Page 1 of 1
[ 3 posts ] |
| Author |
allthumbs
Post subject: Problem with a rip in the veneer Posted: May Thu 17, 2012 3:55 pm |
| Member |
Joined: Aug Wed 25, 2010 3:23 pm Posts: 535 Location: Pacific Northwest
The veneer on this cabinet has stretched apart, creating the rip you can see in the photo. It's the result of being on a curved surface where the wood underneath has swollen, I guess. The veneer is not pulling away from the cabinet--it is still solidly glued to the wood underneath.
Do any of you have any suggestions for making this less obvious? I can refinish, but I'm not able to re-do the veneer as that is beyond my skill level. A cabinet shop would undoubtedly charge more than the radio is worth (9-S-367).
Thanks!
| Attachments: |
_________________ I know just enough about old radios to be really dangerous
| Top |
cwysong
Post subject: Re: Problem with a rip in the veneer Posted: May Fri 18, 2012 1:32 am |
Joined: Oct Sun 05, 2008 6:47 am Posts: 516 Location: Bothell, WA
I would strip the radio and then apply clear sanding sealer to the tear. Fill it in completely, sand it flat, then use some light stains with a paint brush to match the color of the veneer. After that apply some clear. I had this problem on the center post of my Zenith 12s265. The veneer had split vertically. I tried lots of things and they all made the tear stand out. I finally tried sanding sealer and then painted the wood grain on with an artists paint brush. It worked nicely.
Chris
| Top |
allthumbs
Post subject: Re: Problem with a rip in the veneer Posted: May Fri 18, 2012 4:05 am |
| Member |
Thanks Chris. That's kind of what I was thinking, but wanted confirmation from more experienced restorers.
| Top |
Page 1 of 1
[ 3 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: tyedyeskyguy and 1 guest |
