It is currently Jan Wed 24, 2018 5:03 am
Post New Topic Post Reply  [ 60 posts ]  Go to page 1, 2, 3  Next
 Post subject: Norm's 12K5 Regen
PostPosted: Dec Thu 13, 2007 3:34 am
I got Norms schematic today so I thought I'd post it.
PostPosted: Dec Fri 14, 2007 3:56 am
Hi Norm
What size coil form do you recommend???
I have 100/25 turn coils I wound for a 6BM8 xmitter, I'll prob start by removing 23 turns... :lol: I hate windin'... Also have a 12K5, ought to be a "piece O cake" to build... Me getting it to operate, now that's a different story...
PostPosted: Dec Fri 14, 2007 5:04 am
Hi Tom
Any coil made for the broadcast band will work. Just add a couple turns for the tickler. I wouldn't remove your 25 turn coil. You might want to use it for antenna and ground input?
Won't have a problem if you are familar with regen radios. If not familar will take a few minutes tuning.
Suggest using a very low value pot for R1. The type used as speaker fader control in car radios will be ok.
PostPosted: Dec Fri 14, 2007 5:20 am
OK Norm
I've come up with a fairly different form anyway, so I'm going to wind... The 12K5 tests good, I'm on the way...
Hopefully I can make it work, I wanna take pictures... :mrgreen:
PostPosted: Dec Fri 14, 2007 5:52 am
Tom,
Looking forward to pictures.
Norm,
Whats the purpose of the .022 speaker cap in this circuit?
Kevin
PostPosted: Dec Fri 14, 2007 6:43 am
the .022 ufd cap by-passes the RF sig to ground ( b+) while the audio sig is passed by the transformer to the next stage.
RCW
A man learns very little if he speaks only to himself
PostPosted: Mar Sat 07, 2009 4:22 am
A couple questions:
At what voltages should the caps be rated at?
Wattage for the resistor?
Could I use a different coil to receive SW?
-Shane-
PostPosted: Mar Sat 07, 2009 10:51 pm
A couple questions:
Since it uses a 12 V supply, 16 V or 25 V caps should be fine.
The resistor doesn't dissipate any power so a 1/4 W or 1/2W is fine; whatever you have handy.
Yes. You would need fewer turns, of course. You might try about 40 turns with a 6 to 6 turn tickler coil. Experiment! That's where the fun comes in!
PostPosted: Mar Sun 08, 2009 9:15 pm
Thanks Rich!
PostPosted: Mar Sun 08, 2009 9:21 pm
Sorry, I meant to write "6 to 8 " turns for the tickler winding.
PostPosted: Mar Mon 09, 2009 2:47 am
I would like to build this radio using a variable tickler instead of the reostat. I am having trouble finding a 12K5 tube though. It seems to be a bit scarce.
PostPosted: Mar Mon 09, 2009 3:56 am
I got mine off of ebay, Probably paid too much but oh well. There were like 4-5 on there the other day. The one I bought was $10 incl. shipping.
Good luck.
-Shane-
PostPosted: Mar Mon 09, 2009 4:23 am
Radio Daze and likely the other suppliers have 12K5s for $3...
PostPosted: Mar Mon 09, 2009 4:34 am
I went to Tubes And More and they didn't have them so I immediately turned to ebay, Forgot about Radio Daze.....DOH!
On another note I was thinking of making both BC and SW coils complete with their own ticklers for this, and then wiring them in so I can just flip a switch/s depending on which band I want. Based on Rich's earlier post I should be able to do this w/ o mods to the rest of the circuit right?
-Shane-
PostPosted: Mar Sat 21, 2009 3:46 am
Do you wind the tickler around the broadcast coil or above?
PostPosted: Mar Sat 21, 2009 4:05 am
The tickler/feedback winding can be separated from the main coil by about 1/8" if you're winding it on a standard plug-in coil form. In practice, it can be wound right around the main coil... Although 6-8 turns will suffice, anything in the area of 10-45 turns will work as the setting of the regen control will control the feedback.
Dave - WA6VVL
PostPosted: Mar Sat 21, 2009 4:16 am
Hi
Like mentioned tickler can be wound close to the tuning coil. With this tube tickler only needs a turn or two. I wrote two turns but found even 1 was enough when I built the circuit.
PostPosted: Mar Sat 21, 2009 4:32 am
Here's a pict of the one I built, you can see the tickler coil waving in the breeze...
PostPosted: Mar Sat 21, 2009 7:46 pm
Could I use the audio transformer from my junk Westinghouse WR-179(5 tube AMer)? It looks the same as the one pictured but I don't know the specs.
PostPosted: Mar Sat 21, 2009 8:25 pm
That was the 1st transformer I tried from a battery portable, wasn't very happy with it or one from a AA5...
Read through my posts in this thread, where I talk about the transformers I tried...
Comments just after the picture and scope waveforms have the most info on transformers...
Users browsing this forum: Gip-Gip, richfair and 5 guests
