It is currently Sep Tue 25, 2018 2:02 am
 Post subject: The Wonderful Ranger Clamper
PostPosted: Feb Thu 22, 2018 6:16 pm
OK I'm back but this time confused about a Ranger clamper.
It's the early version with no keyer, however, a PTT relay has been installed properly per the manual.
Drive to the final and the final itself all tunes properly when I key the mic in phone position. However. when I unkey and leave the function switch in Phone position the plate current pegs.
It seems like an obvious clamper problem so I did the clamper test by removing drive (switching to an unused crystal). The clamper reduces the plate current (actually clamper current I know) properly to about 50 ma in the CW mode, but has no effect in AM mode because the plate current stays pegged. Or, as soon as I release the PTT the plate meter pegs in the AM mode.
For the life of me I can't see why the clamper works in the undriven CW mode but not the AM mode. Can anyone enlighten me?
Thanks in advance.
Rick
W5RAA
 Post subject: Re: The Wonderful Ranger Clamper
PostPosted: Feb Thu 22, 2018 6:56 pm
Rick,
Check you PTT switch wiring. The feed to the final screen should be grounded with the relay in standby position (look at terminal 6 SW4A connection) and the clamper circuit is not involved in controlling the plate current in standby, it is only designed to operate in transmit mode with loss of excitation.
PostPosted: Feb Fri 23, 2018 1:52 am
Well...I tried to check the relay wiring, but picture this! Somebody did a very nice job of rewiring this Ranger WITH ALL WHITE WIRES!
So, that mass of white wires coming out of the bottom of the function is a bit overwhelming...I'll save this one for another day.
PostPosted: Feb Fri 23, 2018 7:59 am
That must have been the same guy who built a Russian HF CW transceiver I was reverse engineering once, about a century ago. All the wiring was red wire, and I mean all of it. :(
WB6NVH
http://www.wb6nvh.com
PostPosted: Feb Fri 23, 2018 1:26 pm
I have a Telefunken E-1501 receiver that is constructed with the different receiver sections on cards. The interconnecting data/control lines (factory wired) are all white and look like a mass of spaghetti shoved in behind the front panel of the receiver. Mine also has an after-market board to add memory and it replaces the RTTY tuning display; at least that one uses different colored wire.
Post New Topic Post Reply  [ 5 posts ]  Moderator: Sandy
