Page 1 of 1
[ 18 posts ] |
| Author |
j.pp
Post subject: vintage ge radio Posted: Mar Wed 28, 2012 1:05 am |
hi i have a vintage general electric model 351-19a battery/9vdc operated radio. i was wondering if anybody can send a picture diagram to restring a dial cord although i do not have dial cord but is it ok to use string that is thin as the dial cord if it works  when i turned the dial knob i heared a snap thats when i knew the cord was not good so how do i replace this. the model number for the dial cord diagram is: 351-19a brand name: general electric
| Top |
Eickerman
Post subject: Re: vintage ge radio Posted: Mar Wed 28, 2012 11:25 pm |
| Member |
j.pp wrote: the model number for the dial cord diagram is: 351-19a brand name: general electric Is it possible for you to post a picture of the radio? I don't know if anyone else is having any luck, but I am not finding that model number for a General Electric radio anywhere at the moment. By the way, plain old string probably won't work very well. It's too stretchy and too slippery. You are looking for something like braided nylon with a strong non-stretch core. If you do a Google seach for "dial cord" there are a lot of sources. You should be able to get something adequate for $5 or less. Curtis Eickerman
_________________ http://curtiseickerman.weebly.com
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: Apr Sun 01, 2012 9:40 pm |
hi curtiss i do not no how to send you pics, i need an email to send them to you. i also have what i was told is an ARVIN 40'S RADIO WITH THE TUBES IN BACK A SMALL ONE
| Top |
Eickerman
Post subject: Re: vintage ge radio Posted: Apr Mon 02, 2012 1:12 am |
| Member |
j.pp wrote: hi curtiss i do not no how to send you pics When you are working on a reply, right below the Submit button there is a Browse and Download button. You can browse to a location on your PC where the picture is located (probably JPG file), Select the specific file, then select OK. Then select Download which will cause the file to be loaded along with your posting. I believe picture cannot exceed 800 X 400 pixels (?) so if you get an error that says the picture is too big you might have to scale it down to be accepted (I think it tells you the maximum size allowed). I suggest posting a picture because others might recognize the radio and be able to help you. Curtis Eickerman
| Top |
Brett_Buck
Post subject: Re: vintage ge radio Posted: Apr Mon 02, 2012 3:55 am |
Joined: Aug Wed 24, 2011 4:35 am Posts: 1271 Location: Sunnyvale CA
Eickerman wrote: j.pp wrote: hi curtiss i do not no how to send you pics When you are working on a reply, right below the Submit button there is a Browse and Download button. You can browse to a location on your PC where the picture is located (probably JPG file), Select the specific file, then select OK. Then select Download which will cause the file to be loaded along with your posting. I believe picture cannot exceed 800 X 400 pixels (?) so if you get an error that says the picture is too big you might have to scale it down to be accepted (I think it tells you the maximum size allowed). I suggest posting a picture because others might recognize the radio and be able to help you. Curtis Eickerman 800 pixels in the biggest direction, and 256 KB. Brett
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: Apr Wed 04, 2012 11:17 pm |
HI CURTIS HERE ARE THE PICS OF THE 1949 ARVIN RADIO AND THE GE
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: Apr Wed 04, 2012 11:24 pm |
FOR SOME REASON IT HAS KEPT ON SAYING THE FIEL IS TOO BIG MAXIMUM ALLOWED SIZE IS 256 KIB I TRIED SHRINKING IT BUT IT IS TOO BIG
| Top |
Alfred Corbin
Post subject: Re: vintage ge radio Posted: Apr Thu 05, 2012 1:28 am |
Joined: Jul Sat 01, 2006 11:17 pm Posts: 1114 Location: Northwest Florida (Panhandle)
You might try oldradiofixerupperguy on the Internet. He has thousands of dial string diagrams. I looked for the one for your model number and could not find it, but he invites people to contact him. Good luck.
| Top |
Brett_Buck
Post subject: Re: vintage ge radio Posted: Apr Thu 05, 2012 2:06 am |
j.pp wrote: FOR SOME REASON IT HAS KEPT ON SAYING THE FIEL IS TOO BIG MAXIMUM ALLOWED SIZE IS 256 KIB I TRIED SHRINKING IT BUT IT IS TOO BIG Go into a photo-editing program. Set the size so that the max pixel dimension is 800 or less and it's 72 DPI. Then save as "jpeg", and reduce the quality until the size is about 250 kb. Then post. If you want, and are not in a hurry, send them to me at buckbw AT pacbell DOT net, and I can convert them. But it's a good skill to learn for yourself. Brett
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: Apr Thu 12, 2012 11:11 pm |
hi brettt did you get the pics of the radios??
| Top |
Brett_Buck
Post subject: Re: vintage ge radio Posted: Apr Fri 13, 2012 4:46 am |
j.pp wrote: hi brettt did you get the pics of the radios?? Yes, but they are not too big - very small, in fact. I did no manipulation at all, they are all tiny. Brett
| Attachments: |
| Top |
glasdave
Post subject: Re: vintage ge radio Posted: Apr Fri 13, 2012 7:48 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
I think it's an Arvin 402_A.
_________________ I move the world just one step on...
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: Apr Mon 16, 2012 2:00 pm |
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: Apr Wed 18, 2012 1:19 am |
| Top |
glasdave
Post subject: Re: vintage ge radio Posted: Apr Wed 18, 2012 7:38 am |
| Member |
j.pp wrote: Judging by the photos, it is not in very good shape, and given that, it could be a 10-15.00 radio.You could check ebay, buy searching the full model name and number, for sold sets.
| Top |
j.pp
Post subject: Re: vintage ge radio Posted: May Sat 26, 2012 5:39 pm |
does walmart have any dial cord string
| Top |
wrnewton
Post subject: Re: vintage ge radio Posted: May Sat 26, 2012 9:10 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5529 Location: Cleona, PA
Look for braided fishing line. Works great as dial cord.
_________________ Reece
| Top |
gary rabbitt
Post subject: Re: vintage ge radio Posted: May Sat 26, 2012 10:11 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13098 Location: Tennessee,USA
Sorry, I didn't see an listing in the Sams index for that model.
Is the original cord still inside the set? If it is, please make a note (the best you can) as to how it is connected. Newer models can get tricky, you have a tuning knob at the top and the slide rule/dial and tuning cap wheel are probably 90 degrees to each other. The Spiderwire or other non-stretch fishing line should work. I think it ill need to be tight on those newer radios. WalWart should carry fishing line that will work.
Your other set should be pretty easy to get going with a recap.
_________________ Gary Rabbitt
| Top |
