Page 1 of 1
[ 12 posts ] |
Author |
stevebyan
Post subject: Round table with Philco Transitone, SE MA CL Posted: Jan Mon 29, 2018 5:18 am |
Member |
Joined: May Wed 18, 2011 2:40 am Posts: 3702 Location: Littleton, MA
Top |
Indiana Radios
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Jan Mon 29, 2018 2:16 pm |
Member |
Joined: Sep Thu 14, 2006 3:27 pm Posts: 11624 Location: Carmel, Indiana
Top |
stevebyan
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Jan Mon 29, 2018 5:22 pm |
Member |
Top |
doc612
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Jan Mon 29, 2018 9:08 pm |
Joined: Feb Sat 28, 2015 10:50 pm Posts: 511 Location: Decatur Alabama
I have almost the exact table but it has a Brunswick radio in it.
Top |
ptc42@juno.com
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Thu 01, 2018 7:52 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 229 Location: Fitchburg Ma. USA
Hello Would anybody know how to take this radio apart to get at the chassis? Thank You paul
Top |
Indiana Radios
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Fri 02, 2018 12:10 am |
Member |
I would think that there should be some screws on the bottom side of the table that, if you unscrewed them, the bottom should disassemble and access to the radio will be possible.
_________________ Michael Feldt
www.indianaradios.com
Top |
doug-5er
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Fri 02, 2018 1:02 am |
Joined: Apr Mon 09, 2012 2:55 am Posts: 2437 Location: Lakewood,SoCal- 90713
Had a table set a few years ago,here are some pics, the top was removable. Attachment:
_________________ Doug
***"Your best teacher is your last mistake"***
Top |
ptc42@juno.com
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Fri 02, 2018 2:12 am |
Hello We removed the screws and the top will not come off. We can see a pin in the center spindle and was wondering if that had to be removed to disassemble the top. But the pin does not go through all the way (so you could tap it out) and it is solid with no threaded hole so you could put a pin puller on it to pull it out. Very confusing paul
Top |
doug-5er
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Fri 02, 2018 2:41 am |
Just a thought Paul,the table could have been refinished and is glued to the base w/ lacquer or ?? Can you see the underside of the top,through holes on bottom. I wouldn't think the top would unscrew by turning counter clockwise,but you never know.
Top |
ptc42@juno.com
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Fri 02, 2018 2:45 am |
Hello There are no holes on the bottom. The radio in the picture with the holes is a different model. The radio is in original condition. There is no sign of refinishing. paul
Top |
ptc42@juno.com
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Fri 02, 2018 7:58 pm |
Hello. I figured it out. There were two screws underneath the table that held the chassis and part of the frame of the table. Took them out and the frame and chassis came right out. Thanks to all.paul
Top |
stevebyan
Post subject: Re: Round table with Philco Transitone, SE MA CL Posted: Feb Sat 03, 2018 4:32 pm |
Member |
Top |
Users browsing this forum: No registered users and 8 guests |
