It is currently Feb Wed 20, 2019 2:16 am
 Post subject: Help to ID receiver
PostPosted: Sep Mon 08, 2008 2:38 am
I just picked this set up for a winter project, probably a few winters. The only name on it is "POSTAL RADIO" on the right tuning dial.
It has a chrome chassis, and uses 4 long square plug in coils for tuning.
Anyone familiar with this one?
http://myvintagetv.com/sell/radio1.jpg
http://myvintagetv.com/sell/radio2.jpg
http://myvintagetv.com/sell/radio3.jpg
Chuck
PostPosted: Sep Mon 08, 2008 2:44 am
Chuck -
There is a 9 tube "International" model from Postal Radio in Gernsback's 1934 Short Wave Manual. It uses a plug-in coil unit with three coils in a rectangular plugin subchassis.
Chuck N7RHU
PostPosted: Sep Mon 08, 2008 9:36 pm
Chuck,
Thanks for the information, just have to find a copy now. This set has 10 tubes.
Chuck
PostPosted: Sep Tue 09, 2008 12:43 am
That looks like a real interesting receiver. I wonder how the circuit compares to the National AGS?
PostPosted: Sep Wed 10, 2008 1:54 am
I have a soft spot for the early pre-War boatanchors -- and the smaller and more obscure the company, the better.
According to my copy of Moore's, "Communication Receivers, The Vacuum Tube Era 1932-81", Postal Radio of 133/135 Liberty St., New York, NY was around for only two years: 1934-1935. Yours is the 1935 model that tuned .55-23mhz. Other than a listing of the tube lineup, Moore only notes the triple-gang plug-in coils along with a picture.
You have a rarity -- hang on to it!
Chris
 Post subject: Re: Help to ID receiver
PostPosted: Jan Mon 15, 2018 9:16 pm
Well, it's hard to believe it's been almost 10 years since I started this thread, and harder to believe I thought I would have this radio restored in a few months!
As usual when you start a project like this things go south fast and bad. For those not familiar with this project here are pictures of the set from 2008:
It was pretty much a basket case, but for some reason I thought it was special.
First thing that had to happen was strip everything from the chassis so it could be re-chromed and glass bead all the other metal work to remove the rust. Well after I gutted it, making sure I took many pictures of the component placement and wiring, I come to find out there isn't a schematic of this set anywhere. The 9 tube schematic was available and Chuck N7RHU gave me information where to find that, problem was other than the tube lineup the circuit was different. So after getting the chassis chromed and reinstalling sockets, coil cans, and tuning condensers, the restoration came to a halt.
Move ahead 4 years and I received a copy of the Nov 1934 issue of Short Wave Craft from a friend and in it is an article about the new Postal 35 receiver and also a fair copy of the elusive schematic. http://www.myvintagetv.com/sell/Postal%2035%20Article.pdf
So now 10 years later I have a restored working Postal 35 receiver:
I still have to repaint the metal case in black wrinkle finish and do some wood repair and paint on the stand that came with the set. Hopefully that won't be another 10 years.
Chuck
PostPosted: Jan Mon 15, 2018 10:20 pm
Dang! How many of us would have given up by now? Well done, and congratulations on being steadfast! Looks very nice.
PostPosted: Jan Mon 15, 2018 10:37 pm
Absolutely beautiful work Chuck!
How is the performance?
Rodger WQ9E
PostPosted: Jan Mon 15, 2018 10:45 pm
Nice job restoring it!
aaaahhh there is hope yet for me.....
pics here https://www.facebook.com/oldgoaly/photo ... 1507215179
PostPosted: Jan Mon 15, 2018 10:54 pm
I am in awe. I thought I had tackled a few tough radio restorations, but that is truly bringing back the dead.
KK6IYM
PostPosted: Jan Tue 16, 2018 1:44 am
So...this is a plug-in coil set I see.
I wonder if that is the McMurdo Silver patent design that Silver was squabbling with James Millen at National about, i.e. that National was infringing with the first HRO.
WB6NVH
http://www.wb6nvh.com
PostPosted: Jan Tue 16, 2018 1:53 am
Wow! Well done.
kb3wbb
PostPosted: Jan Tue 16, 2018 4:37 am
Bravo!!!! Labor of love, looks great!!
PostPosted: Jan Tue 16, 2018 5:17 pm
When I scrolled down to the first pic I chuckled and thought to myself " where is the chrome chassis?"
:lol:
PostPosted: Jan Tue 16, 2018 8:19 pm
Rodger WQ9E
Thanks.
The performance is mediocre, not sure if it is just the design of the set or other front end issues. I did a quick SNR test, for 10db S/N +N:
A Plug-in @1.5 MHz - 10uV
B Plug-in @4 MHz - 80uV
C Plug-in @9 MHz - 50uV
D Plug-in @22 MHz - 100uV
There isn't much to adjust in the RF sections, the A box has only the Oscillator high & low adjustments, B box has no adjustments, C box has Oscillator high adjustment, D box has RF, Mixer & Oscillator high adjustments.
A few years ago I picked up this Postal Preselector to go with the receiver:
It has and "E" plug-in and covers 820KHz to 2.2MHz, an odd range to be sure. I measured gain of 21dB @ 2MHz sloping down to a loss of 7dB at 820KHz. I would like to find additional coil boxes for it.
It uses two 78 tubes for amplification and a 37 as the rectifier.
Chuck
PostPosted: Jan Tue 16, 2018 9:26 pm
Chuck,
That will make an even nicer looking setup with the preselector.
I suspect there is an issue in the receiver because I would expect much better sensitivity from this setup, at least up to 20 Mhz. or so. Do some tube substitution if you have spares (start with the RF stage, mixer, and HFO) and you can also use your signal generator as a substitute for the HFO to see whether low HFO injection level is the problem. Signal tracing may also prove useful. A much simpler set should recover a very loud signal in the 50 uv range so gain is low somewhere. Check the RF gain pot to make sure it isn't the issue.
Congratulations again on taking that project and doing so much with it!
Rodger WQ9E
PostPosted: Feb Sat 03, 2018 5:37 am
To close out this thread, here is the Postal Model 35 complete in it's cabinet and on the stand I got with it:
Chuck
PostPosted: Feb Fri 16, 2018 3:40 am
Nice. Those are the setups that us pre-war radio nuts dream of finding, and you did a marvelous job reviving it.
And then you found the preselector too (because I'm sure they're as common as stink bugs, right)?
Dayum!
PostPosted: Feb Fri 16, 2018 2:50 pm
Chuck, what a masterful job on a very worthy set.
You have created a real treasure.
73, de Chuck K4CCW
"The question is not what you look at, but what you see." Thoreau
PostPosted: Feb Fri 16, 2018 3:59 pm
Thanks for the praise on the restoration. It was a labor of love as I will never recoup my costs in labor or parts on this project.
I did spend a lot of time recently searching through Radio Craft, Radio News, Radio World, Short Wave Radio & Shortwave Craft for any information on the Postal radio line. It appears they started advertising for the Model 9 in the Oct 1933 issue of Radio News which also included an article about it. The Model 35 appears to have been first announced in the Nov 1934 issue of Short Wave Craft with ads and an article. The last Postal advertisement I could find was in the July 1935 issue of Short Wave Craft.
In Dec 1933 Postal advertised a small 4 tube AC-DC receiver in a wood grained metal cabinet for $18.95, Postal also produced two versions of a SW converter and SW booster/preselector in 1934 & '35. In 1934 they advertised a car radio line and in Feb 1935 they announced a new SW radio that used band switches instead of plug-in coil drawers and looked like a tombstone radio.
From the advertisement timeline, I believe they were in business from mid 1933 to mid 1935, after that I couldn't find any information about them. From the descriptions in the ads and articles it appeared the Model 9 and Model 35 were available as a kit of parts or as complete units.
I've never seen or heard about another Model 35 turning up, a couple of Model 9's have surfaced in addition to a couple boosters and converters. Except for the 4 tube AC-DC set no advertisements for the receivers had a price listed, all said to write for pricing.
If anyone has any additional information on Postal or their radio line I would appreciate hearing from you.
Chuck
Post New Topic Post Reply  [ 20 posts ]  Moderator: Sandy
Users browsing this forum: Eddy, Peter Bertini and 4 guests
