Author |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 2:27 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23456 Location: Haledon, NJ, usa
Flipperhome wrote: Pbpix wrote: Flipperhome wrote: While that's physically true you have to remember that the 6AQ5 voltage limits are less than a 6V6. Yes.. true... but GE set the parameters for this circuit design. Data sheets show 6V6 max Plate +315v and only +250 for 6AQ5. In MY 6v6GT / 6AQ5 amp I run 292v on the plate.... so far hasn't exploded. What does 'GE" have to do with the circuit design? You're closer than you think because plate is actually B+ minus cathode voltage. John is repairing a GE radio with 2 6AQ5 tubes ans a 12AX7 etc... GE designed that radio. ... read his earlier post.
_________________ To be a man, Be a non-conformist, Nothing's sacred as the integrity of your own mind. -Emerson
Top |
Flipperhome
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 2:32 am |
Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 9277 Location: Texas. USA
Pbpix wrote: Flipperhome wrote: Pbpix wrote: Yes.. true... but GE set the parameters for this circuit design.
In MY 6v6GT / 6AQ5 amp I run 292v on the plate.... so far hasn't exploded. What does 'GE" have to do with the circuit design? You're closer than you think because plate is actually B+ minus cathode voltage. John is repairing a GE radio with 2 6AQ5 tubes ans a 12AX7 etc... GE designed that radio. ... read his earlier post. The "GE design" has B+ = 268 volts, which will have plate voltage B+ minus the cathode V. Right spot on the spec of 250V. It's YOUR stated 292 V B+ that I wondered what "GE" had to do with.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 2:41 am |
Member |
Joined: Dec Mon 29, 2014 9:39 pm Posts: 4969 Location: Los Angeles
Pbpix wrote: Yes, it does. The exact same turn table. The am-fm radio, and separate amp look the same. I wonder if one of those manufactures mass produced them for others.
_________________ John Smith, over and out. If I did something right, I made a mistake.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 2:43 am |
Member |
The unit sounds very good. It has SE amps, and plenty of volume. Having problems with the idler wheel. I cleaned it with alcohol but still slips.
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 2:46 am |
Member |
Flipperhome wrote: The "GE design" has B+ = 268 volts, which will have plate voltage B+ minus the cathode V. Right spot on the spec of 250V.
It's YOUR stated 292 V B+ that I wondered what "GE" had to do with. It doesn't. I was just adding a foot note comment that my amp is operating with those values for better or for worse. +292v -19v cathode bias = +273v
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 4:19 am |
Member |
I think the amp is a model GE 'RC-1641' from 1964, according to Beitmans.
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 5:38 am |
Member |
john8750 wrote: I think the amp is a model GE 'RC-1641' from 1964, according to Beitmans. Here's the schematic: http://www.radiomuseum.org/schemaviewer ... Fsch%2Epdf
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 6:24 am |
Member |
Pbpix wrote: john8750 wrote: I think the amp is a model GE 'RC-1641' from 1964, according to Beitmans. Here's the schematic: http://www.radiomuseum.org/schemaviewer ... Fsch%2EpdfThey wont let me in.
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 7:33 am |
Member |
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Sun 24, 2017 8:41 am |
Member |
That worked, and is the correct schematic.
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 1:06 am |
Member |
john8750 wrote: That worked, and is the correct schematic. You may want to get membership to www.radiomuseum.org John. $25 for lifetime. I had to do some gyrations of trying to copy and save that print then upload it to my web page server and then link you to it there.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 6:02 pm |
Member |
Pbpix wrote: john8750 wrote: That worked, and is the correct schematic. You may want to get membership to http://www.radiomuseum.org John. $25 for lifetime. I had to do some gyrations of trying to copy and save that print then upload it to my web page server and then link you to it there. I will do that peter. Will be handy to use.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 6:06 pm |
Member |
In that schematic, it shows power output for the tuner, on a separate chassis. That chassis has a selenium rectifier, and a multi section filter. It sits on top in a metal can. The tuner sounds very good. Should this 50 YO cap still be changed?
Top |
Tube Radio
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 7:21 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 19552 Location: Warner Robins, GA
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 10:15 pm |
Member |
john8750 wrote: Should this 50 YO cap still be changed? Think about that. No matter how good it sounds... no electrolytic cap should be kept in service that long. Yikes.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 10:23 pm |
Member |
I must agree with you guys. I will need to pull the chassis to get to it. Might also consider the audio coupling caps just for the adventure. Thank you men, again.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 10:24 pm |
Member |
Pbpix wrote: john8750 wrote: That worked, and is the correct schematic. You may want to get membership to http://www.radiomuseum.org John. $25 for lifetime. I had to do some gyrations of trying to copy and save that print then upload it to my web page server and then link you to it there. Thanks special for that Peter. You are the best.
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Mon 25, 2017 11:40 pm |
Member |
john8750 wrote: Thanks special for that Peter. You are the best.
Top |
john8750
Post subject: Re: Philco amp re-build. Posted: Sep Tue 26, 2017 6:52 am |
Member |
That's great Peter. The turn table has a rubber idler wheel. I cleaned it up good. Tightened up the spring, and lubed the wheel. The turn table drags with a record on it. The idler wheel turns a little stiff, even after some light oil lube. Don't know what else to do.
Top |
Pbpix
Post subject: Re: Philco amp re-build. Posted: Sep Tue 26, 2017 8:27 am |
Member |
john8750 wrote: That's great Peter. The turn table has a rubber idler wheel. I cleaned it up good. Tightened up the spring, and lubed the wheel. The turn table drags with a record on it. The idler wheel turns a little stiff, even after some light oil lube. Don't know what else to do. other than that...I don't know either... maybe other forums here or elsewhere?
Top |
