It is currently Jun Sat 23, 2018 9:02 am
 Post subject: Proper battery for older Triplett 310-FET? 7 volt type
PostPosted: May Sun 13, 2012 7:04 pm
I bought an older Triplett Model 310-FET which requires a 7-volt battery. Anyone know exactly which battery it takes? Circa 1974.
I found the manual for the Type 2 online, but that one takes a 15volt NEDA 220 battery instead.
If you happen to have a manual for this older model let me know, or if it is online.
Keith
Keith Ostertag
New Albany, IN 47150
 Post subject: Re: Proper battery for older Triplett 310-FET? 7 volt type
PostPosted: May Sun 13, 2012 7:12 pm
I should add- Please let me know if you know where to obtain these 7-volt batteries, or substitute, or if there is a way to modify the meter to work with something more common/easily obtainable.
Keith
Keith Ostertag
PostPosted: May Sun 13, 2012 7:20 pm
Does this look like it will work?
http://www.durhamradio.com/batt7-7-volt ... hones.html
PostPosted: May Sun 13, 2012 8:27 pm
Thanks for responding Bob-
Well, I don't know. Maybe that will work. (type A175?)
Doesn't give the dimensions, and I don't know how sensitive this meter is to needing exactly 7volts to be within its stated accuracy.
Does anyone know?
Keith
Keith Ostertag
PostPosted: May Sun 13, 2012 11:21 pm
It takes an Eveready E175 or a Mallory TR-175 mercury battery (neither of which are available anymore). A 175 7.5 volt battery should work; however, it may be necessary to adjust the zero more often. There are no user calibration adjustments (e.g., pots).
PostPosted: May Mon 14, 2012 1:00 am
OK, thanks Alan and Bob. That's helpful, I appreciate it.
If anyone has the schematic for this older model please PM me.
Keith
Keith Ostertag
PostPosted: May Tue 15, 2012 2:22 am
My Triplett 310-FET calls for an Eveready 504 which is a 15 volt battery and an N cell.
However beautiful the strategy, you should occasionally look at the results.
Winston Churchill
PostPosted: May Tue 15, 2012 3:04 am
Yea, you must have a Type 2.
Keith Ostertag
PostPosted: May Tue 15, 2012 5:52 am
IDK how much room you have for the battery, but opening up a nine volt Duracell and removing one of the AAAA batteries would leave 7.5 total volts remaining.
PostPosted: May Tue 15, 2012 12:39 pm
Hmm... I've never opened a 9volt battery... is that what's in there!
I ordered an E175 off ebay for $3.95, including shipping. Less than most 9-volt batteries. We'll have to see if the little additional voltage throws measurements off much...
If I had a correct schematic for this model I could probably modify the circuit somehow to accept the slightly higher voltage...
Keith
Keith Ostertag
PostPosted: May Tue 15, 2012 2:07 pm
The meter should not have to be modified to work with the slightly higher voltage.
PostPosted: May Tue 15, 2012 2:12 pm
The reason that a mercury battery was used is that it provides a very stable output voltage as contrasted against other types of batteries. This eliminated the complexity adding voltage regulator circuits to the design. If the meter is working, the battery you ordered will work. You will have to use the zero adjust more often to compensate for the voltage regulation characteristics of the battery. I have exactly the same meter that you have and have had no problems (after I replaced the faulty components).
PostPosted: May Tue 15, 2012 6:14 pm
OK, thanks Alan for that info. It's always great to hear from personal experience.
And a special thanks to Steve R for sending me the correct manual for this model!
Keith
Keith Ostertag
Users browsing this forum: Alexa [Bot] and 15 guests
