Page 1 of 1
[ 14 posts ] |
Author |
dazzler
Post subject: Crosley 51 tapped coil mystery? Posted: Apr Fri 29, 2022 8:06 am |
Hi everyone, Im Bob, new to posting on this site, hope Im in the right place, I recently received a Crosley 51 in bits,every component has been desoldered. Im trying to work out how to ID the tap wires from the fixed coil so I can resolder them back onto the switch. Strangely enough there is another fixed coil piggy backed on to the usual coil as seen in many pics online of Crosley 51s. I can only guess that this extra coil, which is just one winding as there are only two wires, it must go in series with the other one ?? The tickler I can identify no problem, I have attached photos, maybe someone out there could take a photo of their tapped coil arrangement and post here thanks. Just retired last nov, 45 years in electronics, military, civil commercial so I know my way around this stuff. Cheers all.
Attachments: |
Top |
palegreenthumb
Post subject: Re: Crosley 51 tapped coil mystery? Posted: Apr Fri 29, 2022 2:52 pm |
Member |
Joined: Apr Sun 01, 2012 9:55 pm Posts: 13913 Location: Seattle, WA
Hi Bob, welcome to the forums! Schematic and hookup diagram is here: http://www.nostalgiaair.org/Resources/372/M0003372.htmI don't see that third coil in pics of other 51s online. You got me stumped.
_________________ Rodney -- KG7EPW Measure it with a micrometer, mark it with chalk, cut it with a chainsaw.
Top |
1N770
Post subject: Re: Crosley 51 tapped coil mystery? Posted: Apr Fri 29, 2022 3:57 pm |
Member |
Joined: Aug Mon 16, 2021 3:25 am Posts: 251 Location: Lewis & Clark Stomping Grounds, Oregon, USA
I have (2) Crosley 51 radios in my collection. They are all constructed exactly as the 1920's schematic indicates.
I would "rebuild" your Crosley 51 exactly as the schematic shows. That is the correct circuit. That extra spider coil, IMO, has no reason to be there. I highly doubt it was there originally.
Jeff
Top |
Post subject: Re: Crosley 51 tapped coil mystery? Posted: Apr Fri 29, 2022 5:25 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 17898 Location: S. Dartmouth MA 02748-1225 USA
I see the extra coil as either a loading coil for long-wave or a conversion to make the tuner a three-circuit. Useful in both instances, as a receiver for long wave it would make the set capable of receiving time signals, for what ever purpose, navigation, jeweler/clock/watch repair. As a three circuit tuner it would isolate the the antenna from the effects of loading the regenerative circuit, reduce any regeneration oscillation from reaching the antenna and causing local interference. Despite the coil being so close to the tuned winding. If the history of the set could be known there may be an explanation. The "extra" spider coil looks like a Crosley product, maybe review of their products available at the time this set was offered, could be found in ads for Crosley at World Radio History. https://worldradiohistory.com/index.htmSome radio manufacturers did offer long wave loading coils but these were often external to the set. However, Crosley was into compact, inexpensive designs at this time... A Jewelers time receiver was, often, more elaborate and costlier that a Crosley 51... Chas
_________________ List' & I will Enchant Thine Ear
Top |
jrehkopf
Post subject: Re: Crosley 51 tapped coil mystery? Posted: Apr Fri 29, 2022 6:55 pm |
Joined: May Sat 30, 2015 11:49 pm Posts: 2384 Location: Keystone Heights, FL, USA 32656
A loading coil, with a switch to switch it in or out?
As to the original coil connections; The green sleeve wire goes to the book condenser, outside connection (with the grid leak). Then there are 5 taps on the coil, from the outside to the inside. Holding the panel upside down, looking from the back, the outer-most tap goes to the left terminal. Then they connect in order from outside to inside taps with the inner-most tap connected to the last terminal on the right.
When connected correctly you should get from about 1.6 to 5 ohms, in steps, measured from the grid leak input to ground. On these radios, this is one of the most difficult switches to work correctly; usually when using the radio I just wiggle the do-do out of it until I get some stations, then don't touch it (or even look at it).
_________________ Jeff “Nothin’s worth nothin ‘till somebody wants it.”—Irv Metter
Top |
Technopol
Post subject: Re: Crosley 51 tapped coil mystery? Posted: Apr Fri 29, 2022 7:51 pm |
Member |
Joined: Nov Fri 23, 2012 3:15 pm Posts: 154 Location: Tucker, GA 30084
Top |
dazzler
Post subject: Re: Crosley 51 tapped coil mystery? Posted: Apr Sat 30, 2022 1:50 am |
Top |
jrehkopf
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Sun 01, 2022 11:29 pm |
I have 3 or 4 of these and they are all wired like the drawing. I think the schematic is incorrect at the top. The book condenser connects to the top of the coil, then if you move the first 4 switch connections down one position on the coil, then the schematic matches the drawing.
Top |
dazzler
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Wed 04, 2022 5:22 am |
Thks Jeff, that makes sense, although the crosley wiring diagram shows 5 taps plus the book condensor green wire, the schematic as you said correctly shows 4 taps down the coil from the top green wire, Ive seen lots of schematics over the years full of errors which slip thru. I have wired it as per schematic, I used the left over tap, 1st or 5th depends which way you look at it, to switch in and out that odd ball coil and see what happens. Still a work in progress, waiting for 12G buss wire to turn up. I dont know what the added switch was for, I replaced it with a 1/4 inch phone jack for a ext speaker, fills up the hole.
Top |
dazzler
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Wed 11, 2022 5:30 am |
Top |
brnhornet52
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Wed 11, 2022 12:42 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1596 Location: Bristol TN 37620
Good job, dazzler. Some clever mods there.
Top |
dazzler
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Tue 17, 2022 7:45 am |
Top |
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Tue 17, 2022 3:06 pm |
Member |
dazzler wrote: A question for anyone out there with a Crosley 51, the lid on my unit looks like it had some pads on the forward corners where it makes contact with the main wooden cabinet and there is a small hole in each corner. I cant see any reason to drill a hole or put tape or whatever. Also toward the center of the lid there are 3 little pin holes in a triangular pattern, anyone else seen these in Crosley 50/51 series lids? I've looked online at other Crosley's but none have these peculiarities. Just mainly curious thats all. Just another modification in its life, not an OEM for sure. Little left to identify as Crosley in this example, panel, knobs, book condenser. Though I have found them as parts sets as well and pieced them back together. I never cared for the series tuned front end. Designed for a high capacity antenna, a through-back from the Wireless era... Then again, Crosley was aware of the needs of his customers.
Top |
dazzler
Post subject: Re: Crosley 51 tapped coil mystery? Posted: May Wed 18, 2022 1:40 am |
Thks Chas, yeah its amazing sometimes what people do in the past modifying things. Must have been a good reason at the time!
Top |
Page 1 of 1
[ 14 posts ] |
Moderator: sofaslug |
Who is online |
Users browsing this forum: sdfzaqhp659 and 27 guests |
