Page 1 of 1
[ 2 posts ] |
| Author |
wvuphd
Post subject: Question About Replacing an Electrolytic Cap Posted: Apr Sat 14, 2012 5:23 am |
Joined: Mar Fri 16, 2012 11:24 pm Posts: 9 Location: West Virginia
Hi!
Another rookie question for everyone! I have just begun re-capping my Philco model 40-195. It has two electrolytic capacitors according to the schematic. I replaced one of them with little difficulty. However, the other electrolytic is stuffed inside a metal can with a single positive lead connecting to the power supply. The can itself acts as the ground for the electrolytic. How do I replace this? The replacement cap I have is a radial with two leads. Can I connect the positive lead of the new cap to where the old one connected and then solder the negative lead to the chassis to provide the ground? Or should I try to re-stuff the can with the new cap and solder the new cap's negative lead to the can? I'm completely lost with this one, so all help is greatly appreciated!
| Top |
glasdave
Post subject: Re: Question About Replacing an Electrolytic Cap Posted: Apr Sat 14, 2012 7:15 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
Yes, you can connect it that way. It will work just fine.
_________________ I move the world just one step on...
| Top |
