It is currently May Sat 26, 2018 8:33 pm
 Post subject: Paco B-12 Power Supply
PostPosted: Oct Sat 17, 2009 1:28 pm
Does anyone have any information on this power supply? I downloaded the schematic from bama. I need to know what the two calibration pots do and how to set them.
Tex
PostPosted: Oct Sat 17, 2009 11:31 pm
Maybe I can help; I own a B12.
I believe the control marked R16 (zero calibration) is for setting the power supply output to actual zero volts when R18 (regulated output) is at minimum. It is possible for these supplies to output a negative voltage when the control is at minimum.
The other control (R19, 400 volt calibration) is used to limit the upper range to 400 volts. I think the raw power supply voltage is something like 525 volts, and you don't want the output to be over 400.
PostPosted: Oct Sun 18, 2009 12:15 am
Thanks for the information Johnnysan. I kind of figured that. Maybe I can pick up a manual somewhere.
PostPosted: Nov Tue 17, 2009 2:50 am
I was just given one of these tonight by a member of the local ARC. It looks original under the chassis, so I'm sure it needs a re-cap job.
But at least it's decently clean. And since I like to homebrew, I'm sure I will get some use out of it after I have it up and going. I'm going to have to get a schematic and study it, I understand what the rectifier tubes do, and what the regulator tubes do, but why it has a pair of 6L6GC's I'm not so sure of.
PostPosted: Nov Tue 17, 2009 3:12 am
Oh, the complete manual is also on bama:
http://bama.edebris.com/manuals/paco/b-12/
(there were two files, one was just the schematic, this one was the whole manual)
PostPosted: Nov Tue 17, 2009 5:42 am
I acquired a nice clean one last year from an estate and it works great. I primarily use it in rejuvenating NOS filter caps.
Pat
PostPosted: Nov Tue 17, 2009 6:40 am
The 6L6 tubes are the are the outputs; they supply the B+ at 0 to 400 volts.
That's a nice supply; I used mine just last night.
Users browsing this forum: Leigh and 8 guests
