Author |
Indiana Radios
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 07, 2021 5:00 pm |
Member |
Joined: Sep Thu 14, 2006 3:27 pm Posts: 13878 Location: Carmel, Indiana
I think the cabinet is vintage which has been poorly refinished in recent years. In order to strip the cabinet, the lid hinge needs to be removed and many time that results in the stripping or damaging of the hinge screws. Those screws were usually cheaply made with shallow groves for the screw driver to grab hold. I think, in the case of this cabinet, so many of the original screws were damaged upon removal of the lid that the refinisher simply settled on Philips style screws as replacements. He probably couldn't find exact flathead screws at the local hardware store but these Phillips screws were a good enough match.
_________________ Michael Feldt
www.indianaradios.com
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 07, 2021 5:11 pm |
Member |
Joined: Apr Sun 01, 2012 9:55 pm Posts: 12521 Location: Seattle, WA
I was debating myself whether the cabinet is modern. There's something about the way the feet are tacked on, they look a little ungainly. In that sense the styling doesn't seem very 1920s to me. (But then look at the exaggerated foot molding on the cabinet shown in the build article... It looks a little ungainly too!) Also, the cabinet is unfinished on the bottom, so I stuck my nose up against it because I love the smell of walnut. No particular odor. It's a dark wood, but it doesn't smell like walnut. Maybe wenge or something like that.
I want to know what that transparent red insulator material is, too, Steve. It looks and feels like plastic, but what kind? Yes the lug on the stator is broken, but worse than that, the stator and the rotor are rubbing on that cap. The other one is fine, but the broken one seems to be warped a bit out of shape.
_________________ Rodney -- KG7EPW Measure it with a micrometer, mark it with chalk, cut it with a chainsaw.
Top |
David Willenborg
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 07, 2021 5:34 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1789 Location: Hollywood, Maryland
Clear red plastic could be Celluloid or Catalin. The Kadette Clockette was available in clear blue Catalin.
Top |
azenithnut
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 07, 2021 5:37 pm |
Member |
Joined: Jan Mon 18, 2010 2:13 am Posts: 22105 Location: Dayton Ohio
I was wondering if the plastic could be "Victron" or whatever the spelling is of that clear plastic was that was often used in the 1930s for HF and VHF work.
I seem to recall The National Co. or James Millen selling parts made of it.
_________________ Radio Interests -Zenith -Sparton -Pre-War FM Consoles and floor models, the bigger, the better!
Top |
Indiana Radios
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 07, 2021 7:45 pm |
Member |
palegreenthumb wrote: I want to know what that transparent red insulator material is. My guess, red translucent celluloid acetate.
Top |
Duane B
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 07, 2021 10:28 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 846 Location: Utah 84065
I have a radio with those same tuning capacitors (St James). I think they are Bremer Tully capacitors.
Edit: Sorry, I now see on the documentation that it indicates Bremer Tully.
_________________ www.duanesradios.info
Top |
David Willenborg
Post subject: Re: Roaring 20s Superhets Posted: Mar Tue 09, 2021 5:52 am |
Member |
Today I picked up three 20's superhets. They all have issues but I think they will all be worth the effort to restore them. This Victoreen has an engraved but no cabinet.
Attachments: |
Top |
Indiana Radios
Post subject: Re: Roaring 20s Superhets Posted: Mar Tue 09, 2021 3:30 pm |
Member |
Dave, that's an very sharp looking Victoreen. Interesting match up of 360 degree Remler tuning dials to 180 degree tuning capacitors but those Remler dials do look nice. If you totally restore that chassis, I'm guessing you won't want to house it in a cabinet.
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Tue 09, 2021 3:38 pm |
Member |
Nice Victoreen! I really like the graphics on the front panel, that's very cool.
Top |
targeteye
Post subject: Re: Roaring 20s Superhets Posted: Mar Tue 09, 2021 4:54 pm |
Member |
Joined: Jun Wed 21, 2006 1:56 am Posts: 1096 Location: Katy, Texas
palegreenthumb wrote: I want to know what that transparent red insulator material is, too, Steve. It looks and feels like plastic, but what kind? Yes the lug on the stator is broken, but worse than that, the stator and the rotor are rubbing on that cap. The other one is fine, but the broken one seems to be warped a bit out of shape.
The Bremmer Tully cap should be a fairly easy find to replace. Just put a WTB add in classifieds. I'm sure one will turn up. i have extras but they are packed away and buried.. It will be a long time until i get to those boxes. Would be quicker to just run and ad.
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Wed 10, 2021 4:53 pm |
Member |
Top |
Duane B
Post subject: Re: Roaring 20s Superhets Posted: Mar Thu 11, 2021 1:53 am |
Member |
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Fri 12, 2021 12:43 am |
Member |
It's interesting the differences. I mean, the component changes are pretty obvious. But the way the 1st-stage jack and power switch are swapped catches my attention.
It's also the case on the Rauland super I posted a few days ago. The 1st-stage jack and power switch are swapped from the plans.
Curious.
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 21, 2021 2:52 am |
Member |
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 21, 2021 2:53 am |
Member |
Top |
Duane B
Post subject: Re: Roaring 20s Superhets Posted: Mar Sun 21, 2021 7:41 pm |
Member |
Someone at Estes must have mis-labeled the radio. Your set, except for the meter, uses the basic Cotton design. Nice looking superhet!
Top |
palegreenthumb
Post subject: Re: Roaring 20s Superhets Posted: Mar Mon 22, 2021 10:04 pm |
Member |
Duane B wrote: Someone at Estes must have mis-labeled the radio. Your set, except for the meter, uses the basic Cotton design. Nice looking superhet! Thanks Duane! It seems like an odd mistake to make. However, there were some other Ware radios in the auction, so maybe Cledis thought it "looked the same" for some reason. I like the trapezoidal layout of the 4 rheostats around the meter, it has a nice look to it. -Rodney
Last edited by palegreenthumb on Mar Tue 23, 2021 12:11 am, edited 1 time in total.
Top |
David Willenborg
Post subject: Re: Roaring 20s Superhets Posted: Mar Mon 22, 2021 11:36 pm |
Member |
That wasn't the only misidentified super in the auction. I think the mistakes benefitted the buyers.
David
Top |
Robert Lozier
Post subject: Re: Roaring 20s Superhets Posted: Apr Thu 08, 2021 11:22 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2214 Location: Monroe, NC 28112 USA
I rarely have supers to show. Today I finished assembly of a Best super of (I guess) 1925 vintage... Has been waiting in my house attic for 15 or 20 years for attention. No engraving on the panel. Kind-of bummed that the IF transformers are positioned so you can't see the nifty Blue and Silver Remler tags.
This set is a pain to solder together with a 1920s vintage iron because there are a bunch of plain T-type buss wire intersections. If I had built it way back when, I would have bent a little L in the base of the T and tied a strand of wire to the long bus to hold stuff in position for soldering.
The cabinet is a Signal brand made of solid walnut. It appeared to have a single coat of clear lacquer with no grain filling and never stripped. I deviated by giving it three coats of lacquer and rubbing-down to satin finish...
The Remler tuning condensers were improperly assembled. And could never work that way. It is tricky to line them up. Fortunately I had a junk box unit to set me straight.
I'm sure there must have been a construction article.... Anyone know what mag and issue?
Robert
Attachments: |
Top |
Duane B
Post subject: Re: Roaring 20s Superhets Posted: Apr Thu 08, 2021 11:43 pm |
Member |
Top |
