It is currently May Sun 20, 2018 8:13 pm
 Post subject: Precision socket adapter help needed
PostPosted: Aug Sat 14, 2004 5:49 pm
Hi, I need the pinout for the Precison octal to 9 pin miniature socket adaptor. Precision part G-109. Hopefully most of you Precision 900 series owners should have one, perhaps maybe one you don't need.<P>------------------<BR>Tony
PostPosted: Aug Sun 15, 2004 1:07 am
Most adapters are wired 1 to 1, 2 to 2, etc. It would be easy to make one with an old octal base and a 9 pin socket.<P>Dave<P>------------------<BR>Intelligence is the ability to use your knowledge
PostPosted: Aug Sun 15, 2004 1:48 am
Thanks Dave, I have the original adapter but I pullled it apart a while back for whatever reason and forgot what went where.<P>------------------<BR>Tony
PostPosted: Aug Sun 15, 2004 4:38 am
In making the adapter, would one assume that pin 9 of the minature tube socket is connected to the "grid cap" connection of the tube tester (since the octal plug has only 8 pins)?<P>Dave<P>------------------<BR>
PostPosted: Aug Mon 16, 2004 7:58 pm
Well, I opened up my 912 modified with a 9 pin mini socket on the panel. Traced the wiring, checked it against the schematic and loctal socket where all sockets are interwired, transposed it to the octal socket, and quess what? It is wired one for one with the octal socket with the 9th pin going to grid cap connector. <P>Now this 9 pin socket has a center contact in the socket, any idead what that was used for? I don't think it was connected in anyway, but just curious as to what used for.<P>------------------<BR>Tony
PostPosted: Aug Mon 16, 2004 8:47 pm
Hi Tony,<P>There was a multi-section tube with a 9-pin miniature base and an additional pin in the center. I can't remember the number. It was discussed here recently.<P>------------------<BR>73 de Leigh W3NLB | | Leigh@AtwaterKent.Info<BR><A HREF="http://www.AtwaterKent.info" TARGET=_blank>http://www.AtwaterKent.info</A> | | <A HREF="http://www.Synchrophase.info" TARGET=_blank>http://www.Synchrophase.info</A>
PostPosted: Aug Mon 16, 2004 9:13 pm
Hi Tony<P> 6C9 is one number with a center pin. There are a couple others but none were used very often.<P>------------------<BR>Norm
Users browsing this forum: Findm-Keepm, jim rozen, processhead and 15 guests
