Author |
Crist Rigotti
Post subject: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 1:19 am |
Joined: Jan Sun 18, 2015 5:01 am Posts: 1326 Location: Waxahachie Texas
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 1:21 am |
Top |
Crist Rigotti
The metal chassis has the usual plating dust all over it. Everything steel has it. A quick trip to the quarter car wash and most of it is cleaned away. Though the metal will have to be scrubbed clean.
Attachments: |
_________________ Crist
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 1:22 am |
The chassis looks like it was made from galvanized steel. It appears that something has "run" on the surface of the chassis. This makes me think it's from the galvanizing process.
Attachments: |
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 1:23 am |
Now the one bit of bad news. When I got this tv I did a quick check on the CRT. It checked real good! Problem was is that the 10BP4 CRT is gassy. Yup, there is a purplish glow around the inside diameter of the tube. BTW, this tube is a rebuild. I have several 10BP4's that checked good from "donor" tv's.
Top |
Eric H
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 4:17 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 10273 Location: Redlands CA
The purple glow may not be gas, if it glows on the inner surface of the glass it could be normal, same way a output tube will sometimes glow under a load, try it in a working chassis before condemning it.
Top |
irob2345
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 4:36 am |
Joined: May Sun 07, 2017 11:35 am Posts: 470 Location: Belrose, NSW, Australia
I agree. You may just have the ion trap out of adjustment or missing, (if it has one).
Gas is usually a distinctive purple glow that's around the gun elements more than on the glass. A purply-blue color can be fluorescence on the glass, actually can be a good sign!
What does the getter flash look like? Metallic-looking all over, usually a good sign. Dirty-looking grey - brown, bad sign. Cloudy at the fringes, may still be OK, but has had a little gas the getter has removed.
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 5:54 am |
Eric H wrote: The purple glow may not be gas, if it glows on the inner surface of the glass it could be normal, same way a output tube will sometimes glow under a load, try it in a working chassis before condemning it. IIRC, the white tubes were also glowing purple. Here is a close up.
Attachments: |
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 5:57 am |
irob2345 wrote: I agree. You may just have the ion trap out of adjustment or missing, (if it has one).
What does the getter flash look like? Metallic-looking all over, usually a good sign. Dirty-looking grey - brown, bad sign. Cloudy at the fringes, may still be OK, but has had a little gas the getter has removed. The purple glow was also on those white tubes. The getter looked good. The cut-off worked well but the meter on my BK 467 CRT tester was pegged all the way to the right. A sign that the tube is gassy. When I have the TV up and running, I'll see what it is really like then.
Top |
irob2345
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 8:07 am |
Purple glow on the white insulators is very bad.
Tester pegs - gas is ionizing. Also bad.
I'd say that whatever has happened, it's happened recently and the getter hasn't had time to react with the gas.
Probably a crack somewhere....
Start looking for another tube.
Top |
bandersen
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 4:02 pm |
Member |
Joined: May Fri 29, 2009 4:35 am Posts: 2079 Location: Chicago, IL USA
Crist Rigotti wrote: irob2345 wrote: The purple glow was also on those white tubes. The getter looked good. The cut-off worked well but the meter on my BK 467 CRT tester was pegged all the way to the right. A sign that the tube is gassy. When I have the TV up and running, I'll see what it is really like then. You say the meter is pegged, but cut-off worked well ? I'm not that familiar with the 467, but my experience has been that the cutoff control will not do anything if the CRT is gassy.
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 4:23 pm |
bandersen wrote: Crist Rigotti wrote: irob2345 wrote: The purple glow was also on those white tubes. The getter looked good. The cut-off worked well but the meter on my BK 467 CRT tester was pegged all the way to the right. A sign that the tube is gassy. When I have the TV up and running, I'll see what it is really like then. You say the meter is pegged, but cut-off worked well ? I'm not that familiar with the 467, but my experience has been that the cutoff control will not do anything if the CRT is gassy. Yeah, the cutoff worked great. There is definitely a purple glow especially when the ION trap magnets are moved over the area. It gets a lot brighter. I wish I could post a good video of it. The getter looks pretty good too. The base is loose so I'm wondering is an indication of where the leak started near the wires as they exit the tube. Though I've had other bases loose and tubes that weren't gassy. We'll see in a week or so when I fire this thing up.
Top |
Eric H
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Wed 24, 2018 5:52 pm |
Member |
There are some tubes that have phosphors in the neck that glow to help adjust the trap, I think Phil Nelson has one? I remeber it being green but I guess it could be purple also.
One thing's for sure, either you have a paperweight or a really good tube.
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 1:46 am |
Eric H wrote: There are some tubes that have phosphors in the neck that glow to help adjust the trap, I think Phil Nelson has one? I remeber it being green but I guess it could be purple also.
One thing's for sure, either you have a paperweight or a really good tube. Yeah, you're right! We'll see.
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 1:47 am |
I used a 1/2 inch square piece of hard maple to make a "stand" while I work on the underneath part of the chassis. I removed the tuning scales to keep them safe. I then tape some folded over paper towels to the top of the power transformer and to the top of the HV cage to protest them while inverted. I used an existing hole in the chassis and bolted on a small cross-member so the stand will stay in place. Much easier to work on when it is this way.
Attachments: |
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 1:58 am |
I also use some spacers that I make up so I can grab the chassis when upright.
These spacers are 1" x 1/2" with a 3/16 hole down the middle. I then use a 5/16 drill bit and counter bore a hole about 1/4 deep. Then I round the "bottom" corner to prevent it from digging into my bench top.
For the hardware I use some #10 (3/16) x 1 1/2 long countersink head 10-24 bolts. I also use some 10-24 nylon lock nuts. Using my disc sander I reduce the head diameter so it'll fit into the counter bored hole.
Then the spacer is bolted to the chassis. Works great and I can grab and lift the chassis much easier. Been doing this type of thing for awhile now. Works great!
Attachments: |
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 2:36 am |
As my usual practice, I labeled all the tubes, resistors, capacitors, coils, inductors, and transformers according to the Sams docs. I also label all the terminal strips.
There was only 1 resistor that was in the chassis that wasn't covered in the Sams. See if you can spot it in picture #2. I also found a mistake with the value with C56. Sams has it listed as a .002uf while it should be a .003uf which was installed and Riders has it listed as a .003uf.
Now I'm ready to start re-stuffing the E-Caps.
Attachments: |
Top |
Crist Rigotti
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 2:51 am |
Top |
Notimetolooz
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 3:38 am |
Joined: May Thu 14, 2015 4:15 pm Posts: 1276 Location: Dallas, TX
Nice work spotting those C26, C35 gimmicks! I don't think I've ever seen any like that.
_________________ Tim It's not the Destination, It's the Journey.
Top |
philsoldradios
Post subject: Re: Crosley 9-403M Restoration Posted: Jan Fri 26, 2018 5:31 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5374 Location: Woodinville, WA USA
Eric H wrote: There are some tubes that have phosphors in the neck that glow to help adjust the trap, I think Phil Nelson has one? I remember it being green but I guess it could be purple also. My Hoffman 7M112 TV had a Rauland CRT with a patch of green phosphor in the neck to aid in adjusting the ion trap magnet: https://antiqueradio.org/Hoffman7M112Te ... #GreenGlowThose are the biggest gimmick capacitors I've ever seen. I'd leave 'em alone -- they are just wires -- and avoid bending them into new shapes. Phil Nelson Phil's Old Radios https://antiqueradio.org/index.html
Top |
Who is online |
Users browsing this forum: WeekendHacker and 0 guests |
