It is currently Jul Sat 22, 2017 9:45 am
Post New Topic Post Reply  [ 905 posts ]  Go to page 1, 2, 3, 4, 5 ... 46  Next
 Post subject: LM386N MK-XI BCB Transmitter
PostPosted: May Sun 06, 2012 6:29 pm
NOTE -- I'm working on the broken links... After almost two years of inactivity the hosting service dumped me(Imagine that)...
I spent more time in development with this little guy than most of the tube units... Sound quality is very good and the current drain at 9v is only 11ma, so can be easily powered by a std 9v battery... The coil coupling the audio to the osc is very important, without it current draw is increased by 60%, is essential for battery life...
Unit is built in a discarded satellite tuner... The meter is in series with B+ so takes place of tuning LED on schematic...
On-off sw & gain(level) are operational... Single lighted LED indicates standby or both for power on...
My unit is built semi-modular, board can easily be removed for service or modification... Plug with brown, orange and red wires connects to the power indicator LEDs(has standby and in operation modes)... Audio is fed from gain pot on front panel through the large connector and one at it's upper right connects to ammeter on front panel(in series with B+), lower plug connects ant tuning cap... LM7809 regulator installed at angle for cover clearance...
Large black item is a cover over the line fuse also has a scrap piece of pref board Velcroed over 120v connections to power transformer...
Better shot of board & tuning cap, antenna peaking performed from back panel...
Belly shot of the PCB and 110ma @ 10v xfomer...
 Post subject: Re: LM386N MK-XI BCB Transmitter
PostPosted: May Mon 07, 2012 3:43 am
Very nice work. 8)
PostPosted: May Tue 08, 2012 7:12 pm
Looks good and simple. I'll have to give it a try soon as I get a crystal osc...thanks for your hard work..alan
Don't worry about old age; it doesn't last that long.
PostPosted: May Thu 10, 2012 3:30 am
This is great. I'll start to get kits together.
KB3QNN 73
PostPosted: May Thu 10, 2012 8:12 pm
A kit? That'd be great, Bill.
Can I ask, offer a choice between the 1 mhz osc and the 1.228 please?
And I want to be first in line, I'll take two kits.
-Sam T.
PostPosted: May Thu 10, 2012 9:46 pm
I've tried using a sq wave from my signal gen and as long as the trimmer cap will tune down to 10pf or so(padders usually won't adj completely to 0), the 330uh coil will match 1228Kc to a 10ft antenna... Unfortunately I don't have 1228 osc to try, with a 1230 local, I don't generally keep one on hand... Worse case is the coil will have to be changed to 270uh or maybe a 47- 68pf added in series with the trimmer...
PostPosted: May Fri 11, 2012 1:32 am
Bill, I'll take a kit too..thanks, Alan
PostPosted: May Fri 11, 2012 6:11 pm
Give us a couple of weeks and I'll get kits to everyone. In the meantime PM your mailing addresses.
KB3QNN 73
PostPosted: May Mon 14, 2012 8:30 pm
Bill...I'll PM you too - I think I have the itch to build another of the famous 35z5 designs! Count me for one.
"The 21st Century is a nice place to visit - but I sure wouldn't want to live there."
PostPosted: May Wed 30, 2012 7:58 pm
All kits are shipped.
KB3QNN 73
PostPosted: May Wed 30, 2012 9:10 pm
fantastic!!! thanks, Alan
PostPosted: May Wed 30, 2012 10:27 pm
Looks like a nifty idea, but a couple of questions:
1. The ECS oscillator is TTL and rated for 5V +/- 0.25V. Does the modulated voltage exceed that?
http://www.ecsxtal.com/store/pdf/ecs_100.pdf
2. The ECS runs as a modulated oscillator in this application. Does than cause some FM? Probably even if it does, it isn't a handicap?
PostPosted: May Thu 31, 2012 4:24 am
Hi Rich
Audio signal required for full modulation is approx same PP as the DC input to osc... The LM386 outputs approx 50% of B+ so at 9v should be 4.5v, though I have seen variances between ICs close to .5v...
Norm has reasoned it should not be able to modulate 100% without killing the osc, but I can push it deep into over modulation and osc keeps running, of course distortion is a issue and seems to start being noticeable at approx 85% modulation... I have some older Dale osc that start "chopping" due to osc cutout at only 20-25% modulation, the ECS osc exhibits none of this trait... I haven't noticed any FMing issue(maybe in that last 15% modulation?)... Varying the B+ & using a counter, there wasn't a freq shift at any voltage between enough to keep osc running(less than 3v) to over 6v...
While I hate to admit it, basically this little Tx is so good it pisses me off... Spent hours building tube units(that I'll continue to use), can throw one of these together on a breadboard in just a couple minutes... If I could, only thing that I'd change would be a VFO or maybe a larger selection of IC freq...
PostPosted: May Thu 31, 2012 1:23 pm
Bill I'd like a kit if there are any left. PM sent.
kb3wbb
PostPosted: May Thu 31, 2012 5:32 pm
To all members awaiting kits, don't buy anything as there are backorders happening on some items. I'll have everything there soon except VC-1 which may take another week. PM me with any specific questions. Bill
KB3QNN 73
PostPosted: May Thu 31, 2012 8:54 pm
No rush, whenever it's ready.
kb3wbb
PostPosted: May Thu 31, 2012 8:58 pm
For those who like waveforms, here are the modulation envelope using music and trapezoidal WF with approx 800cps tone... Both are at near 100% modulation...
PostPosted: Jun Fri 01, 2012 1:49 am
35Z5 said: "While I hate to admit it, basically this little Tx is so good it pisses me off... Spent hours building tube units(that I'll continue to use), can throw one of these together on a breadboard in just a couple minutes... If I could, only thing that I'd change would be a VFO or maybe a larger selection of IC freq..."
I doubt it Tom. I would choose your 12AV6-12CS6 transmitter any day.
PostPosted: Jun Fri 01, 2012 6:01 pm
Tom, Between you and Norm we all got the best of both worlds! Also, if compared to the knightkit 3 tube from days of old this needed to be done. The fact that we all now need AM content is the cherry on top.
KB3QNN 73
PostPosted: Jun Sat 02, 2012 12:33 am
I'm not discounting the audio quality of the tube units, they're very good, it's the capability of "almost nothing" that's astounding...
The idea for this Tx isn't mine, giving credit where it's due, Mike Toon posted a slightly simpler version last year but I could not get much more than a bunch of squealing from the one I built... Mostly the problem was the LM386L IC I purchased that absolutely would not tolerate RF feedback from the osc... After trying a alternate configuration that modulated the ground side of the osc, I realized it was a RF issue and went back to a similar circuit as orig but with the added coil for isolation... From that point, it was come up with a good antenna conversion/matching network, in the end proved far simpler than I'd imagined...
