It is currently May Fri 24, 2013 10:39 am
 Post subject: vintage ge radio
PostPosted: Mar Wed 28, 2012 1:05 am
hi i have a vintage general electric model 351-19a battery/9vdc operated radio. i was wondering if anybody can send a picture diagram to restring a dial cord although i do not have dial cord but is it ok to use string that is thin as the dial cord if it works :?: when i turned the dial knob i heared a snap thats when i knew the cord was not good so how do i replace this.
the model number for the dial cord diagram is: 351-19a
brand name: general electric
 Post subject: Re: vintage ge radio
PostPosted: Mar Wed 28, 2012 11:25 pm
Is it possible for you to post a picture of the radio? I don't know if anyone else is having any luck, but I am not finding that model number for a General Electric radio anywhere at the moment.
By the way, plain old string probably won't work very well. It's too stretchy and too slippery. You are looking for something like braided nylon with a strong non-stretch core. If you do a Google seach for "dial cord" there are a lot of sources. You should be able to get something adequate for $5 or less.
Curtis Eickerman
PostPosted: Apr Sun 01, 2012 9:40 pm
hi curtiss i do not no how to send you pics, i need an email to send them to you. i also have what i was told is an ARVIN 40'S RADIO WITH THE TUBES IN BACK A SMALL ONE
PostPosted: Apr Mon 02, 2012 1:12 am
When you are working on a reply, right below the Submit button there is a Browse and Download button. You can browse to a location on your PC where the picture is located (probably JPG file), Select the specific file, then select OK. Then select Download which will cause the file to be loaded along with your posting. I believe picture cannot exceed 800 X 400 pixels (?) so if you get an error that says the picture is too big you might have to scale it down to be accepted (I think it tells you the maximum size allowed).
I suggest posting a picture because others might recognize the radio and be able to help you.
Curtis Eickerman
PostPosted: Apr Mon 02, 2012 3:55 am
Curtis Eickerman
800 pixels in the biggest direction, and 256 KB.
Brett
PostPosted: Apr Wed 04, 2012 11:17 pm
HI CURTIS HERE ARE THE PICS OF THE 1949 ARVIN RADIO AND THE GE
PostPosted: Apr Wed 04, 2012 11:24 pm
FOR SOME REASON IT HAS KEPT ON SAYING THE FIEL IS TOO BIG MAXIMUM ALLOWED SIZE IS 256 KIB I TRIED SHRINKING IT BUT IT IS TOO BIG
PostPosted: Apr Thu 05, 2012 1:28 am
You might try oldradiofixerupperguy on the Internet. He has thousands of dial string diagrams. I looked for the one for your model number and could not find it, but he invites people to contact him. Good luck.
PostPosted: Apr Thu 05, 2012 2:06 am
Go into a photo-editing program. Set the size so that the max pixel dimension is 800 or less and it's 72 DPI. Then save as "jpeg", and reduce the quality until the size is about 250 kb. Then post.
If you want, and are not in a hurry, send them to me at buckbw AT pacbell DOT net, and I can convert them. But it's a good skill to learn for yourself.
Brett
PostPosted: Apr Thu 12, 2012 11:11 pm
hi brettt did you get the pics of the radios??
PostPosted: Apr Fri 13, 2012 4:46 am
Yes, but they are not too big - very small, in fact. I did no manipulation at all, they are all tiny.
Brett
PostPosted: Apr Fri 13, 2012 7:48 am
I think it's an Arvin 402_A.
PostPosted: Apr Mon 16, 2012 2:00 pm
thank you alot but about the vintage ge radio can you look up the dial cord diagram :?: :?: :?: :?:
PostPosted: Apr Wed 18, 2012 1:19 am
how much does the arvin radio cost today :?: :?: :?: :?: :?:
PostPosted: Apr Wed 18, 2012 7:38 am
Judging by the photos, it is not in very good shape, and given that, it could be a 10-15.00 radio.You could check ebay, buy searching the full model name and number, for sold sets.
PostPosted: May Sat 26, 2012 5:39 pm
does walmart have any dial cord string
PostPosted: May Sat 26, 2012 9:10 pm
Look for braided fishing line. Works great as dial cord.
Reece
PostPosted: May Sat 26, 2012 10:11 pm
Sorry, I didn't see an listing in the Sams index for that model.
Is the original cord still inside the set? If it is, please make a note (the best you can) as to how it is connected.
Newer models can get tricky, you have a tuning knob at the top and the slide rule/dial and tuning cap wheel are probably 90 degrees to each other.
The Spiderwire or other non-stretch fishing line should work. I think it ill need to be tight on those newer radios.
WalWart should carry fishing line that will work.
Your other set should be pretty easy to get going with a recap.
Gary Rabbitt
Post New Topic Post Reply  [ 18 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: pixellany and 4 guests
