| View previous topic :: View next topic |
| Author |
ecir40 New Member
| Posted: May Tue 06, 2008 2:52 am |
I could use some help on the type of componets used on this tube tester. I am new to working with eletronics and some of the older pieces I have not seen before. My first question is for the 2500ohm 2W resistor. It is about 3 inches long and flat. I am guessing it is a flat wirewound resistor. The coating has a sandy finish and doesn't look to be in great shape although it reads correctly with a DVM. Should I replace this and if so with what?
Johnnysan
Joined: 01 Jan 1970 Posts: 6182 Location: Albuquerque, NM 87123
| Posted: May Tue 06, 2008 6:02 am |
| If the resistor looks bad, I would replace it, probably with a 5 watt resistor. Does the tester function OK? |
ecir40 New Member
| Posted: May Tue 06, 2008 12:50 pm |
The tester seems to be working fine. What I have replaced so far is two 470 ohm resisitors with metal oxide ones and the BYI diode with a ratshack 1N4005. I also resoldered all connections. See resistor and parts that have been replaced in pic below. Never seen a diode like that before, hope I chose a equivalant replacement.
easyrider8
Joined: 01 Jan 1970 Posts: 4848 Location: Minnesota easyrider8@aol.com
| Posted: May Tue 06, 2008 10:39 pm |
Now just replace the capacitors and you should be all set.
Dave |
Alan Douglas
Joined: 01 Jan 1970 Posts: 16705 Location: Pocasset, Cape Cod, MA
| Posted: May Wed 07, 2008 12:49 am |
This is weird: I'm sure I replied to this thread today, either at lunch or break time, but I don't see my post now.
It's not the first time the server has skipped posts, but usually they show up after a couple of reloads. |
ecir40 New Member
| Posted: May Thu 08, 2008 2:30 pm |
Alan, since it looks like your post isn't going to come through. Can you reply again?
I am still curious about what kind of resistor this is, even though it might not be replaced since it test ok.
Thanks |
easyrider8
| Posted: May Thu 08, 2008 3:17 pm |
The resistor is a wirewound sand resistor. If the wires are not corroding away and it reads good it will be fine to use.
Dave |
Alan Douglas
| Posted: May Thu 08, 2008 4:20 pm |
| I agree with Dave. |
ecir40 New Member
| Posted: May Thu 08, 2008 9:20 pm |
| Thanks guys. |
