It is currently Sep Sun 23, 2018 12:21 am
 Post subject: QST's Pine board AM transmitter with tubes
PostPosted: Dec Sat 30, 2017 2:08 am
Greetings,
I understand that this months issue of the QST magazine has a pine board AM transmitter project in it.
As I'm not a member of ARRL, I don't receive the magazine.
Has anyone here seen this article? Is it a novel circuit concept or just another copy of one of the existing layouts?
 Post subject: Re: QST's Pine board AM transmitter with tubes
PostPosted: Dec Sat 30, 2017 11:02 am
This QST cover story is available at no cost. You do not need to be a member to read this one. Just google the title and download the pdf. Not novel but a nice approach using "Heising Modulation" 5 W on 40 meters. Authored by Bob Heil and is nicely done piece. Alan W4AMV.
PostPosted: Dec Sat 30, 2017 12:28 pm
PDF is here
http://www.arrl.org/files/file/QST/This ... 8/Heil.pdf
PostPosted: Dec Sat 30, 2017 1:42 pm
Alan and Dave, thank you.
I'll take a look at the article.
Gar
PostPosted: Dec Sat 30, 2017 2:39 pm
ggargia wrote:
Greetings,
Novel? Yes, however, a "slat board" transmitter and power supply were developed and published in an ARRL handbook of the early 50's. There was also a miniature battery tube plug-in coil regenerative receiver too, but not slat board on a metal chassis.
If you like the concept of early homebrew Ham transmitters you might like to join the AWAGroup, a Yahoo group of mostly Hams building and using transmitters designed with tubes of 1929 and before.
https://groups.yahoo.com/neo/groups/AWAGroup
Chas
WA1JFD
PostPosted: Dec Sat 30, 2017 6:42 pm
Slat board transmitters go back to the 1930s and probably a lot earlier.
http://theradioboard.com/rb/viewtopic.php?t=3580
Built at a time when TVI and EMI weren't of much concern.
Here is one done by NT9K:
PostPosted: Dec Sat 30, 2017 7:54 pm
Nice!
Concerned about TVI?
Is that a problem in the digital age with CW?
Better not participate in the BK, or Cundal CW contest net week...
Have an image of slat from the 20' 30's?
PostPosted: Dec Sun 31, 2017 4:24 am
Gotta love the improvised crystal socket!!
Rick
AB5ON
Forest Gumping through life
PostPosted: Dec Sun 31, 2017 5:17 am
Octal sockets were used in some commercial transmitters, the socket was behind a sub-panel with openings only for two crystals.
PostPosted: Dec Sun 31, 2017 2:53 pm
Like my EFJ Ranger.
Avery W3AVE
PostPosted: Jan Wed 10, 2018 4:17 am
ggargia wrote:
Greetings,
Tonight I worked KK4RF on 75M who said he was using a pine-board transmitter he finished just today using the circuits Bob Heil described in the QST article. The audio sounded quite good.
PostPosted: Jan Wed 10, 2018 10:16 pm
And, the original series is on Heil's website. It includes some videos as well:
https://heilsound.com/amateur-radio-pos ... d-project/
PostPosted: Jan Sat 13, 2018 12:59 am
If you haven't seen the 5W 50C5 CW transmitter, here are two links:
http://www.qsl.net/kb7tbt/manuals/Ham%2 ... esigns.pdf
http://www.qsl.net/wd4nka/TEXTS/50c5f.HTM
Looks like fun.
Rob
PostPosted: Jan Sat 13, 2018 1:36 am
I really like the neon (NE-2) warning light that lights if the 2-prong plug is reversed on a transformerless rig. I'm goin back to a project for an "update". :wink:
It should be incorporated on all transformerless homebrews.
PostPosted: Jan Sat 13, 2018 3:20 am
What I don't like about that 50C5 circuit is the 400 ohm 20W resistor to drop the heater voltage. It's wasteful. Why not put two 50C5 tubes in parallel, wire the heaters in series? Thereby a much smaller resistor. Or use two 60FX5: no need for a dropping resistor at all then.
Or better: use them in push-pull!
Some ideas:
http://www.w7ekb.com/glowbugs/tx/transmitters.html
The killer in these simple designs is finding a suitable xtal.
Rob
PostPosted: Jan Sat 13, 2018 3:29 am
Or use DC and only drop 34V.
PostPosted: Feb Fri 09, 2018 7:15 pm
I built the Bare Essentials rig many years ago and resurrected it for the Novice Rig Roundup last February. I throttled back the output to 5 watts, by lowering the screen voltage (simple increase in screen resistor value). My only upgrade is the addition of a plate current meter. The pill bottle tank coil is for 40 meters, the 80 meter coil is in the background. A British Navy key and a few FT-243's in the foreground.
I still enjoy using this rig and will again in the Novice Rig Roundup in March. The single 50C5 and the 400 ohm resistor do not exactly warm the room but both do produce some heat!
Todd
ka8gef
'Itoshiki oshieo idaki'
-Let us never lose the lessons we have learned.
PostPosted: Feb Sun 11, 2018 3:23 pm
Some ideas:
Rob
Or use two 50C5's and a 35W4. No dropping resistor needed. This is the tube
lineup I used in a low power AM BCB transmitter design recently. One 50C5
was the xtal osc, the second was the PA.
Slat board, or breadboard layouts have been around as long as radio has.
And they are a blast to build.
Steve
