| View previous topic :: View next topic |
| Author |
Ken G Member
Joined: 01 Jan 1970 Posts: 9799 Location: twin falls idaho
| Posted: Oct Thu 22, 2009 6:20 am |
Not sure if it's just me, but it doesn't seem like there are too many people really following this. It could just be me, because I'm not in too good oof a mood because of my living arrangements.
So does anyone really follow this thread, or am I posting to blind eyes?
Right after you insisted a roller would not work to spread glue i lost all interest in this . I really like what you are doing but that killed it for me . |
slammed87d21 Member
Joined: 09 Apr 2009 Posts: 1254 Location: Seymour, TN
| Posted: Oct Thu 22, 2009 7:31 am |
I don't remember if I had said it wouldn't work exactly, but if i did, I apologize. The reasoning behing recommending a brush over a roller, is one, a paint brush is cheap, two, less cleanup when you're finished, and three, for more than smaller items, the rollers gums up, and is useless. For this radio, a roller would have done fine, but I'm trying to restore this radio for the least amount possible, without sacrificing quality, so the brush goes with the theme of this restoration perfectly.
Sorry if a comment as such killed it for you. It's just personal opinion what works best. _________________ Andy
The Vintage Attic Forum
http://www.thevintageattic.net/forum/index.php
Come join!
All my classified listings are on my site too. |
glasdave Member
Joined: 24 Feb 2009 Posts: 997 Location: Aurora Colorado
| Posted: Oct Thu 22, 2009 8:51 am |
I'm still here,....was out of town for a bit, the brush vs. roller thing is kind of an interesting debate. To be valid, though, you would have to use the same tools, under like circumstances, it seems. The proof would then be self evident.
But, I like both ideas, and will try them for my next foray into wood working. David _________________ Stumbling through the hobby since 1967. |
amyotte Member
Joined: 02 Jun 2007 Posts: 765 Location: Ennismore, Ontario
| Posted: Oct Thu 22, 2009 9:34 am |
| Ken G wrote: | | Not sure if it's just me, but it doesn't seem like there are too many people really following this. |
I am enjoying this.
Brian _________________ I came into this world with nothing...
I have been able to keep most of it. |
Gassy Tube Member
Joined: 01 May 2009 Posts: 118 Location: Stratford, CT
| Posted: Oct Thu 22, 2009 12:36 pm |
Another lurker here. Keep up the good work! _________________ -Cameron
MichaelD Member
Joined: 06 Jun 2006 Posts: 359 Location: North Royalton, Ohio
| Posted: Oct Thu 22, 2009 4:48 pm |
| Ken G wrote: | | Right after you insisted a roller would not work to spread glue i lost all interest in this . I really like what you are doing but that killed it for me . |
Hmmm....yet strangely Ken is still here, commenting. Maybe he actually has brush envy and has become disenchanted with his foam roller. I wonder...
Me, I'm just lurking and picking up a ton of tips. I think we forget that you can't hear us or see us nodding in approval. Thanks for posting your work and helping a lot of us learn a thing or two!
MichaelD |
radiorich Member
Joined: 01 Jan 1970 Posts: 5604 Location: tacoma,wa,usa
| Posted: Oct Thu 22, 2009 11:28 pm |
Hello Andy,
to bad you did not live closer I get free shelving ,
and wood all the time that people are tossing on the job.
That equipment self would be a breeze to build.
Far as your set I've been following it Because see I've only refinished one wooden radio so far .
mainly I love redoing the insides guts the most.
Rich _________________
amptramp Member
| Posted: Oct Fri 23, 2009 12:24 am |
| I'm still here lurking, I just don't have any insights that I could contribute. |
slammed87d21 Member
| Posted: Oct Fri 23, 2009 1:21 am |
Got a little more done tonight, since I took a break yesterday. Did some stain work, and a little more. Got a sneak peak of what it's going to look like coming up later. But first, got to watch Fringe.  _________________ Andy
Come join!
slammed87d21 Member
| Posted: Oct Fri 23, 2009 5:43 am |
Where oh where to begin...
Yesterday I stripped the sides and the grill. I used chemical stripper to help lighten the wood. It didn't help too much since I had already sanded, so most of the wood showed its natural color.
The way I do that is pouring on the stripper to the wood, and scrub it till my arm wants to go numb, then rinse. Nice and simple. The really strong stuff works best.
Anyway, today is staining. I usually use Minwax stains, but I thought I would try Ace brand since it's a dollar or so cheaper than the Minwax equivelent.
Starting with the grill since it's the more complicated piece of the three.
The way I stain, is to rub the stain onto the piece with a soft cotton rag, and then instantly wipe it off. That way i don't darken the wood too much.
You can always add stain, but you can't take it from the wood without starting over.
Anyway, here's the grill getting stained.
And here it is.
Next up is a little more work to the lower edge of the front, and the dial opening.
For the dial opening, it needs smoothed out a little.
And a little filler here.
I sanded a little bit around the edge to smooth it out, then went on the filler to build up the edge.
Alright. On to the sides.
I'm staining these the same way I did the grill. BTW, I rub the stain in with the grain. Seems to work better without darkening the wood more than you want.
I'm not sure where the pics went if me doing the top, front, and inside, but here it is stained.
Doesn't look too bad. May need to be what I call "spot stained". By that, I mean stain just the light areas to even their darkness to the already dark areas.
Well the wood putty on the dial openings edge is dry finally. After a little sanding...
The putty is still a little moist, so I use a razor knife in this situation.
Now that edge isn't too bad looking. Once it completely dries, I'll sand it perfectly smooth.
Time to stain the front/top. Same as before with the stain.
Since tht's finished, let's do the other side.
Looking good...
Since it's all stained now, here's how it's looking. All 3 pieces are close in color, so just a little more work with the stain. Maybe one more day if I'm lucky.
Well, the stain is still wet, but I thought I'd stick it together for a little sneak peak of what it will look like finished. But first, let's see where I started at.
Next...
How it looks now...
Almost looks new already. Still have a bit more to go though. Soon enough it will be done.  _________________ Andy
Come join!
calmark Member
Joined: 15 Sep 2006 Posts: 403 Location: Long Beach, CA.
| Posted: Oct Fri 23, 2009 1:14 pm |
Looks 1000% better, excellent work.
Mark |
Chuck McB Member
Joined: 23 Oct 2007 Posts: 1349 Location: Waverly, Alabama
| Posted: Oct Fri 23, 2009 1:32 pm |
| It really looks good & I can't wait to see it finished. |
badrestorer Member
| Posted: Oct Fri 23, 2009 2:26 pm |
Andy,
Quick...tune in a station on that bugger.
One comment: I've found that Minwax Pre-stain Treatment helps a great deal. It automatically evens out the color. Prevents blotching. Very easy to use. After brushing it on you have 2 hours to do your staining. Terrific stuff. Comes in a quart can from Lowes, Home Depot, etc. Once tried, you'll use it more and more. And it's pretty cheap. _________________ Regards,
They don't know the power of the radio side. |
slammed87d21 Member
| Posted: Oct Fri 23, 2009 4:27 pm |
| badrestorer wrote: | Andy,
One comment: I've found that Minwax Pre-stain Treatment helps a great deal. It automatically evens out the color. Prevents blotching. Very easy to use. After brushing it on you have 2 hours to do your staining. Terrific stuff. Comes in a quart can from Lowes, Home Depot, etc. Once tried, you'll use it more and more. And it's pretty cheap. |
I've seen that before, but always wondered about it. I may try it next time I do some staining.
Well, it's time to make the rounds for today, so I'll be back later. Got my rf gen in the mail so I may end up working all night.  _________________ Andy
Come join!
glasdave Member
| Posted: Oct Sat 24, 2009 7:17 am |
Good looking and a great color choice, Andy.  _________________ Stumbling through the hobby since 1967. |
Pbpix Member
Joined: 01 Jan 1970 Posts: 3442 Location: Haledon, NJ, usa
| Posted: Oct Sat 24, 2009 7:29 am |
| Ken G wrote: |
I'm anyone and I'm here too. Andy's doing a GREAT job with a wonderfully detailed and annotated thread that he's taken a great deal of time and effort to present for us!
Hey Ken.. how can you let such little stuff bother you?
Whatever is wrong with your living arrangements... can't be worse than some.. consider Charlie Manson's living arrangements... lol
... So breath easy buddy...lol
....Andy didn't call you "an Idaho roller-lover" or anything.. lol
.. he simply restated his reasons for why he prefers a brush over a roller.
Anyway just teasing... ya.
 _________________ Peter G. Balazsy
WB2eqt
www.pbpix.com/radio
"Whoso would be a MAN... must be a non-conformist ...for nothing is at last sacred as the integrity of your own mind."
... (Emerson)
radiorich Member
| Posted: Oct Sat 24, 2009 7:40 am |
Hello Andy,
it's looking good from this end
P.S. I used that preastain on A fir dresser that I had to refinish it worked nicely. _________________
slammed87d21 Member
| Posted: Oct Sat 24, 2009 7:43 am |
| glasdave wrote: | Good looking and a great color choice, Andy.  |
Thanks. I tend to second guess myself when choosing colors a lot. This time, I just scanned through colors, and picked the first one I could picture the radio stained with.
But seriously though. I had first thought about using a light walnut stain, but I got a piece of the old veneer and polished it up to show what the color originally was. Light walnut was way too light.
Tonight I did a little more staining. The sides match better now. Maybe a little more stain, and they should be good. Got to let them dry first.
If anyone wonders about my techniques I use, I learned them from many older gentlemen that have done this since they were young. The man who taught me staining was in his 70's nearly 7 years ago, and had done wood finishing since he was old enough to work. The only reason why I bring that up is because i prefer the older ways of doing things. For instance, the only power tool I have and use is a drill, and that's because I can't find a hand drill that's in good shape for a good price.
The older way of doing things isn't exactly the easiest way of doing anything, but I want to keep that way alive. Right now, I'm looking into how to hand cut veneer. Looks like a lot of trouble, but I would love to learn.
Anyway, I'm starting to ramble, so I'll finish up. I'll be doing a little more staining tomorrow night, along with working on the bottom board. Not much to do to it. Just sand it smooth(I wish I had a plane here) and put a little stain on it.
Hopefully before the weekend is over, I'll be able to paint the grooves and the edge of the dial opening so I can spray some lacquer next week before it gets cold again. _________________ Andy
Come join!
slammed87d21 Member
| Posted: Oct Sun 25, 2009 5:58 am |
Ok, well did some more staining tonight.
Here's what we did the other night, now dry.
Doing one last staining now.
The grill should match perfectly after it completely dries.
Like I said last time, the bottom needs a little work too. All it really needs is a little sanding and a bit of stain so it matches.
And now the back edge...
Now a light staining...
The bottom piece will only get one staining, since there is so much figuring. With much more than this, it would end up with black swirl marks.
I know it looks like black swirls now, but wait till they dry. They will end up a medium to dark brown.
Now that the staining is finished, the lip that goe into the sides is missing a little wood. Since it's hidden, I just used a little wood filler.
Well, that will be it for a couple days. Since I've used so much stain in such a little amount of time, I'm going to give it a couple days to dry completely. In the meantime, there's still plenty to do.
I have finally decided against using brown for the grooves and dial hole edge. The wood has too much of a red tint in it to match any brown I find or even mix. So black it is.
Well, since it will be a few days, I'm going to go ahead with the chassis.
Check it out here.
http://antiqueradios.com/forum ... 547#970547 _________________ Andy
Come join!
slammed87d21 Member
| Posted: Nov Sat 07, 2009 9:19 am |
Finally, I can update this thread!
Since it's to cold to do much right now, I got the cabinet glued together tonight. Gluing is simple enough, so I'll let the photo's speak for themselves.
Just want to point out in this pic the small pieces of wood wedged in. This is to keep the front/top pressed against the outer edge of the groove.
And lastly for tonight...
The tape you see is helping hold the bottom of the front to the front of the bottom. Very odd angle, and I only have one clamp that will work on that. I'm letting it sit till tomorrow night, so the glue won't let loose.
A little off topic, but I've been doing a good bit of research on glues for woodworking. That's why I've been away from the cabinet and chassis of this radio for a while.
From what I've read and figured out, I may be throwing out my carpenters glue and never buying any again.
I've been comparing carpenters glue like most people use to other glues like hide glue. Let me just say that I'm a believer of the old ways, because if something works effectively, why change it.
I'm going to try getting some true hide glue, and doing some tests of my own to compare it to carpenters glue. I guess you could call it aging tests.
Anyway, the next warm day, I will be spraying the lacquer on ths radio to get this cabinet finished finally. Hopefully in a day or 2 the edge around the dial and the grooves can get painted.
More to come... _________________ Andy
Come join!
You cannot post in this forum Only registered users can edit or delete their posts in this forum
