Antique Radio Forums :: View topic - 6ME8 1-tube superhet - A modest Proposal
Forums :: Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives :: Books :: Value Guide :: Wiki  Support This Site: Contributors
Radio Showroom
 Forum Rules/FAQ   Posting Photos   Search     Register   Profile   Log in to check your private messages   Log in
6ME8 1-tube superhet - A modest Proposal Goto page 1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Homebrew Radios
View previous topic :: View next topic
BobWeaver
Posted: Sep Thu 25, 2008 1:29 am  Reply with quote
While discussing the 6ME8 direct conversion receiver here, Vlad had brought up the possibility of using a 6ME8 as a one tube superhet and emailed me his proposal:
Meanwhile, I'd also had some fleeting thoughts of this and had sketched a proposed circuit as well:
Fairly similar, but there are a couple of differences.
Vlad's idea of connecting the IF transformer #1 primary between the plates looks like a much better idea than mine. I'd been thinking along the lines of the audio detector transformer from my direct conversion circuit, but a center tapped IFT would have to be custom job.
On the other hand I see a bit of a problem with how the reflexed signals are combined in Vlad's circuit. The rotor of tuning capacitor should be grounded to avoid special mounting and hand capacitance problems. To handle this, I had used an extra winding on the RF coil to feed the signal through.
I think these two circuits could be combined, to produce something interesting, and possibly even functional.
View user's profile Send private message
vladn
Posted: Sep Thu 25, 2008 2:52 am  Reply with quote
I think IF1 primary connection in parallel to LO exitation is not optimal - they will shunt each other at both resonanse frequencies reducing the Q - I guess having weak inductive coupling in IF1 and weak capacitive coupling in LO may somewhat alleviate that but still. I think the correct way is to have LO and IF1 tanks connected in series. BTW am I correct that a cap in series with LO excitation coil is strictly to adjust the coupling ?
Input connection does not require separate RF coil if you change the order. RF tank can be grounded, followed by IF1 output followed by floating AF filter (especially if volume control can be replaced with AGC control as below). Not a big deal just trying to simplify things. Another option would be to move audio on a separate grid but I am not sure how much worse intermod would be.
BTW I really like Bob's 2-tube superhet idea for IF regen and AGC combo. The ability to continuously adjust IF bandwidth via IF regen control without volume change on such small superhet RX is impressive. I am not 100% sure BFO function from IF regen will work in this setup but it is definitely worth a try. AGC would be a must for maintaining very low level of IF BFO oscillations. Maybe volume control should be done via adjusting AGC level instead.
vladn
Posted: Sep Thu 25, 2008 3:10 am  Reply with quote
I've just realised that for AGC you need detector output referenced to ground so I guess it is ether extra RF winding like on your schematic or audio to grid 2.
BobWeaver
Posted: Sep Thu 25, 2008 4:58 am  Reply with quote
I think I'm going to sleep on this tonight. Razz
vladn
Posted: Sep Thu 25, 2008 8:01 pm  Reply with quote
I think the most important issue in this design is to make IF (and to some extent AF) amplification as linear as possible so prevent parasitic spurs from harmonics bleed between reflexing amplification bands. If the IF harmonic suppression in RF band is less than RF gain it may cause runaway oscillation when RX tuned to the IF harmonic spur.
Fortunately tube harmonic energy is mostly concentrated in the low order harmonics so it should be less of an issue for AF-IF separation (even though AF signal is of larger magnitude). However IF to RF harmonic bleed separation is a big deal in this design. I think it can be solved by:
- selecting IF frequency to be less than half of the bottom of RF band avoiding the strongest 2nd harmonic of IF bleeding into RF;
- using AGC to keep IF level in the small signal region that ensures better IF amplification linearity, this will also avoid runaway oscillation that could make it difficult to tune away from the parasitic spur;
- possibly linearizing the tube amplification by adding a cathode resistor trading off some gain for linearity, could also be used for manual gain control or volume control.
BobWeaver
Posted: Sep Sat 27, 2008 5:36 am  Reply with quote
Just a few comments on some things you mentioned.
The reason for the capacitor in series with the local osc. primary was simply a leftover from the direct conversion receiver to prevent the audio signal from being shunted through the osc, coil and disappearing. Since there shouldn't be any audio frequency diff mode signal in the superhet, the capacitor shouldn't be necessary.
You made a few comments about problem of harmonic generation due to tube nonlinearities. The one good thing about beam deflection tubes is that they are noted for excellent liinearity. I can vouch for that, because in the direct conversion set, there were ample opportunities for cross modulation of signals, yet I had virtually no problem in that regard.
Regarding AGC, I'm not sure what the cutoff characteristics of this tube are. I suspect it's sharp cutoff. However, AGC could still work to a certain extent, but it would likely be touchy. Maybe trying to get AGC in something like this is asking too much. Anyway it's just a matter of observing correct polarity of the detector diode, and carrying the DC through back to the grid.
I received this schematic and comments by email:
vladn wrote:
Taking in your suggestions attached is a hybrid schematics (better drawn). Still no IF regen and AGC yet. I have very limited experience (to say politely) in biasing tubes so the AGC circuit is probably on you. IF regen probably does not need a separate tickler coil - a variable capacitive link between IF filters will probably do just fine.
Maybe this circuit for gain control is better since it does not affect tube DC bias. (L16 should have large enough inductance to mininimize AF LF rolloff). I think any gain / volume control in this design should use some form of negative feedback rather than attenuator to make the amplification more linear. One tradeoff is that LO must run pretty hot in this design for good conversion efficency and ideally negative feedback should only affect common mode gain.
And one more idea - I've been thinking about capacitive balancer at the plates to enhance common mode / differential mode separation (a small fixed capacitor in one plate to something plus a tunable capacitor in another branch). But I suddenly realised that it could also serve as a front panel regen control as well. Like a small tunable cap on one plate and a variable cap mounted on the front panel on another plate. It can be tuned such that at one extreme position on front panel variable cap corresponds to a perfect balance (minimum IF feedback) and the other extreme position corresponds to reliable oscillation (BFO) across all gain/tuning conditions.
My thoughts are revolving around these areas of the design now:
- how to best make a manual gain / volume control via negative feedback;
- how to minimise effect of AGC and manual gain control on LO;
- how to minimise compression effects from AGC and audio amplification on RF amplification;
- how to fine-tune the balance in the differential stage to control IF feedthrough - another possible idea is to use DC offset between deflector plates;
So far I do not see a show stopper but a lot of tiny issues. Also started looking into 6ME8 datasheet and tube operation intro on the net trying to understand how tubes work in general Smile. BTW there are a lot of warnings on sensitivity of BDT to stray magnetic fields (moving it out of balance), have you noticed that on your DC RX ?
One mistake in my comments is that L16 does not cause AF LF rolloff, rather the opposite, it results in max gain at DC.
BobWeaver
I'm not sure how that cathode resistor and inductor would work out. Generally the DC should be forced through the resistor to put the cathode a some small positive voltage. Then the grid is biased slightly negative with respect to the cathode. This arrangement would keep the cathode and grid at the same potential.
I suspect that you don't need to be too concerned about things affecting the local oscillator. I found that in the direct conversion set, this oscillator is virtually impervious to anything that I threw at it. One would normally be concerned about the oscillator being pulled off frequency by a very strong RF signal, but this one was so stable that it needed a fine tuning control to get it close enough to the RF signal to lock in.
Regarding your final points, I think you are looking too far ahead, and risk overdesigning things. A prototype probably needs to be built now to see how it really behaves. Many of the concerns may be unwarranted, and other problems, not considered, may show up. A prototype would show which way to proceed.
vladn
Posted: Sep Sat 27, 2008 10:17 pm  Reply with quote
Clarification on last cathode circuit - assuming that the tube is biased strictly by the grid leak RC circuit (also part of AF detector) with cathode DC at ground the inductor works similar to a current source in the long tail pair. When only inductor is present the common mode gain is virtually zero while differential mode gain (LO) is unaffected. When resistive shunting of the inductor is increased so is common mode gain. Assuming an output tube impedance of ~10k a pot of comparable value will vary common mode gain from 1 to max with no affect on LO.
There is an issue with the diode detector polarity on all diagrams so far - if the grid is DC coupled to the detector then grid leak current will reverse bias the diode. Yet in this orientation it forms a pseudo-AGC since the AM carrier increases negative offset reducing tube gain, while reversing it will do the opposite. So reversing the diode polarity in that sense is undesirable. Not sure yet how to solve it.
I've downloaded 6ME8 spec:
http://tubedata.itchurch.org/sheets/049/6/6ME8.pdf
Looks like it is speced for 14ma sum of plate currents with max being 30ma which corresponds to gr1 bias of approx -5.8V and -3.3V respectively. I am not sure that grid leak bias would be sufficient for setting proper operating point. Cathode resistor is probably needed.
Also I may be wrong but from I've read about BD tubes is they are extremely linear for differential mode amplification. Not so sure about common mode.
vladn
Posted: Sep Sat 27, 2008 11:02 pm  Reply with quote
Q for the tube guys - does the tube diode have negative voltage cutoff ? If so I can understand how it can work in DC coupled AGC configuration as the negative cutoff compensates for negative bias from grid leak. Or maybe I am completely confused.
BobWeaver
Posted: Sep Sat 27, 2008 11:48 pm  Reply with quote
In any circuits I've seen, there is no grid leak bias when AGC is used. The AGC provides all of the bias in order to control the gain. The grid may be connected to the AGC line through a large resistor to isolated it from other stages that are also controlled by AGC, but in this case the resistor is not acting as a grid leak.
vladn
Posted: Sep Sun 28, 2008 12:06 am  Reply with quote
I need to think some more on detector design, gain control and biasing. I really like the idea of negative feedback manual gain control. If it is done at the cathode the additional benefit is that extra winding in RF tank is not really needed since AF filter can be floating.
vladn
Posted: Sep Sun 28, 2008 1:30 am  Reply with quote
Is there any data on steady state grid leak current vs grid bias (in the negative bias voltage region) for 6ME8 or other tubes ?
vladn
Posted: Sep Mon 29, 2008 1:59 am  Reply with quote
I did a quick and dirty simulation of the mixer / IF reflexing topology in ltspice and it seems to work as expected. I do not have BT tube models so I just build equivalent circuit out of FETs.
BTW I think I found 1AD reflexing superhet circuit by Terry Judkins that Bob referred to :
http://home.comcast.net/~suptj ... erhet2.GIF
He uses IF regen, not true IF reflexing, only AF is reflexed. Great idea but different.
After thinking some more on AGC in BDT superhet I realized that the main difficulty is the impact of AGC on AF amplification. Strong stations involving AGC will limit the tube current and AF power headroom. The funny result is that you can only listen to weak/medium signals at high volume level Smile.
Standard AGC design will actually overcompensate by dropping AF gain. While it is easy to compensate for that by introducing the AF-only negative feedback, the AF amp headroom will be greatly reduced at low currents and it will go into clipping.
One possible solution is to add another tube for power amplification (6BQ5, 6AQ5 or similar) and use BTD AF as preamp in small signal mode with negative feedback used to linearise the amp and negating AGC impact on AF gain. But this is a whole different project - big transformer, box for a nice large loudspeaker etc.
BobWeaver
Posted: Sep Mon 29, 2008 6:33 pm  Reply with quote
vladn wrote:
I did a quick and dirty simulation of the mixer / IF reflexing topology in ltspice and it seems to work as expected. I do not have BT tube models so I just build equivalent circuit out of FETs...
That sounds promising.
This has become interesting enough, that I think I may have to start building one of these. I don't have much spare time right now, but I need to order some parts first anyway.
vladn
Posted: Sep Tue 30, 2008 3:27 am  Reply with quote
I am actually thinking that off the shelf common mode toroidal chokes can be used for all transformers except audio and IF with just few turns added for L15 and L3. The L4/L5 one has to have large enough inductance not to shunt IF frequency. These chokes usually use powdered iron cores, not RF quality but may work OK.
BobWeaver
Posted: Oct Wed 01, 2008 12:56 am  Reply with quote
My past experience with non-RF ferrite has been quite bad. Anything designed for RFI suppression tends to use very lossy ferrite, so that the ferrite losses account for as much RFI suppression as the inductance does. I don't think I would chance it. I would go with a type 61 ferrite.
Curt Reed
Posted: Oct Wed 01, 2008 10:11 am  Reply with quote
I think my bad past experiences with toroids may have been because the wrong core material was used. Thirty years ago I did considerable experimenting with them and my experiments were all a flop. Most of the cores were salvaged from junk boxes found at hamfests and such and the core material was anyone's guess.
Someday I hope to get back into them and take up where I left off, but I will be better armed with more knowledge about them now than I had back then.
Curt
Curt, N7AH
View user's profile Send private message Send e-mail
vladn
Posted: Oct Thu 02, 2008 2:40 am  Reply with quote
Did some reading on RF core materials - you are right on EMI chokes, probably wont work. Also there is apparently an issue with temp stability with most core materials even RF ones, not good for LO.
However for L4/L5 an off the shelf pulse transformer should work just fine. DC current is compensated between two coils so there should be no core saturation issues. Needs inductance at least in the tens of mH though.
I've started ordering some parts for this thingy. Main question is where do you get 262 KHz IF cans ? My guess is these have to be tube-specific for the reasons of proper impedance matching.
Norm Leal
Posted: Oct Thu 02, 2008 1:35 pm  Reply with quote
Hi
You can buy 262 KHz IF Transformers here:
http://www.oldradioparts.com/2a6fla.txt
There is an earlier post about making your own IF Transformers using two RF chokes mounted close together for coupling. Should be able to search for this information.
BobWeaver
Posted: Oct Thu 02, 2008 3:59 pm  Reply with quote
vladn wrote:
...Also there is apparently an issue with temp stability with most core materials even RF ones, not good for LO...
I've used them for LO's and had no problem with temperature stability, although they were generally kept away from heat sources. Both, my 2 tube superhet and the 1 tube direct conversion set uses them with no problems. However, I have noticed that the smaller cores can experience strange behavior in oscillator circuits (harmonics and ringing) if you put too much power through them.
Display posts from previous:
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Homebrew Radios All times are GMT
Page 1 of 6
You cannot post in this forum
Only registered users can edit or delete their posts in this forum
