It is currently Feb Sat 16, 2019 10:29 am
 Post subject: Gilfillan Radiobar Working
PostPosted: Jan Fri 12, 2018 4:48 am
This is a 5 tube set (2A5, 2A6, 2A7, 58, 80). The dial is round and only says, "Radiobar."
Thank you,
Dale
http://www.dalesantiqueradio.com/
 Post subject: Re: Need Gilfillan Radiobar Schematic
PostPosted: Jan Fri 12, 2018 4:58 am
Dale
Here is a list of radios using those tubes:
http://www.grillecloth.com/sylvania/tub ... ubmit&db=5
Might try Mission Bell Model 40?
http://www.nostalgiaair.org/pagesbymode ... 010914.pdf
PostPosted: Jan Fri 12, 2018 1:51 pm
Are you sure the tube lineup is correct?
Check out this list..
https://www.radiomuseum.org/m/gilfillan_usa_en_1.html
The 5-C looks really close...
PostPosted: Jan Fri 12, 2018 3:10 pm
Thank you. I tried that one but only the power supply section matches. Resistor values and locations not even close.
Dale
PostPosted: Feb Wed 07, 2018 3:33 pm
Got it running! Also lots of errors out there about RCA chassis being used in Radiobars. Gilfillan had an RCA license. See dial detail.
Dale
Users browsing this forum: lorenz200w and 10 guests
