Page 1 of 1
[ 10 posts ] |
| Author |
corbymite
Post subject: How does a 6H6 tube work! Posted: Apr Thu 19, 2012 2:16 am |
Joined: Jan Thu 19, 2012 9:35 pm Posts: 307 Location: Lompoc, CA 93436
Hi, Working on an RCA radio that used a 6H6 tube for the audio detector. While going through the Riders diagam on voltage measurements I see only a couple volts across the tube! How can it work with such a small voltage? Corby Dawson
| Top |
battradio@
Post subject: Re: How does a 6H6 tube work! Posted: Apr Thu 19, 2012 2:59 am |
| Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 1372 Location: near ST Louis Mo
Its a detector diode it only takes a couple of volts to bias it on .
_________________ Mark
| Top |
codefox
Post subject: Re: How does a 6H6 tube work! Posted: Apr Thu 19, 2012 3:03 am |
Think of that little workhorse as a dual diode. In fact you could substitute a 1N34 germanium diode for each section when in this service at lower frequencies. Higher frequencies, not.
Tube could also be used as a rectifier for very small amounts of current within it's boundries, sometimes found in old precision instruments.
| Top |
FrankB
Post subject: Re: How does a 6H6 tube work! Posted: Apr Thu 19, 2012 6:06 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2117 Location: Olympia WA USA
The 6H6 (and its 7 pin minature clone the 6AL5), work pretty well with low voltages on them. I seldom have had to replace one. I have seen them used as rectifiers over the years also. Mostly in some VTVM's and signal tracers as diode detectors in probes and IIRC, some home brew projects from the radio projects magazines from the "good old days". I have also seen projects using them as bridge rectifiers in metering circuits (2 tubes).
You would be amazed at how little voltage is really required in some projects to make the tubes work. I made a radio using a 6J5 in a regen circuit and got down to 6VDC on the plate with it still working!
_________________ FrankB WB7ELC Member: TCA "I know that all that is wrong with it is one little part".
| Top |
radiotechnician
Post subject: Re: How does a 6H6 tube work! Posted: Apr Thu 19, 2012 9:34 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 3947 Location: Powell River BC
You could try hooking only the heater voltage to the 6H6 and see if there is any voltage between cathode and plate, with a DVM or VTVM on DC.
| Top |
pixellany
Post subject: Re: How does a 6H6 tube work! Posted: Apr Thu 19, 2012 11:25 am |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 5386 Location: Annapolis, MD
Here's a data sheet that includes the plate characteristics: http://frank.pocnet.net/sheets/093/6/6H6.pdfIt seems that it will work even with a plate voltage less that 1v. Most of the data sheets just show the in-circuit performance.
_________________ "It's always something". --Gilda Radner "100%" on E-Bay is not IQ......
| Top |
Dave Wise
Post subject: Re: How does a 6H6 tube work! Posted: Apr Tue 24, 2012 9:02 pm |
Joined: Feb Thu 08, 2007 12:36 am Posts: 1164 Location: Hillsboro, Oregon
The 6H6 was designed from the start to have high "perveance"; that is, it needs hardly any voltage to get some current moving. That's what you want in a detector. It so happens that they also have high enough emission and breakdown voltage that they can be used as a power rectifier if you don't need much power, but that's a secondary application.
Dave Wise
| Top |
Chris108
Post subject: Re: How does a 6H6 tube work! Posted: Apr Tue 24, 2012 10:24 pm |
Joined: Jun Fri 19, 2009 6:34 pm Posts: 2666 Location: Long Island
A 6H6 or 6AL5 contains very small plates which are very close to its cathodes. Consequently, they begin conducting at much lower voltages than a power rectifier. The trade-offs for this is that the tubes can only handle a few mA of current, and the peak inverse voltage is also pretty low.
| Top |
codefox
Post subject: Re: How does a 6H6 tube work! Posted: Apr Tue 24, 2012 10:47 pm |
Which means you always blow one out if you exceed max AC voltage in a VTVM. Same 6AL5.
| Top |
Dennis Banker
Post subject: Re: How does a 6H6 tube work! Posted: Apr Wed 25, 2012 1:28 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 718 Location: St. Louis, MO, USA
I hooked up a 6AL5 in place of the crystal in a crystal set awhile back and it makes a fair detector.
-Dennis
| Top |
Users browsing this forum: No registered users and 0 guests |
