It is currently Jan Wed 24, 2018 12:35 pm
 Post subject: Eico 636 tube checker info wanted.
PostPosted: Mar Wed 12, 2008 3:46 pm
I picked up a tube checker at a 2nd hand store cheap. No book, no info.
Has anyone heard of a Eico 636 tube checker? Doing a Google search I can see it listed but no info.
Checking Bama I can find nothing. It seems to skip it.
I'm looking for a circuit diagram at least, or where I can find a cheap manual and data book. Is there such a thing?
I think it will work after cleaned up, if nothing else maybe I could turn it into a low voltage power supply for a couple of 1935 aera BC radios I'm working on.
Its about a 8 x 7 x 3 plastic case, the front is metal. The only ID I can find on it is the meter says Eico 636.
Is there any hope for it?? I'm about ready to scrap it.
Jerry - NR5A - South Dakota
PostPosted: Mar Wed 12, 2008 5:06 pm
Hi Jerry;
EICO 636 is the same as Realistic (Radio Shack) Model T-B-C (Tube-Battery-Continuity) tester, and also very closely related to EMC 211, 213 and 215. As far as I know, the last tube tester model EICO produced themselves was the 635, so apparently EICO (as well as Radio Shack and EMC) decided to out-source these models at their final legs of the tube tester business.
You can use the schematics and tube setup data from EMC 213-215 for your EICO 636. The complete document is posted on BAMA > http://bama.edebris.com/manuals/emc/
EICO 636 and Realistic T-B-C has a battery and continuity testing function in addition to the tube testing facility. EMC 211 and EMC 213 is a plane-Jane tube tester, and the EMC 215 has an additional transistor tester function. But the tube testing section of all the models are the same and the setup data are interchangeable. Use the EMC 213 schematics for your EICO 636.
Unless the meter and/or power transformer are dead on your 636, there isn’t much inside so it would be very easy to fix. Clean all the switch contacts and tube sockets with a contact cleaner that removes copper oxidation, clean the pots, replace any out-of-value resistors and a .02uf cap by the neon lamp, you should have a working emission tester in no time
Chris M.
Users browsing this forum: Google [Bot], Marcc, rob.manderson and 8 guests
