It is currently Feb Thu 21, 2019 10:35 am
 Post subject: AM transmitter options?
PostPosted: Dec Thu 07, 2017 10:57 am
I am looking for a frequency-agile AM transmitter I can use to play MP3 files over my antique radios. I say frequency agile, because at night I sometimes get interference from distant stations on the fixed frequency my 12AT6/12CS6 transmitter is set to (I built mine for 1228KHz, in hopes that the odd frequency would not get any interference. However...). The SSTRAN is now out of production, so that is not an option. Don't want to spend an arm and a leg, either. Are there any options out there?
 Post subject: Re: AM transmitter options?
PostPosted: Dec Thu 07, 2017 11:22 am
viewtopic.php?f=12&t=280783&p=2345984#p2345984
PostPosted: Dec Thu 07, 2017 4:59 pm
If it's tuned properly, within 40-50ft of transmitter a 12CS6 should cover the background noise easily...
PostPosted: Dec Thu 07, 2017 11:32 pm
The worst problem I have with interference is with one of our local stations, especially when I am using one of my 1920's TRF sets (they actually sound better to my ear than most of my later sets, oddly enough, unless I am using my Atwater Kent horn speaker). Because they tune rather more broadly than a superhet, our local station at 1270KHz - which, believe it or not, comes in so strongly during daylight hours that you can sometimes pick it up on a crystal set just by touching the antenna terminal, with no ground hook-up - can be heard in the background, even with my 12CS6/12AT6 transmitter set up nearby with a good antenna. The station still comes in strongly at night, even after the station throttles its power back. Thus, my desire for a frequency-agile transmitter.
So again, is there one available as a kit? Or has someone designed one and published the info on how to build one? Can an older "talking house" transmitter be modified easily (I have seen some fairly cheap on EBay)?
PostPosted: Dec Fri 08, 2017 2:40 am
Ramsey had a fairly decent unit but AFAIK they ran afoul with the powers that be, so it's discontinued... The Vectronics 1290K is apparently still being sold... My experience is it isn't as good as they make it sound but does perform somewhat acceptable... http://www.vectronics.com/Product.php?p ... =VEC-1290K
There have been some positive reports on the Talking House, but others say junk which is experience with one I had around here... They do seem to be hit or miss...
PostPosted: Dec Fri 08, 2017 10:05 am
I had a Talking House 5 transmitter, and loved both the digital frequency display, and ease of selecting the transmitting frequency. I sold it, however, because of the background hum it continually had.
PostPosted: Dec Fri 08, 2017 2:47 pm
I see Vectronics (owned by MFJ) has a kit (VEC-1290K) for about $30. Wonder if it is any good...?
PostPosted: Dec Fri 08, 2017 6:45 pm
Here is the schematic.
PostPosted: Dec Fri 08, 2017 7:17 pm
Doesn't tell me much. I know it has some frequency adjustment and antenna tuning built into it, though.
PostPosted: Dec Fri 08, 2017 10:35 pm
Wow, Mike, thanks for posting that. It's dated 1990. Do you think that's the first use of a 386 as a modulator?
I've wondered if a simple LC oscillator would be stable enough for most ARFers' use. The trend lately is to use some form of crystal control. But if Vectronics has a $30 kit that includes antenna tuning, that might turn out to be a fine substitute for SSTrans.
PostPosted: Dec Fri 08, 2017 10:46 pm
The problem I had with an LC oscillator was the beat tone from adjacent stations would rise and fall constantly as the oscillator drifted up and down. Also there would be beat tones from distant stations on the same frequency giving low frequency tones also rising and falling with oscillator drift. If you're in an area with few stations on the dial I guess it's OK.
PostPosted: Dec Sun 10, 2017 6:12 pm
That's why crystal control is the way to go. Anything with MFJ on it should be regarded with some skepticism.
PostPosted: Dec Sat 16, 2017 4:36 pm
Just found this kit on EBay: https://www.ebay.com/itm/AM-Transmitter-Kit/142624623282?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649. Looks promising...
PostPosted: Dec Sat 16, 2017 5:51 pm
I have a couple of two-tube AM transmitters, both are octal tubes. They are missing one tube and I am not sure what that tube should be. I thought I had a paper showing the unit, but have misplaced it.
PostPosted: Dec Sun 17, 2017 12:21 am
Being octal it's probably copy of the Zenith phono osc, those had a rectifier and probably a 12SA7... I dunno if any of those used a power transformer...
A picture would be helpful, depending on what it is, possibly may need close view of wiring to sockets...
PostPosted: Dec Sun 17, 2017 4:49 am
I found these two AM transmitters. One tube is the rectifier, a 35Z5 and the missing tube was a 12something or other, maybe a 12SQ7? Any thoughts on what the second tube should be? I'll have to see if I can't find the paper that came with this, but I might not. They look to be new, and I have no use for them as I have an SSTRAN and a Talking House.
PostPosted: Dec Sun 17, 2017 1:10 pm
Not much doubt, those are Zenith phono osc likely have a hot chassis that'll get you knocked on your butt... Used 12SA7 that modulate poorly...
I'd put the 35Z5(s) in my tube stash and part/junk the remainder...
PostPosted: Dec Sun 17, 2017 2:27 pm
I'd be happy to take them off your hands...
PostPosted: Dec Sun 17, 2017 8:26 pm
Uh huh...And why is this suggestion not a surprise... :wink:
PostPosted: Dec Sun 17, 2017 9:05 pm
Naah ain't that, none of my current daily players even have a 35Z5... The Silvertone AA6 now with PP triode audio has 1N4007, the TV tube radio has a pair of 17AX4 used as full wave rect, Warco has a 6ZY5(rorig had two 6J5 as rect) and the plastic AA6 Westinghouse has a 25DK4... British Philco has a 5Z4 and the Silvertone console has a 5Y3... The sometimes player Mantola farm radio has 50L6 audio and a 35Z4 rectifier(close but no cigar)... Still has it's 1.4v battery tubes in small signal circuits... At one time it did use a 35Z5 rectifier but when I converted from 3Q5 to 50L6, additional tie points were needed... Pin 3 now has heater dropper rectifier tied to it...
