It is currently Apr Mon 23, 2018 8:10 pm
 Post subject: matching transformer for 600 to 8 ohm AF output
PostPosted: Mar Mon 27, 2006 4:23 pm
Wondering what would work to match 8 watts at 600 ohm imp AF output to an eight ohm speaker. I normally use the little $2 PC board transformers for these matching tasks, but they are only rated to .4 watts so they are not going to do the job this time (on a Navy RBS receiver). I am not interested in replacing the original output transformer.<P>Any suggestions would be appreciated<P><BR>Thanks<P>Andy<P>------------------<BR>
PostPosted: Mar Mon 27, 2006 4:36 pm
Andy, I've been using the Hammond 600:8 matching transformers and they work very well. I've gotten good results on receivers such as an SX-28, SP-400 and SX-16. I think that both Radio Daze and Antique Electric Suppy carry these transformers and they're slightly less than $20 apiece. <P>Joe Connor<P>------------------<BR>
PostPosted: Mar Mon 27, 2006 5:23 pm
In a pinch, I've used a 50L6 output transformer from a junker AA-5 chassis. Not an exact match by any means, but it seems to work.<P>Dave<P>------------------<BR>
PostPosted: Mar Mon 27, 2006 5:29 pm
Silent Key
Fair Radio Sales used to have lots of these for sale for around 5 bucks. However that was a few years ago. Might be worth a try checking them for one.<BR>Curt<P>------------------<BR>Curt, N7AH<BR>(Connoisseur of the cold 807)<BR>QCWA# 25085 AMI# 242<BR>CW forever
PostPosted: Mar Mon 27, 2006 5:40 pm
An ordinary filament transformer will work well. A transformer with a 120-volt primary and 12.6-volt secondary has a turns radio of 10 to 1 or an impedance ratio of 100 to 1. That will take 600 ohms down to 6 ohms. Six ohms will make a decent match to a 4 or 8-ohm speaker.<P>The standard fix is to use a 10-watt, 70-volt line transformer. They used to be available from Rat-Shack - I don't know if they still have them. The 10-watt tap provides a good match.<P>------------------<BR> <A HREF="http://www.gvtc.com/~edengel/TARC.htm" TARGET=_blank>http://www.gvtc.com/~edengel/TARC.htm</A>
PostPosted: Mar Mon 27, 2006 5:52 pm
I use a 70 volt line matching transformer, probably not the most effecient, but it sounds OK. I am planning to order one of the 600/8 ones from AES. Ross<P>------------------<BR>
PostPosted: Mar Mon 27, 2006 9:59 pm
Try HSC Electronics (halted.com). They have lots of odds and ends.<P>Jim Falls<BR>KG6FWT<BR>Eureka, CA<P>------------------<BR>
PostPosted: Mar Mon 27, 2006 11:42 pm
I also use the Hammond 600:8 matching transformer on my Hammarlund SP-600. It works very well. I mounted the transformer inside the wooden case that the speaker I'm using is mounted in (old jukebox speaker). No one would ever know that I'm not using a 600 Ohm speaker.<P>------------------<BR>
 Post subject: Xformer
PostPosted: Apr Sun 23, 2006 5:55 am
Try a doorbell or thermostat Xformer. 6, 12 or 24 V. Cheap at twice the price. George.
 Post subject: Profile
PostPosted: Apr Sun 23, 2006 6:04 am
Don't find contact for web-master. Need to correct "profile" info. George. gsmonroe2001@msn.com
PostPosted: Apr Mon 24, 2006 8:39 am
A 70 volt line PA transformer, set to the correct tap, is quite close to 600 Ohms and works just fine, plus it costs under $ 5. This is not something where precision is important. You would have to be an audiophool to hear any difference between that and the Hammond transformer. You also have the advantage that the taps on the 70 volt transformer allow you to use it on other impedances to 5000 Ohms.
Unfortunately, Radio Shack has discontinued them as of 2004, however Alpex Electronics has plenty of Speco brand ones at less than $ 5 (look them up on Google) and local sound installers may be able to sell you one from a scrapped ceiling spaker assembly.
Post New Topic Post Reply  [ 11 posts ]  Moderator: Sandy
Users browsing this forum: Eric_KE6US, Exabot [Bot] and 3 guests
