It is currently Nov Wed 21, 2018 8:52 pm
Post New Topic Post Reply  [ 269 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14  Next
PostPosted: Sep Sun 24, 2017 2:27 am
Flipperhome wrote:
Flipperhome wrote:
While that's physically true you have to remember that the 6AQ5 voltage limits are less than a 6V6.
Yes.. true... but GE set the parameters for this circuit design.
Data sheets show 6V6 max Plate +315v and only +250 for 6AQ5.
In MY 6v6GT / 6AQ5 amp I run 292v on the plate.... so far hasn't exploded.
What does 'GE" have to do with the circuit design?
You're closer than you think because plate is actually B+ minus cathode voltage.
John is repairing a GE radio with 2 6AQ5 tubes ans a 12AX7 etc...
GE designed that radio.
... read his earlier post.
PostPosted: Sep Sun 24, 2017 2:32 am
The "GE design" has B+ = 268 volts, which will have plate voltage B+ minus the cathode V. Right spot on the spec of 250V.
It's YOUR stated 292 V B+ that I wondered what "GE" had to do with.
PostPosted: Sep Sun 24, 2017 2:41 am
John:
That GE looks a bit like this RC1671A set.
http://www.antiqueradio.com/Jun10_Schoo ... ation.html
Yes, it does. The exact same turn table. The am-fm radio, and separate amp look the same.
I wonder if one of those manufactures mass produced them for others.
John Smith, over and out.
PostPosted: Sep Sun 24, 2017 2:43 am
The unit sounds very good. It has SE amps, and plenty of volume.
Having problems with the idler wheel. I cleaned it with alcohol but still slips.
PostPosted: Sep Sun 24, 2017 2:46 am
It doesn't.
I was just adding a foot note comment that my amp is operating with those values for better or for worse.
+292v -19v cathode bias = +273v
PostPosted: Sep Sun 24, 2017 4:19 am
I think the amp is a model GE 'RC-1641' from 1964, according to Beitmans.
PostPosted: Sep Sun 24, 2017 5:38 am
Here's the schematic:
http://www.radiomuseum.org/schemaviewer ... Fsch%2Epdf
PostPosted: Sep Sun 24, 2017 6:24 am
They wont let me in.
PostPosted: Sep Sun 24, 2017 7:33 am
Try this:
http://pbpix.com/radio/ge%20rc1641.pdf
PostPosted: Sep Sun 24, 2017 8:41 am
That worked, and is the correct schematic.
PostPosted: Sep Mon 25, 2017 1:06 am
You may want to get membership to www.radiomuseum.org John.
$25 for lifetime.
I had to do some gyrations of trying to copy and save that print then upload it to my web page server and then link you to it there.
PostPosted: Sep Mon 25, 2017 6:02 pm
You may want to get membership to http://www.radiomuseum.org John.
$25 for lifetime.
I will do that peter. Will be handy to use.
PostPosted: Sep Mon 25, 2017 6:06 pm
In that schematic, it shows power output for the tuner, on a separate chassis.
That chassis has a selenium rectifier, and a multi section filter. It sits on top in a metal can.
The tuner sounds very good. Should this 50 YO cap still be changed?
PostPosted: Sep Mon 25, 2017 7:21 pm
Yes change it.
PostPosted: Sep Mon 25, 2017 10:15 pm
Think about that.
No matter how good it sounds... no electrolytic cap should be kept in service that long. Yikes.
PostPosted: Sep Mon 25, 2017 10:23 pm
I must agree with you guys. I will need to pull the chassis to get to it. Might also consider the audio coupling
caps just for the adventure.
Thank you men, again.
PostPosted: Sep Mon 25, 2017 10:24 pm
$25 for lifetime.
Thanks special for that Peter.
You are the best.
PostPosted: Sep Mon 25, 2017 11:40 pm
You are the best.
PostPosted: Sep Tue 26, 2017 6:52 am
That's great Peter.
The turn table has a rubber idler wheel. I cleaned it up good.
Tightened up the spring, and lubed the wheel.
The turn table drags with a record on it.
The idler wheel turns a little stiff, even after some light oil lube.
Don't know what else to do.
PostPosted: Sep Tue 26, 2017 8:27 am
john8750 wrote:
That's great Peter.
other than that...I don't know either... maybe other forums here or elsewhere?
Users browsing this forum: Google [Bot] and 3 guests
