Antique Radio Forums :: View topic - DuMont "doghouse" troubles.
Forums :: Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives :: Books :: Value Guide :: Wiki  Support This Site: Contributors
Radio Showroom
 Forum Rules/FAQ   Posting Photos   Search     Register   Profile   Log in to check your private messages   Log in
DuMont "doghouse" troubles. Goto page 1, 2  Next
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Antique Television Discussions
View previous topic :: View next topic
Kyle Steck
Posted: Oct Thu 22, 2009 3:44 am  Reply with quote
Hello again, I am just updating the topic of my DuMont television restoration.
I am having the set serviced by someone else. I have replaced ALL of the wax old paper caps and filters and even the flyback transformer. He had gotten the set to work for 10 minutes, he was actually watching it! But, then after that 10 minutes the picture disappeared and there is now a one inch wide vertical line that spans the tube. We are both stumped, everything measures correctly, all resistance measurements are in range, just no picture. What could be causing this? We also replaced that resistor that is known to go bad in the HV cage. Still nothing. Any help is appreciated!
View user's profile Send private message Send e-mail AIM Address
Tom Albrecht
Posted: Oct Fri 23, 2009 5:58 am  Reply with quote
Kyle,
You may have a problem in the horizontal coils of the deflection yoke or the windings on the flyback transformer that drive the yoke. Check the wiring to the yoke. Substituting a different yoke may also be a useful check. Check the horizontal width and linearity coils and the wiring to them.
Also, check the voltages in the horizontal output and damper stages to see if everything is where it should be.
If you have a scope, check the frequency of the horizontal oscillator. If this is not running at the right frequency, check the components in the horizontal oscillator.
Good luck!
Tom K6VL
View user's profile Send private message Send e-mail Visit poster's website
Kyle Steck
Posted: Nov Mon 02, 2009 5:19 am  Reply with quote
The damn thing works!
Apparently the new old stock flyback I put in, blew out, meaning the windings shorted. Fortunately the old flyback is good and is working in the set! The only problem it has now is that the middle of the picture is pulling to the left horizontally. So whatever is on the screen is stretched. What could be causing this?
Thank you for the help!
Tom Albrecht
Posted: Nov Mon 02, 2009 6:22 am  Reply with quote
You've got three adjustments on this set to work with:
1. width
2. horizontal centering
3. horizontal linearity
Width and centering are self-explanatory.
Linearity is the adjustment that can be used to even out any tendency to stretch on one side while compressing on the other.
First try the width and centering controls, and make sure they have the intended effect. Then try the same with linearity. Linearity can be tricky to adjust unless you have a test pattern with a grid pattern. In the absence of that, lettering on the screen in commercials and movie credits can work. If you have a DVD player, bring up a suitable picture and pause there while you make adjustments.
If you find that the adjustments don't work, check the wiring of the width and linearity coils, and the components directly around them. Also make sure you have a good damper tube and horizontal output tube.
Tom K6VL
Kyle Steck
Posted: Nov Thu 05, 2009 4:14 am  Reply with quote
After running the TV and making a few adjustments, it's looking pretty excellent! Only one more thing. There seems to be some kind of shadow effect going across the screen if the imagine on the screen scrolls, like the camera moves. What could be causing this problem?
Tom Albrecht
Posted: Nov Thu 05, 2009 4:53 am  Reply with quote
Hi Kyle,
Not quite sure what you're describing, but let me make a guess: You've got a "wave" that moves slowly through the picture from bottom to top.
If that's what it is, it's 60 Hz or 120 Hz in the power supply due to a bad electrolytic filter capacitor somewhere in the power supply.
Another possibility is interference from a nearby DTV converter or cable box.
Or you may be seeing something entirely different. Try to give us a little more detailed description of what you're seeing.
Tom K6VL
Tom Schulz
Posted: Nov Thu 05, 2009 6:47 am  Reply with quote
I have seen an effect where the picture is darker than it should be immediately the the right of something bright. It is most noticeable when there is white lettering scrolling up the screen. That can be caused by a capacitor in the video circuit that is too small. A bad electrolytic can be way small but not quite gone. It is also possible to replace a capacitor with the wrong value. Getting one that is 1/10 th of the correct value is easy to do and easy to not see.
hoffies2
Posted: Nov Thu 05, 2009 1:48 pm  Reply with quote
The person that doing the servicing should be of help? You have a phasing problem that can be caused by outside interference, among other things suggested above. Smile
You may never get these old TV's 100%.
philsoldradios
Posted: Nov Thu 05, 2009 7:39 pm  Reply with quote
What are you using as a video source?
I'm currently finishing up a DuMont RA-103. A set without AGC responds differently to some signals than one which has AGC.
If you can give a more detailed description, perhaps others can help tell whether you have a problem, or you're seeing some momentary effect that's normal for this kind of set.
Phil
View user's profile Send private message Visit poster's website
Kyle Steck
Posted: Nov Sat 07, 2009 4:13 am  Reply with quote
Will a 12LP4 work in this set?
Mr. Detrola
Posted: Nov Sat 07, 2009 4:21 am  Reply with quote
Yes, you have to change the HV connector to the correct type and adjust mounting hardware/yoke position so the tube is physically in the right place.
Kyle Steck
Posted: Nov Sat 07, 2009 4:23 am  Reply with quote
How much is a working 12JP4 worth with an ion burn?
Tom Albrecht
Posted: Nov Sat 07, 2009 6:35 am  Reply with quote
Hi Kyle,
Are you sure that you need a new CRT? Not quite clear what effect you are seeing from the above description.
I'm not sure what a 12JP4 would go for, but if the ion burn isn't bad, and the tube is nice and bright, I could imagine $50-$100. One with no defects would go higher.
Tom K6VL
Eric H
Posted: Nov Sat 07, 2009 10:40 am  Reply with quote
It's longer to accommodate the Ion trap so the back may not fit without cutting a hole in it.
On the sets I've seen with the burn it was hardly noticeable when watching a program, it only really shows up on a blank screen.
http://www.youtube.com/user/Vintagetvs
Bill Cahill
Posted: Nov Sat 07, 2009 3:36 pm  Reply with quote
Dumonts used a straight back, and, will have no problem accommodating an ion trap.
Bill Cahill
Please visit my forums:
http://tuberadio.heavenforum.com/forum.htm
My friend Mike
Kyle Steck
Posted: Nov Sun 08, 2009 2:22 am  Reply with quote
Oh I don't need a knew one, I was just curious as to what would replace a 12JP4 due to the fact that they cannot be rebuilt. My 12JP4 is good, but I would like to use my set very often...
Kyle Steck
Posted: Nov Thu 19, 2009 5:04 pm  Reply with quote
Does anybody know what the knob says for the selector? I am having labels made for when I restore the cabinet. My label for that switch is worn off. All I can read is "phono" "FM" and then the rest is worn off. Can someone please let me know what the other two setting abreviations are?
Thank you, Kyle
philsoldradios
Posted: Nov Thu 19, 2009 9:10 pm  Reply with quote
Here are some of the decals on my Meadowbrook RA-103 cabinet.
Let me know if you make a decal set. My cabinet has serious problems (not seen here) that will require a total refinish.
http://antiqueradio.org/DuMontRA-103Television.htm
Did someone tell you a 12JP4 can't be rebuilt? The CRT in my set has a sticker from a rebuild shop labeled 12JP4. It also appears to use a different gun, requiring an ion trap. Go figure. Anyway, it's very bright, so I'm keeping it, whatever it is Smile
Kyle Steck
Posted: Nov Fri 20, 2009 5:56 pm  Reply with quote
I just added that set you own to my wish list Very Happy
The people I am having make my labels are having trouble peeling them from the rest of the sheet. They are being cut from gold vinyl. I already have the DuMont label cut and it is pretty darn close to the original.
rdusel
Posted: Nov Fri 20, 2009 8:06 pm  Reply with quote
Good Afternoon Gentlemen!
I'm also starting a rebuild of an RA103 doghouse and was looking for a 12JP4 as mine has lost it's vacuum. The filament is intact but the getters are white so I know what will happen when I power it up.
I was told that the 12JP4 can not be rebuilt because it is pyrex and there are no more pyrex necks available, just the regular glass necks.
Maybe they were available in the past?
I would also be interested in a label set if your supplier starts offering them.
Thanks guys!
Rob
Display posts from previous:
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Antique Television Discussions All times are GMT
Goto page 1, 2  Next
Page 1 of 2
You cannot post in this forum
Only registered users can edit or delete their posts in this forum
