Author |
LarryAD
Post subject: Re: 12S267 Posted: Jan Mon 15, 2018 11:41 pm |
Joined: Jul Sun 26, 2015 11:34 pm Posts: 641 Location: Hurdle Mills, North Carolina
Top |
Kidd
Post subject: Re: 12S267 Posted: Jan Fri 19, 2018 1:43 am |
Joined: Nov Fri 10, 2017 4:42 pm Posts: 33 Location: Western, Kentucky
Hey.... is that color !!! Been a long time since it had some Big change from this...
Attachments: |
Top |
Bosch's Fault
Post subject: Re: 12S267 Posted: Jan Fri 19, 2018 10:12 pm |
Member |
Joined: Nov Tue 18, 2014 9:18 pm Posts: 550 Location: Corvallis, Oregon
Have neen following along. First class work Larry! Impressive.
Bosch
_________________ Fast is only good if you don't have to start over.
Top |
LarryAD
Post subject: Re: 12S267 Posted: Jan Sat 20, 2018 10:05 pm |
Worked on the cabinet a little more, I think I got the color the way it should look and have a few coats of lacquer on the cabinet, let it cure a coupe of days and steel wool with 0000 and then a few more coats of lacquer.
Attachments: |
_________________ Larry in NC
Top |
radioterry
Post subject: Re: 12S267 Posted: Jan Sun 21, 2018 3:20 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4078 Location: Eschew Obfuscation Virginia 23005
Larry:
Is it just my eyes or does the bottom (base) look a lot different than a regular 12S267...or is that normal?
Terry
Top |
LarryAD
Post subject: Re: 12S267 Posted: Jan Sun 21, 2018 4:03 am |
The shape is correct the color is too brown, I used medium brown toning lacquer on the base and corners. First I'm going to use steel wool to remove some of the toner and add some some darker aniline dye to see how it looks. If I'm not happy with that I'll go with a darker toning lacquer.
Top |
processhead
Post subject: Re: 12S267 Posted: Jan Sun 21, 2018 1:47 pm |
Member |
Joined: Jul Tue 15, 2008 6:13 pm Posts: 5833 Location: Gretna, Nebraska
Top |
Gary123
Post subject: Re: 12S267 Posted: Jan Mon 22, 2018 2:02 am |
Joined: Apr Fri 30, 2010 9:04 pm Posts: 1335 Location: New York 12986
Top |
LarryAD
Post subject: Re: 12S267 Posted: Jan Wed 24, 2018 12:30 am |
Top |
LarryAD
Post subject: Re: 12S267 Posted: Jan Sat 27, 2018 11:25 pm |
Top |
LarryAD
Post subject: Re: 12S267 Posted: Jan Wed 31, 2018 11:52 pm |
Top |
Kidd
Post subject: Re: 12S267 Posted: Feb Thu 01, 2018 12:22 am |
Only one word to say Larry... Unbelievable Kidd
Top |
azenithnut
Post subject: Re: 12S267 Posted: Feb Thu 01, 2018 2:01 am |
Member |
Joined: Jan Mon 18, 2010 2:13 am Posts: 17858 Location: Dayton Ohio
Larry, that is an amazing transformation from junk to treasure! I am very impressed! -Steve
_________________ Radio Interests -Zenith -Sparton -Pre-War FM Consoles and floor models, the bigger, the better!
Top |
LarryAD
Post subject: Re: 12S267 Posted: Feb Fri 02, 2018 2:34 pm |
Thanks for all the comments, getting near the end of this project. I installed the grill cloth I got from Richmond Designs yesterday. Waiting on a voice coil for the speaker. Chassis recapped, belts replaced, tuning motor checked, all tubes checked, rf choke replaced, field coil rewound and the dials replaced from a donor chassis I had. The acoustical adapter was repaired using orthopedic cast tape and painted with hammered gold paint. The next post from me will be when it is playing and assembled.
Attachments: |
Top |
radiopicker
Post subject: Re: 12S267 Posted: Feb Sat 03, 2018 1:42 pm |
Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 4462 Location: Rochester, NY
Larry- the color is all SPOT on... Seems I've finally crossed a resto of this cabinet that I find perfect to my taste colorwise. I'm going to re-read the thread now incase I missed it but can you please confirm any and all products that involved color for the main body as well as trims for my record, from stains, dyes, to toners, etc. Congrats, this is stupendous.
_________________ Vincent
Top |
Kidd
Post subject: Re: 12S267 Posted: Feb Sat 03, 2018 5:25 pm |
Radiopicker
I agree Larry got the color just right.
Kidd
Top |
ktewell
Post subject: Re: 12S267 Posted: Feb Sun 04, 2018 9:51 pm |
Member |
Joined: Apr Thu 18, 2013 2:43 am Posts: 992 Location: Cincinnati, Ohio
Wow....
_________________ Kevin....
Top |
Donald Cochrane
Post subject: Re: 12S267 Posted: Feb Mon 05, 2018 4:23 am |
Joined: Oct Tue 28, 2008 3:15 pm Posts: 603 Location: Front Royal, VA
Absolutely stunning.
_________________ The second mouse got the cheese....
Top |
radioterry
Post subject: Re: 12S267 Posted: Feb Thu 08, 2018 6:11 pm |
Member |
LarryAD wrote: Finally received the toning lacquer I ordered and today the weather warmed up enough for me to open the shop door and finish the cabinet. I prefer spraying with natural light. I also cleaned up the bezel and sprayed and installed it. Tomorrow's plan is the install the speaker grill cloth. The bottom edge of the speaker board needed a little glue, waiting on it to dry. I replaced the right top corner of the Australian walnut veneer, a portion was missing and it was cracked badly, the rest of the Australian walnut was good. The cabinet shine will back off a little after all of the solvents leave the lacquer.
The chassis is ready to apply power. I have rewound the speaker field, received a new cone and am waiting on a voice coil delivery. Larry: The cabinet looks terrific! BR, Terry
Top |
Meatloaf Lover
Post subject: Re: 12S267 Posted: Feb Fri 16, 2018 8:00 pm |
I have never nick named any radio before, but if I was the owner of this set I would - and call it LAZARUS
Amazing work!
Top |
Who is online |
Users browsing this forum: Exabot [Bot], Google Adsense [Bot], High Tension and 12 guests |
