It is currently Jun Fri 22, 2018 10:30 am
 Post subject: Eico 1078 (variac sort of)
PostPosted: Feb Tue 01, 2005 6:36 am
Hi, I picked up a Eico 1078 variable power supply. I have two questions. 1)The meter reads about 10 volts low at all places; is there a way to calibrate the meter? and 2)Does this unit act as an isolation transformer or should I still use a separate one? Thanks <P>------------------<BR>
PostPosted: Feb Tue 01, 2005 6:41 am
There should be some way of calibrating the voltmeter, but I can't guarantee it.<P>An isolation transformer will be a separate component. It can't be built into the Variac itself, by definition. Measure the resistance between the input and output connectors. If there's an iso in the circuit, it should read hundreds of megohms, effectively an open circuit. Any lower reading indicates no iso.<P>------------------<BR>73 de Leigh W3NLB | | Leigh@AtwaterKent.Info<BR><A HREF="http://www.AtwaterKent.info" TARGET=_blank>http://www.AtwaterKent.info</A> | | <A HREF="http://www.Synchrophase.info" TARGET=_blank>http://www.Synchrophase.info</A>
PostPosted: Feb Tue 01, 2005 7:18 am
Thanks, Leigh. <P>------------------<BR>
PostPosted: Feb Tue 01, 2005 7:27 am
I have a 1078, too. My meter reads more than 10 volts low, more like 30 volts. I see no adjustment. I have suspected, but not bothered to confirm that it is due to the meter rectifier (inside the meter). I just use an external meter. The transformer is not isolated. I have it plugged into a 1KVA isolation transformer. <P>------------------<BR>Brian McAllister<BR>Sarasota FL<BR> <A HREF="http://oldtech.net" TARGET=_blank>http://oldtech.net</A><BR>bkm@oldtech.net
