involves the bias cell. This link explains them and gives a method to try to rejuvenate them: http://www.philcorepairbench.com/biascell.htmThe circuit arrangement is a little unusual in that the bias cell is directly in the path of the audio signal. If the cell cannot be brought back to life or made to operate satisfactorily, the usual thing to do is to eliminate it with a circuit modification as shown below. This relies on the grid to develop it's own bias through it's "contact potential." There are other methods, but this one seems to be the most favored. Attachment:
_________________ Terry Davidson
| Top |
Alfred Corbin
Post subject: Re: Volume pot question Posted: Feb Thu 09, 2012 3:13 pm |
Joined: Jul Sat 01, 2006 11:17 pm Posts: 1120 Location: Northwest Florida (Panhandle)
I don't believe the bias cell can cause that problem. If the resistance from the volume pot reads essentially zero at minimum setting, there should be no signal leakage through the cell.
Since you have recapped it, and this is quite a high impdance circuit, subject to pickup, I wonder if you might be getting some accidental capacitive coupling in your wiring. With the volume turned to minimum, can you change the audio level by poking around the wires in the vicinity of the VC?
| Top |
Oldbear
Post subject: Re: Volume pot question Posted: Feb Thu 09, 2012 4:39 pm |
I think Steve's idea was that with a dead bias cell, there would be zero bias on the grid. Then the gain of the tube would be very high and overly susceptible to stray signal pickup through accidental coupling.
| Top |
jrs
Post subject: Re: Volume pot question Posted: Feb Thu 09, 2012 10:55 pm |
| Member |
I have never dealt with bias cells before so I am going to have to do some reading first.
Occam's razor...........I will meter out the pot first.
| Top |
jrs
Post subject: Re: Volume pot question Posted: Feb Sat 11, 2012 6:32 pm |
| Member |
I metered out the 2 Meg pot here today and I am getting about 22 ohms at zero volume level from the pot. I removed it, recleaned it and reinstalled it and yet I am still getting the same ohm readings and low audio when the volume is at the zero level.
Can I therefore eliminate the pot as the problem and proceed to looking at the bias cell? If I go with Terrys idea of bypassing the bias cell with a .01uf and a 5 Meg what wattage resistor should I use?
| Top |
jrs
Post subject: Re: Volume pot question Posted: Feb Sat 11, 2012 7:20 pm |
| Member |
Problem solved! You guys are pretty smart I removed the bias cell and modified the circuit as per Terrys diagram and the volume pot works perfectly now. I used a 4.7M 2W resistor; from what I have read that part of the circuit is lower volatge and current anyway s
| Top |
Oldbear
Post subject: Re: Volume pot question Posted: Feb Sun 12, 2012 12:48 am |
4.7 meg at 2 watts? Zounds, I'm surprised you had one like that! Current there is indeed very small. You could have used 1/2 watt, or even less. Sorry I didn't catch your post early enough to say so. At least you don't have to worry about it overheating now!
| Top |
jrs
Post subject: Re: Volume pot question Posted: Feb Sun 12, 2012 4:18 am |
| Member |
| Top |
Nelson in Winnipeg
Post subject: Re: Volume pot question Posted: Feb Sun 12, 2012 5:47 am |
Joined: Feb Fri 05, 2010 6:14 am Posts: 944 Location: Winnipeg, Canada
Zounds! Is that thing chromed? Nelson
_________________ "Never get between electricity and where it wants to go." -Red Green
| Top |
jrs
Post subject: Re: Volume pot question Posted: Feb Sun 12, 2012 7:03 am |
| Member |
To be quite honest, I don't know.
It was heavily oxidized before I cleaned it up so I would tend to think that it is just plated. The strange thing to me is, as you know, Canadian Phonola/Dominion/Electrohome are not considered to be high end sets so it makes me wonder why the manufacturer took the time/money to plate or chrome the thing????????
| Top |
Tube Radio
Post subject: Re: Volume pot question Posted: Feb Mon 13, 2012 4:32 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8040 Location: Warner Robins, GA
Some Eastwood's Chassis black satin paint would look great on that transformer. An example of how that paint looks on a transformer
| Top |
Users browsing this forum: Tung-Sol and 0 guests |
