| Author |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Tue 27, 2012 12:30 am |
Joined: Nov Thu 08, 2007 2:44 am Posts: 2177 Location: Worcester, Mass.
No AM Also. Henri...give me a call.
_________________ Lee
Worcester, Mass
| Top |
Eric H
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Tue 27, 2012 1:34 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5676 Location: Redlands CA
On my set I injected a signal and worked my way back to the tuner to figure out where it died, since I got something all the way back it figured it had to be the tuner.
Sometimes I just wiggle or pull the i.f. tubes one at a time and see where the static stops, I then figure the problem is between that tube and the last one that gave a response. May not be the most reliable method but it's fast.
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Tue 27, 2012 3:30 am |
Yeah, I wiggled away, to no avail... I notice all I get is a faint hum out of the loudspeaker, that varies when I raise and lower the volume. No static. Because I hear a hum out of the speaker cone, does that mean the audio output transformer is operational? Well, at least she's spankin' clean;    I think whatever is holding the set back is something trivial, IMHO.
Worcester, Mass
| Top |
philsoldradios
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Tue 27, 2012 3:40 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3707 Location: Woodinville, WA USA
Do you hear a buzz if you turn on your soldering iron and briefly touch it to the center terminal of the volume control?
| Top |
Kevin Kuehn
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Tue 27, 2012 3:44 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3126 Location: WI
Great time to break out the B&K TV Analyst.
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Tue 27, 2012 4:14 am |
Kevin Kuehn wrote: Great time to break out the B&K TV Analyst.  No, it's a great time to hit the sack. Found out something interesting. When you switch to TV on the Input Control, the display backlights go out, of course. But, when you push in the Tone Control Knob, the backlights come on.
Worcester, Mass
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Wed 28, 2012 12:32 am |
Worcester, Mass
| Top |
pielock373
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Thu 29, 2012 1:33 am |
| Member |
Joined: Feb Sun 28, 2010 4:48 pm Posts: 1127 Location: Massachusetts
Time to get the rf tracer and go stage by stage, see where you loose the signal. Best of luck.
Steve P
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Thu 29, 2012 4:02 am |
philsoldradios wrote: Do you hear a buzz if you turn on your soldering iron and briefly touch it to the center terminal of the volume control?
Phil Nelson Yup. A good buzz.
Worcester, Mass
| Top |
philsoldradios
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Thu 29, 2012 7:17 am |
| Member |
The buzz suggests that components downstream of that point -- output tube, transformer, speaker -- are working, so you can shift your focus upstream. The TV's sound section is not much different than an FM radio and you can use straightforward techniques to trace where an injected signal is not getting through. In the Archives section of this website is a downloadable copy of Elements of Radio Servicing, a popular text that describes such techniques: http://www.antiqueradios.com/archive.shtmlRegards, Phil Nelson
Last edited by philsoldradios on Mar Thu 29, 2012 11:47 pm, edited 1 time in total.
| Top |
DaveM
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Thu 29, 2012 8:32 pm |
Joined: Aug Thu 07, 2008 1:36 pm Posts: 2067 Location: Orlando
does the rastor have snow or is it just blank? if snow the osc tube working if just blank then suspect the osc tube.
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Thu 29, 2012 11:19 pm |
Blank raster. I'll check the Osc Tube after dinner. Thanks.
Worcester, Mass
| Top |
DaveM
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Fri 30, 2012 3:34 am |
I had a problem somewhat like that, wiggled the heck out of the osc tube eventually it started working. That was the crosley with the inductor tuner, I cant recall if I ended up with a new tube or what the deal was exactly.
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Fri 30, 2012 4:20 am |
DaveM wrote: does the rastor have snow or is it just blank? if snow the osc tube working if just blank then suspect the osc tube. By Osc Tube you mean thye 6J6 in the Tuner Section. I checked that. All the tubes in the Tuner are new.
Worcester, Mass
| Top |
DaveM
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Fri 30, 2012 4:13 pm |
I would start by checking the voltages at that tube. this is when a TV analyst is great as you can inject RF/IF/composite and narrow it down. If the radio is dead and I presume its a spit system, then you can narrow it down to before the pick off point which is prob pretty close to the tuner. If that is the case I would still focus on the osc, Try a lot of tube wiggling and voltage checking.
| Top |
Electronic Memory
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Fri 30, 2012 6:39 pm |
Joined: Nov Thu 11, 2010 6:03 pm Posts: 397 Location: Pewaukee, WI
I have a philco split chassis set that won't pass a signal if the OSC tube is in the wrong spot in it's socket. Whenever it dies I go and wiggle the osc to fix it. Some sets are finicky like that even after socket cleaning.
Tom C.
| Top |
Tom Schulz
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Fri 30, 2012 9:58 pm |
| Member |
Joined: Mar Sun 01, 2009 10:27 pm Posts: 2915 Location: Ann Arbor, MI
Electronic Memory wrote: I have a philco split chassis set that won't pass a signal if the OSC tube is in the wrong spot in it's socket. Whenever it dies I go and wiggle the osc to fix it. Some sets are finicky like that even after socket cleaning. Tom C. Sounds like the contacts in the socket are loose and not putting enough pressure on the tube pins. Sometimes you can bend the contacts in the socket and tighten them.
_________________ Tom
| Top |
Doug66
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Sat 31, 2012 12:01 am |
Joined: Mar Wed 30, 2011 5:37 am Posts: 596 Location: GA
What did you clean your power transformer with to make it look new?
Doug
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Sat 31, 2012 12:20 am |
DaveM wrote: I would start by checking the voltages at that tube. this is when a TV analyst is great as you can inject RF/IF/composite and narrow it down. If the radio is dead and I presume its a spit system, then you can narrow it down to before the pick off point which is prob pretty close to the tuner. If that is the case I would still focus on the osc, Try a lot of tube wiggling and voltage checking. I did the voltage check. They came out fine.
Worcester, Mass
| Top |
M3-SRT8
Post subject: Re: Andrea T-VK12 & Table Resto Posted: Mar Sat 31, 2012 12:32 am |
Doug66 wrote: What did you clean your power transformer with to make it look new?
Doug Spray Nine. Wash, Rinse, Blow Dry, Bake in Oven 2-3 hours @125 F.
Worcester, Mass
| Top |
Users browsing this forum: Google Adsense [Bot], Scottb, terra2 and 1 guest |
