It is currently Jun Thu 20, 2013 6:52 am
 Post subject: Need advice on Emerson 724B repair
PostPosted: Apr Tue 24, 2012 3:30 am
I bought an Emerson 724B quite a while ago and my wife grabbed it to decorate! :oops: Well she is redoing her kitchen and now the 724B is mine again. :) I popped it open to recap it and found it has already been recapped!. Powered it up and no reception. :cry: Looked around and found some very messy work around the IF transformers. Tracing the connections to the new electrolytics I found a big error. They had connected the 95 volt electrolytic to the AVC line! :shock: I reconnected it back where it belonged and powered up again. Finger on the volume control gets hum but still no reception. AVC line reads 0 Volts at turn on and slowly goes positive as the unit warms up. I think this is wrong? :?: Looking at the schematic (Beitman's 1953 page 37) it looks like the wiring error had put 95 volts on the control grid of the 12BA6 IF amp. Anyway can anyone give me advice on what to try now? :?: I.F. coils all read about 19 or 20 Ohms. Some resistors have changed up a bit in value but not radicaly so. Also what type of bulb is the pilot light supposed to be. It works but looks a little dim.
Corby
 Post subject: Re: Need advice on Emerson 724B repair
PostPosted: Apr Tue 24, 2012 6:50 am
I think you will need to check for more wiring errors; start at the antenna and work forward.
PostPosted: Apr Tue 24, 2012 7:04 am
Bingo :shock: You are correct! I was Ohmming out around the tuning capacitor and it showed an open. Should have a low impedance as the loopstick coil is supposed to be in parallel with the tuning capacitor. Looked around and found that the wire from the loopstick terminal board was connected to the wrong terminal. This put a tiny external antenna isolation capacitor in series with the loopstick. :!: Corrected the wiring and now I can get stations. Will give it a good try tommorrow and see if thats the last problem. :) Anyone know the correct pilot light number?
Corby
PostPosted: Apr Tue 24, 2012 9:03 am
Lamp is a 47. I have the Sams (208-5). Do you want a scan? PM your email address.
PostPosted: Apr Tue 24, 2012 11:57 pm
Thanks, Don't need the scan. I have the schematic. Just needed the lamp type. There is a 44 installed. I'll try a #47 per your input and see if it looks better. :D
Corby
PostPosted: Apr Fri 27, 2012 2:52 am
Well I put in a #47 and it is much better! Pretty much finished with it now. Looks and plays nice.
PostPosted: Apr Fri 27, 2012 10:41 am
The 44 can accept double the current the 47 does. If the 47 blows, that's the reason they had the higher capacity (but lower luminescence) bulb in there.
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: N6MKC and 1 guest
