It is currently Apr Mon 23, 2018 1:57 pm
 Post subject: TV-7 D/U Shorts Testing Problem
PostPosted: Aug Tue 17, 2010 8:23 pm
I tested some 6BQ5 tubes on my TV-7 D/U and they ALL check shorted.
Shorts light glows in all positions except 4
Did the Shorts check in the Manual TM 11-6625-274-35
Chapter 3 Page 40-41
All test results are as expected with the 100K and 510K resistors.
I checked these tubes on a recently acquired Knight 600B and they have all 6BQ5 testing with 0 Emissions.
Looks like I have 2 faulty tube testers.
I also have a Jackson 103 , but no listing for the 6BQ5
I think I am being punished for selling off my Hickok 600A.
Has anyone else had this problem with the TV-7 D/U ???
Bob T.
PostPosted: Aug Tue 17, 2010 9:16 pm
Bob
Some time the routeing of the power cord will cause shorts on tubes that are checked in the 9 pin socket on A TV-7D/U after the unit is put back in the box.
Jimmie
Last edited by Jimmie Stewart on Aug Wed 18, 2010 3:52 am, edited 1 time in total.
PostPosted: Aug Tue 17, 2010 11:16 pm
Jimmie Stewart wrote:
Bob
My 6BQ5's test fine on my TV-7 D/U.
Jimmie
Not much room, there no choice but to route cord same as original.
I did put a new grounded Cord assembly on mine. But it is routed the exact same route as the original.
For sure I will take it apart and see if it makes any difference.
I almost threw 2 good 6BQ5's in the trash.
Found this old post ??????
http://www.antiqueradios.com/forums/vie ... 0837cb79e2
Bob T.
PostPosted: Aug Tue 17, 2010 11:51 pm
Pulled out the updated tube listings that Nolan Lee was so kind and wonderful to supply to the world
Surenuff It is Normal for what I am getting.
His listing for the 6BQ5
SHOWS SHORT ON 1-2-3 AND 5 Reference Air Force Supplement T.O. 33AA21-5-31G
Looks like I will be using Nolan"s settings all the time.
He is more accurate than what is in the TV-7 booklet
Bob T.
PostPosted: Aug Wed 18, 2010 4:32 am
Tonight after look at my notes on TV-7’s I see that they have problems test all tube that have a 9CV basing, with pins 1,6, and 8 have internal connection.
Jimmie
PostPosted: Aug Thu 19, 2010 9:19 am
Yeah that was my old post. The short indication is normal, so you don't want to test EL84's in the TV7's unless the EL84 has been already verified to be without shorts. TV-7's DO NOT have a bias fuse bulb. If you think the tube is just indicating a shorted condition because "that is normal for the tv7's" and the tube is *really* shorted, you could smoke a very expensive bias pot since it doesn't have a fuse bulb in series with it. OUCH!
I use my 752 to test el84's with.
Ed
 Post subject: Re: TV-7 D/U Shorts Testing Problem
PostPosted: Dec Sat 06, 2014 2:28 am
I'm bringing this old thread up just as a reminder about the incompatibility between the 6BQ5, EL84, and 7189 and TV-7 series tube testers. I was testing a bunch of tubes tonight including six 6BQ5's and two 7189's and found that they all showed shorts as described above. Then I Googled "6BQ5 test on TV-7D/U" and this topic was first on the list. Thank you ARF for letting me know about this little secret. Does anyone know about any other tubes that will not test correctly on the TV-7's?
Users browsing this forum: banjo800, Big Harry, Retired HVAC and 9 guests
cron
