It is currently Feb Thu 21, 2019 11:45 am
 Post subject: Round table with Philco Transitone, SE MA CL
PostPosted: Jan Mon 29, 2018 5:18 am
Is this a Frankenradio?
https://worcester.craigslist.org/ele/d/ ... 25810.html
 Post subject: Re: Round table with Philco Transitone, SE MA CL
PostPosted: Jan Mon 29, 2018 2:16 pm
I think this table (below) was made by the same company. Same chassis and same speaker grill.
http://www.antiqueradio.com/Jul05_Schneider_Sligh.html
Michael Feldt
www.indianaradios.com
PostPosted: Jan Mon 29, 2018 5:22 pm
Cool, thanks for the link.
PostPosted: Jan Mon 29, 2018 9:08 pm
I have almost the exact table but it has a Brunswick radio in it.
PostPosted: Feb Thu 01, 2018 7:52 pm
Hello Would anybody know how to take this radio apart to get at the chassis? Thank You paul
PostPosted: Feb Fri 02, 2018 12:10 am
I would think that there should be some screws on the bottom side of the table that, if you unscrewed them, the bottom should disassemble and access to the radio will be possible.
Michael Feldt
PostPosted: Feb Fri 02, 2018 1:02 am
Had a table set a few years ago,here are some pics, the top was removable.
Doug
***"Your best teacher is your last mistake"***
PostPosted: Feb Fri 02, 2018 2:12 am
Hello We removed the screws and the top will not come off. We can see a pin in the center spindle and was wondering if that had to be removed to disassemble the top. But the pin does not go through all the way (so you could tap it out) and it is solid with no threaded hole so you could put a pin puller on it to pull it out. Very confusing paul
PostPosted: Feb Fri 02, 2018 2:41 am
Just a thought Paul,the table could have been refinished and is glued to the base w/ lacquer or ??
Can you see the underside of the top,through holes on bottom. I wouldn't think the top would unscrew by turning counter clockwise,but you never know. :wink:
Doug
PostPosted: Feb Fri 02, 2018 2:45 am
Hello There are no holes on the bottom. The radio in the picture with the holes is a different model. The radio is in original condition. There is no sign of refinishing. paul
PostPosted: Feb Fri 02, 2018 7:58 pm
Hello. I figured it out. There were two screws underneath the table that held the chassis and part of the frame of the table. Took them out and the frame and chassis came right out. Thanks to all.paul
PostPosted: Feb Sat 03, 2018 4:32 pm
I’m glad it found a good home.
Post New Topic Post Reply  [ 12 posts ]  Moderator: Lou deGonzague
