It is currently Jun Wed 19, 2013 11:32 pm
 Post subject: Screen foldover
PostPosted: Mar Tue 13, 2012 7:35 am
Well, my Phillips 27S310 CRT set has started to fold over at the top, and is at around 1 1/4". If I continue to run it, can I make it fail faster? Is it something I can fix? It has been in the shop twice, and is in good shape, other than this problem.
It will be 20 years old in September, so, if it is a hard to find i.c. or other part, I may just look for a newer CRT set. :(
Would appreciate any advice , thanks David.
 Post subject: Re: Screen foldover
PostPosted: Mar Tue 13, 2012 10:36 am
Anything could fail faster. It may be bad electrolytics in either the lv poser supply, and, or, vertical circuit.
Bill Cahill
PostPosted: Mar Tue 13, 2012 11:10 am
Thanks Bill. I'm going to pull the back and look for the usual suspects,may have to get a schematic, too.
PostPosted: Mar Tue 13, 2012 11:35 am
The B+ for the vertical circuit may come from the flyback transformer (scan derived), so the filter caps may be next to the flyback. Also, they used a rectifier in a pump up circuit that can get leaky; it will be next to the vertical output IC.
PostPosted: Mar Tue 13, 2012 7:17 pm
Thanks,Johnnysan!!!!It is a great help to know where to focus, going to crack the case tomorrow, after work. :)
PostPosted: Mar Fri 16, 2012 8:03 pm
Check your capacitors in the vertical output circuit / yoke circuit
I usually just jump them out one at a time to find out which one it is.
Make sure to discharge cap each time you go to jump out another.
bauerdental
Post New Topic Post Reply  [ 6 posts ]  Moderators: Mr. Detrola, 7jp4-guy
