It is currently May Fri 25, 2018 9:38 pm
 Post subject: Hallicrafters SX-36 Receiver
PostPosted: Mar Fri 30, 2007 9:17 pm
Does anyone have any information on a SX-36 receiver?
PostPosted: Mar Fri 30, 2007 9:30 pm
Never heard of one. But Hallicrafters made an S-36 and S-36A.
PostPosted: Mar Fri 30, 2007 9:42 pm
I have an S-36. The service information for the similar S-36A is here:
http://www.nostalgiaair.org/PagesByMode ... 008860.pdf
Top to bottom is my S-37, S-36 and SX-28:
Like Johnnysan said, there is no SX-36.
 Post subject: s-36
PostPosted: Mar Fri 30, 2007 11:30 pm
I am corrected on the type radio I have. It is a S-36.
Thanks.
PostPosted: Mar Sat 31, 2007 12:42 am
Silent Key
In my humble opinion, I think the S-36 is a more handsome receiver than the SX-28 is. Probably a lot easier to work on also, as getting to some of the capacitors in the SX-28 can be a real chore.
Curt
Curt, N7AH
PostPosted: Mar Sat 31, 2007 3:49 am
The S-36 (which followed the S-27) was designed for the emerging VHF freqiencies of 27 - 145 mhz. It can receive AM and FM modulation. The dial reminds me of the S-20R and a number of other models.
The S-37 covers the then highly experimental band of about 130 - 210 mhz. Both sets use "acorn" tubes in their front ends. The s-37 has two TRF stages ahead of the mixer. It's knobs don't match any other Hallicrafters that I know of.
PostPosted: Apr Thu 05, 2007 2:53 am
I've got a military version of the S-36 with a wierd problem. The dial stop is an arm which drops down and catches on a cam on the tuning cap shaft at each end of the band. After I tune mine to either end the arm doesn't lift high enough not to catch the cam as I'm tuning away from the dial edges. Is there some sort of adjustment which can correct this?
One other question- this set looks like it didn't use any conventional paper caps or electrolytics, only oil and mica types. My set has rather poor performance. What should I be looking to replace under there? Tubes test good.
Scott Todd
PostPosted: Apr Sun 29, 2007 7:21 am
You might want to check some of those caps. I always believed micas to be bulletproof, until I found some bad ones in a couple of 50-year old TVs. Same for bathtub style caps. Somebody told me they were all oil filled, and good forever. I tested a couple in a Scott 800B radio, and they leaked like the devil, so I replaced 'em and the radio was good to go.
I'm not telling you to shotgun every cap, but it costs nothing to check, eh? After 60 years or more, even usually-good quality components may be showing their age :-)
PostPosted: Apr Sun 29, 2007 8:13 am
My SX-25 looks almost the same as the S-36. It is that rare receiver that looks much more impressive in person. It eased my lust for an SX-28. Unfortunately it kindled a craving for the SX-23. I wonder if the S-36 used the PM-23 speaker too. It's a beaut especially with the chrome h.
-Phil
Post New Topic Post Reply  [ 9 posts ]  Moderator: Sandy
Users browsing this forum: Robert Buntzel and 3 guests
