It is currently May Mon 20, 2013 8:39 am
 Post subject: Repair cracked rubber CRT mask ...
PostPosted: Feb Sun 12, 2012 2:54 pm
Any tips on how to repair cracked rubber CRT masks like the green ones that surround the CRT in Zenith porthole TVs?
 Post subject: Re: Repair cracked rubber CRT mask ...
PostPosted: Feb Mon 20, 2012 4:32 am
I would try rubber cement like the kind you would use on tire repair. And then paint it to the color you need it to be.
PostPosted: Feb Mon 20, 2012 3:59 pm
The green mask around Zenith tubes is plastic. Not rubber.
Bill Cahill
PostPosted: Feb Wed 22, 2012 12:39 am
Yea, I know it plastic. My porthole has a plastic one. Iv'e got a seeburg trashcan jukebox and the dome was cracked real bad on it. And the rubber cement worked great on it.
PostPosted: Feb Tue 28, 2012 1:31 pm
I wonder if using a fiberglass cloth repair like used on auto bodies would fix the mask?
I would think it would strengthen the mask. Certainly would require some sanding and painting.
PostPosted: Feb Wed 29, 2012 2:20 am
That could work too.
PostPosted: Feb Wed 29, 2012 2:27 am
I had a cracked mask on my DuMont. After gluing it back together I reinforced it on the back with some epoxy putty. But in my case the back of the mask did not sit against anything, so there was room for the blob of epoxy putty.
Post New Topic Post Reply  [ 7 posts ]  Moderators: Mr. Detrola, 7jp4-guy
