| Author |
KDG
Post subject: AES AM Transmitter problems Posted: Feb Thu 23, 2012 4:57 am |
Joined: Dec Mon 29, 2008 7:20 pm Posts: 54 Location: California
Hi all, I built the AES am transmitter a few years back and I am noticing a problem with it. For mono songs it does fine, but on true stereo songs there is distortion. I am running my Ipod into it using a "Y" connector to go from the Ipod's earphone jack to 2 RCA connectors to one RCA into the transmitter. Any ideas? Also is there a way to reduce the noice that the Ipod's charger generates? Thanks!
| Top |
Johnnysan
Post subject: Re: AES AM Transmitter problems Posted: Feb Thu 23, 2012 5:49 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
I would use two 1k resistors instead of using a straight Y connector; that is, do not run the left and right channels together.
The only suggestion on the adaptor I can think of is try another one that is not switch mode (a transformer type adaptor).
| Top |
Tube Radio
Post subject: Re: AES AM Transmitter problems Posted: Feb Thu 23, 2012 6:25 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7878 Location: Warner Robins, GA
You can build a charger which is easily done by getting one of those car phone chargers that plug into the cigarette lighter socket with one or two USB ports on it then build a 12 volt 2 amp power supply. Add a panel mount cigarette lighter socket and you're all set. You can then use it as a noise free way to charge things like cellphones or other electronic devices that use a USB cable for charging purposes.
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Feb Thu 23, 2012 7:37 am |
| Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 943 Location: Texas. USA
KDG wrote: Hi all, I built the AES am transmitter a few years back and I am noticing a problem with it. For mono songs it does fine, but on true stereo songs there is distortion. I am running my Ipod into it using a "Y" connector to go from the Ipod's earphone jack to 2 RCA connectors to one RCA into the transmitter. Any ideas? Also is there a way to reduce the noice that the Ipod's charger generates? Thanks! A straight Y connector is a no-no because you have two active outputs tied together. When 'mono' they're doing the same thing, so it appears okay, but with stereo you have one trying to forcably drive the other in a different direction than it's trying to drive things. You need a resistive mixer (or other but a resistive is easiest) and. as someone else suggested, series 1k would probably work on a headphone output but 10k is more in keeping with tradition (line level).
| Top |
KDG
Post subject: Re: AES AM Transmitter problems Posted: Feb Thu 23, 2012 8:23 pm |
OK thanks for the help; I understand the issue. So if I am understanding right can I run 10K resistors from the center posts of the 2 RCA connectors to the common input of the transmitter? And I can just "tie" the shields of the RCA connectors together to the ground of the transmitter?
| Top |
Tube Radio
Post subject: Re: AES AM Transmitter problems Posted: Feb Thu 23, 2012 9:32 pm |
| Member |
You are absolutely correct.
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Feb Fri 24, 2012 12:03 am |
| Member |
KDG wrote: OK thanks for the help; I understand the issue. So if I am understanding right can I run 10K resistors from the center posts of the 2 RCA connectors to the common input of the transmitter? And I can just "tie" the shields of the RCA connectors together to the ground of the transmitter? Yep. Now, "just in case" I would also cap isolate the input since line outputs are not always perfectly ground referenced (I have a notebook that isn't, for example) but that's not terribly common so you might get away with a direct connection. My schematic of the AES transmitter shows a 100k grid leak so a .1uF 50V film after the 10ks would be fine.
| Top |
KDG
Post subject: Re: AES AM Transmitter problems Posted: Feb Fri 24, 2012 12:46 am |
Would that cap be in series between the ouput of the 10K resistors and the input of the transmitter?
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Feb Fri 24, 2012 1:34 am |
| Member |
KDG wrote: Would that cap be in series between the ouput of the 10K resistors and the input of the transmitter? Yep, you got it. Two 10ks and one .1uF cap.
| Top |
KDG
Post subject: Re: AES AM Transmitter problems Posted: Feb Fri 24, 2012 5:24 am |
| Top |
KDG
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 2:47 am |
Ok, So I built the resistive mixer and I still have the stereo distortion problem. There is no problem with the Ipod hooked up to my Kenwood amp or the headphones, just when I try to use the transmitter (problem with it?).
| Top |
Tube Radio
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 2:55 am |
| Member |
Maybe the signal level is too high when being fed by a stereo signal?
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 3:11 am |
| Member |
KDG wrote: Ok, So I built the resistive mixer and I still have the stereo distortion problem. There is no problem with the Ipod hooked up to my Kenwood amp or the headphones, just when I try to use the transmitter (problem with it?). Well, a resistor mixer is run of the mill bog simple and as Spock and McCoy explained about their tranquilizer grenade "nothing can go wrong." They said that just before it didn't work The first obvious thing is to make sure it really is wired right. Nowhere should the outputs be tied to each other. Each one goes only to its corresponding resistor. Are you over-driving the transmitter? Volume up too high? If neither of those 'fix' it try playing a stereo MP3 but with only one channel connected to the transmitter. Try left alone and then right alone. Do each, by themselves, sound ok?
| Top |
35Z5
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 3:45 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8652 Location: Chesapeake VA
I have doubts the "stereo" input would cause transmitter problems... I regularly connect a computer to experimental 6GY6 & 12CS6 Tx on the bench with a "Y" cable with no matching resistors at all, I've not had a issue... Possibly the problem is created within the I-pod when the channels are connected... If you have a scope, check the waveform at output of the I-pod when the channels are connected...
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 4:16 am |
| Member |
35Z5 wrote: I have doubts the "stereo" input would cause transmitter problems... I regularly connect a computer to experimental 6GY6 & 12CS6 Tx on the bench with a "Y" cable with no matching resistors at all, I've not had a issue... Possibly the problem is created within the I-pod when the channels are connected... If you have a scope, check the waveform at output of the I-pod when the channels are connected... It depends on the output and, for example, maybe yours inherently has a series resistance, or other means, for 'protection' or to cater to variable headphone impedances. However, it's intuitive that two active outputs should not be directly connected to each other because if one goes 'high' while the other goes 'low' then who wins?
| Top |
35Z5
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 4:22 am |
| Member |
Flipperhome wrote: It depends on the output and, for example, maybe yours inherently has a series resistance, or other means, for 'protection' or to cater to variable headphone impedances. However, it's intuitive that two active outputs should not be directly connected to each other because if one goes 'high' while the other goes 'low' then who wins? You are probably right, there was one 'puter here that didn't like the outputs connected together... Still I've done it countless times without issue... Tom
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 5:13 am |
| Member |
35Z5 wrote: You are probably right, there was one 'puter here that didn't like the outputs connected together... Still I've done it countless times without issue... The problem is there's no way to know, it being virtually impossible to get 'specs', much less schematics, for these things, so I can't give what the 'odds' are. But even if it doesn't blow an output that doesn't necessarily mean it works right either. But, back to his problem, he shouldn't have distortion with a mixer and the only time I've seen anything remotely resembling that was with Winamp playing something that had 'surround sound' content. For some reason it didn't seem to 'add' right and showed up as obscure background distortion (till I told Winamp to disallow 'surround sound') so I suppose it would be worth checking to see if he has some problematic 'equalizer' setting. In particular, any kind of '3d effects' or 'stereo enhancers' as those manipulate phase and could cause odd effects when added back together.
| Top |
Blustar1
Post subject: Re: AES AM Transmitter problems Posted: Mar Tue 06, 2012 8:10 pm |
Flipperhome wrote: "But, back to his problem, he shouldn't have distortion with a mixer and the only time I've seen anything remotely resembling that was with Winamp playing something that had 'surround sound' content".
He will need two separate channels outputed to the AES transmitter to start out with, and he will almost certainly need a mixer if he has any hopes of delivering AM stereo to his receiver. Virtually all of the ARF AM transmitter designs (including the AES AM transmitter) do not incorporate a stereo mixer.
| Top |
Flipperhome
Post subject: Re: AES AM Transmitter problems Posted: Mar Wed 07, 2012 12:04 am |
| Member |
Blustar1 wrote: He will need two separate channels outputed to the AES transmitter to start out with, and he will almost certainly need a mixer if he has any hopes of delivering AM stereo to his receiver. Virtually all of the ARF AM transmitter designs (including the AES AM transmitter) do not incorporate a stereo mixer. He's not doing "AM Stereo," he just Yd L and R into a mono transmitter and had distortion. So we told him how to make a resistive mixer, which he did, and he's still got distortion.
| Top |
Blustar1
Post subject: Re: AES AM Transmitter problems Posted: Mar Wed 07, 2012 1:15 am |
You're correct, but he might end up going through that route in any case.
| Top |
Users browsing this forum: Flipperhome and 2 guests |
