It is currently Feb Fri 22, 2019 10:18 pm
 Post subject: Help with EV-96 Cartridge Wiring
PostPosted: Jan Thu 25, 2018 9:13 pm
Can someone please double check my wiring to the EV-96 cartridge in my 1958 Admiral record player? There are 3 wires. Red, white, and black. I used yellow for white in the illustration below. The black wire has a jumper to another pin. I believe that to be the ground for each channel. Does it matter if the red/black or white /black are reversed? The pins are numbered 1 thru 4 as shown. Thanks
Cliff Fitch
 Post subject: Re: Help with EV-96 Cartridge Wiring
PostPosted: Jan Thu 25, 2018 10:49 pm
http://www.shure.com/americas/support/find-an-answer/color-code-for-phono-cartridge-wiring
This should help as its a standard color coding method.
the standard color is red for the right channel. Yellow for Left. you can swap those two around if they are not correct.
Visit our Webpage:
PostPosted: Jan Fri 26, 2018 12:14 am
Thank you!
Cliff Fitch
Post New Topic Post Reply  [ 3 posts ]  Moderator: Alan Voorhees
