It is currently Feb Sun 17, 2019 2:26 am
 Post subject: How to wire this variac?
PostPosted: Feb Sun 18, 2018 10:31 pm
I purchased this variac and do not know what tabs to hook up wires to. Could someone help this dummy? :)
 Post subject: Re: How to wire this variac?
PostPosted: Feb Sun 18, 2018 10:36 pm
The input line connects to 2 and 4.
The output line connects to 2 and 3 or 3 and 4 depending on direction of rotation. With either connection, terminal 3 is the "high" side of the output, with the other being the "low" side.
The other two connections provide voltage boost, also depending on rotation;
Install a fuse on the output high side at the rated current. Because of the way Variacs work, it's possible to draw too much current at low output voltage even with input current less than max.
PostPosted: Feb Sun 18, 2018 10:37 pm
2 to neutral, 3 output, 4 hot. 2 and 3 are output
PostPosted: Feb Sun 18, 2018 10:42 pm
If you want 0-140V like most variacs:
input to 2 and 5
output to 2 and 3
2 is common neutral.
Scott.
PostPosted: Feb Sun 18, 2018 10:48 pm
Thank you for such fast replies!
PostPosted: Feb Sun 18, 2018 10:49 pm
140 volts could be dangerous if working on radios designed for 110 or 112 volts.
PostPosted: Feb Mon 19, 2018 12:03 am
So don't turn it up to 11. ;)
I use it with a dimbulb setup to account for the drop in voltage. That way i can still have near 110V but still keep the protection.
The Hallicrafters I'm working on will not work with the 60W bulb on the dim-bulb setup. It drops to about 75V. I could go out and buy a 100W bulb but easier to just crank it up a to 90V with the variac on 130..
Scott.
PostPosted: Feb Mon 19, 2018 1:19 am
Here's what I used to hook up mine.
PostPosted: Feb Mon 19, 2018 2:29 am
No radio is intended to work properly on a DBT.
DBTs are not designed to power a working radio.
They're designed to find short circuits and similar wiring faults.
Once they pass that test, replace the bulb with a screw-in fuse and run the set at proper voltage.
You should never run any set on reduced line voltage.
Doing so will tell you nothing, and could damage the set.
PostPosted: Feb Mon 19, 2018 4:11 am
Is that a dial ring that I see touching your thumb? If so, does it have a voltage scale on it with a pointer on the knob? If the scale goes up over line voltage, you may want to hook it up with the boost connection to make the dial somewhat track. Or, if it only goes to the line voltage, then the non boost connections.
PostPosted: Feb Mon 19, 2018 6:02 am
Greetings to the Forum:
To amplify on J. Hill's comment, many of those dial rings were printed on both sides. One side was calibrated for 0 to 100% line voltage and the other for 0 to 117% (or 130 volts). You mounted the dial scale so that the correct calibration for the intended use was showing.
Jim T.
KB6GM
PostPosted: Feb Mon 19, 2018 9:31 pm
Yes this indeed does have a double sided scale. It works great now!
PostPosted: Feb Tue 20, 2018 1:39 pm
If I am building a variac or powerstat project that may have a use for the higher output voltage, I will include a DPST switch to apply the AC input to either the terminal that produces line in = max volts out, or to the terminal that produces ~140 volts out. The second pole of the DPST switch powers a prominent looking pilot light when the higher voltage position is selected.
I also like the types without the extra taps. Nothing extra to be concerned about...
PostPosted: Feb Tue 20, 2018 4:53 pm
One problem we have on ARF is we know absolutely nothing about the technical background or abilities of new members other than what they tell us.
I will always err on the side of safety in any response I post. Even if it's not needed by the OP, it may yet be useful to others who read the thread or find it in the archives.
PostPosted: Feb Tue 20, 2018 6:08 pm
Member "comm-nav" wrote above (w/ pictures) about mod's to make a SuperiorPowerstat-brand (or most GenRadVariac) variac ranges switchable. Am writing to inform that this feature is already standard with many models of the STACO branded variacs, and some of the FisherBrand (beige/tan case painted, before Thermo-Fisher) 1960's-80's models spec'd by Fisher, built by Superior company. So if you buy the STACO or older FisherBrand, then you don't have to make this mod, it's already there. Fred
