Page 1 of 1
[ 8 posts ] |
Author |
Kevin Clark
Post subject: Miniature Tube Shields Posted: Jan Thu 18, 2018 1:06 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 973 Location: Detroit, Michigan
Wondering if anybody knows if steel miniature tube shields where bare steel or plated with tin or something else from the factory?
Top |
lorenz200w
Post subject: Re: Miniature Tube Shields Posted: Jan Thu 18, 2018 2:16 am |
Joined: Jan Mon 16, 2012 4:15 pm Posts: 5129 Location: Near Brandon, Iowa
Almost certainly steel shields were plated. Rust is inimical to shield operation, since when it forms it can create a nonconductive layer between the shield and the chassis.
Top |
jack.estes
Post subject: Re: Miniature Tube Shields Posted: Jan Thu 18, 2018 3:19 am |
Joined: Oct Thu 02, 2014 5:57 am Posts: 700 Location: Memphis, TN
I've got a handful of them in a box. All are definitely plated. Some appear chromed, and others are clearly cadmium plated.
Top |
Don Cavey
Post subject: Re: Miniature Tube Shields Posted: Jan Thu 18, 2018 4:06 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14198 Location: Fernandina Beach, FL
A lot of them were tin plated.
_________________ Don
Top |
Kevin Clark
Post subject: Re: Miniature Tube Shields Posted: Jan Thu 18, 2018 5:28 pm |
Ok thanks to all for the info. I picked up another Hali SX-100, and the shields on this one are kind of nasty. I wire wheeled one off, and though shiny, it's way too dark in color. I'll have to decide on painting them or investigate getting them plated.
Top |
Poston Drake
Post subject: Re: Miniature Tube Shields Posted: Jan Fri 19, 2018 7:02 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4439 Location: Charleston, W.Va.
Hi Kevin, As Don says, tin plating seemed to be the most common, and of course this often tends to tarnish. Your wire wheel probably removed the tin plating, leaving only bare steel. You might try another one using just Brasso on a soft rag.
A few times in the past, with shields which were extremely bad, I have painted them with metallic silver high-temp engine enamel. This looks good, but of course is not authentic.
_________________ Poston
Top |
Kevin Clark
Post subject: Re: Miniature Tube Shields Posted: Jan Fri 19, 2018 5:05 pm |
Thankyou Poston for the info. Believe it or not, I did break out my Brasso to try before I wired it and in my case, it just made the shield darker in color for some reason, like a charcoal brickette.
Top |
Kevin Clark
Post subject: Re: Miniature Tube Shields Posted: Feb Tue 06, 2018 4:34 pm |
Top |
Page 1 of 1
[ 8 posts ] |
