It is currently May Sat 18, 2013 11:51 pm
 Post subject: 1937 Sentinel Radio Question
PostPosted: Apr Thu 26, 2012 6:01 pm
I am getting ready to work on a circa 1937 Sentinel Model 52 table top radio that someone else has previously butchered. All the paper caps have been removed. Does anyone know what make/manufacture the original paper caps were used in 1930s Sentinel radios? Did they have their own branded caps, or use other generic caps like Sprauge? Also, this radio has a bias cell where prior restoror installed a watch battery. Is this a proper replacement for a bias cell?
Britt
 Post subject: Re: 1937 Sentinel Radio Question
PostPosted: Apr Thu 26, 2012 7:01 pm
Last year I did a Sentinel 269T from the late 30's. It had blue-label Solar molded plastic caps.
If the watch battery matches the specified bias cell voltage, it should do, so long as it's properly installed for polarity.
PostPosted: Apr Thu 26, 2012 10:29 pm
Thanks Larry, did these Solar caps look like the plastic bumble-bee style plastic caps?
Britt
PostPosted: Apr Fri 27, 2012 8:35 am
NO, the Solar caps are a light brown, and the wrapper slips over them like a crayon wrapper.
PostPosted: Apr Fri 27, 2012 12:14 pm
Right, and the molded plastic bodies themselves often looked sloppy, as if somebody made them by hand instead of by machine.
L
PostPosted: Apr Fri 27, 2012 5:42 pm
If the bias cell goes between grid and ground, you can likely replace it with a 10 Meg resistor and get rid of it entirely. If it's floating, though, you'll need to keep the battery there.
PostPosted: Apr Fri 27, 2012 11:21 pm
Guys thanks for the info... I re-looked this chassis over and it also has three of the raised tube shield mounts riveted to the tube sockets where the tube shield fit over top in friction mount. Two of these are missing and have two square philco tube shields mounted with grounding strap wires soldered to ground. The more you look....the more you find...maybe I will put this one off awhile and pick a simpler project like my Zenith 8S443 table set.
Britt
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Google Adsense [Bot], Joe Connor, Tarpawns and 12 guests
