It is currently Feb Wed 20, 2019 1:39 am
 Post subject: Silvertone 6120 Eye Tube
PostPosted: Feb Thu 08, 2018 3:10 pm
I am using a 6E5 which is more sensitive than the 6U5. How do I reduce the sensitivity. Currently it overlaps on most signals.
http://www.nostalgiaair.org/pagesbymode ... 017377.pdf
Thank you,
Dale
http://www.dalesantiqueradio.com/
 Post subject: Re: Silvertone 6120 Eye Tube
PostPosted: Feb Thu 08, 2018 3:21 pm
Dale
Reduce voltage going to pin #3, grid. Add a large value resistor in series with wire going to this pin. Connect another large value resistor from pin #3 to cathode, pin #5. This makes a voltage divider. I would start with 4.7 or 10 meg resistors. Using much lower values will load down the AVC line.
PostPosted: Feb Thu 08, 2018 10:50 pm
Thanks Norm. I checked and found the sensitivity of the 6U5 to be 1/3 of the 6E5, so I used 4.7M to ground and 10M in series with pin3 resulting in a 30% voltage divider. Results are perfect.
Dale
Post New Topic Post Reply  [ 3 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Chris in TC, jbees, Joezenithman, Leigh, lorenz200w, processhead, Tom Albrecht and 6 guests
