Outlet strip with Edison fuse used as a dim bulb tester
Discussion of test equipment, tools, and related topics. Using, finding, fixing radio and television test equipment. Ads are not permitted.
Post Reply
wa2ise
Aug Mon 16, 2010 6:01 pm
Oradell, NJ
Contact:
Post by wa2ise »
Picked this up at a garage sale. An old Japanese outlet strip, 2 pin, using an old fashioned Edison base fuse (the kind you should not put a penny behind of). Remove the fuse, and replace it with a light bulb, and now you have a dim bulb tester to test a radio under repair. Use a bulb of wattage of twice the radio's power consumption rating, and if the bulb lights brightly, you have a problem like a short in the radio's power supply (shorted filter cap or such that could ruin a power transformer).
cwysong
Oct Sun 05, 2008 5:47 am
Bothell, WA
Re: Outlet strip with Edison fuse used as a dim bulb tester
Post by cwysong »
That's cool! Is there a make and model for it? I'd love to find one.
Chris
egg
Jan Tue 31, 2012 12:55 am
Bryansford Village. Ireland.
Post by egg »
Chris you've got mail.
wa2ise
Oradell, NJ
Contact:
Post by wa2ise »
cwysong wrote:That's cool! Is there a make and model for it?
It's a "Fedtro" model CON-6 Electric outlet control center. Made in Japan.
Flipperhome
Nov Sat 26, 2011 3:09 am
Spring Texas
Contact:
Post by Flipperhome »
Well, I'll be. In all the years I've had the thing I never opened the 'fuse box'. :lol:
FEDTRO CON-6.jpg (69.05 KiB) Viewed 4169 times
Thanks. That's a slam dunk no brainer.
johnS.
Apr Tue 25, 2006 4:51 am
Post by johnS. »
Watt a :idea: bright :idea: idea!
Sorry...just had to say it.
-John S.
RIP:Curt Reed, Alan Douglas, "oldradiospook", & "Bigbandsman"
Don Cavey
Jan Thu 01, 1970 12:00 am
Fernandina Beach, FL 32034
Post by Don Cavey »
Fedtro, I think that was a brand that we sold when I was in retail, working at E.J. Korvette, 1966-67. (Then the army got me...)
radiohenry
Jul Fri 10, 2009 9:13 pm
Weymouth, Ma 02189
Post by radiohenry »
I also have had one all these years and never opened the fuse cover. Who knew?
Henry
stevebyan
May Wed 18, 2011 1:40 am
Littleton, MA
Contact:
Post by stevebyan »
Don Cavey wrote:Fedtro, I think that was a brand that we sold when I was in retail, working at E.J. Korvette, 1966-67. (Then the army got me...)
I had one of those Fedtro's on my electronic workbench as a kid. We moved from Parkville to Towson in 1966 and I build my first workbench and installed one of those outlet strips. I probably bought it at Korvettes.
Don Cavey
Post by Don Cavey »
The Korvette on Perring Parkway in Parkville. We called that the "Towson" store. I worked on Baltimore National Pike and that was store 57 in Catonsville. I always had fun working there. Who knows, if you bought it at the Catonsville store, you may have bought it from me. I also worked in the Audio Department. Talk about died and went to heaven? A teenager, working with audio equipment... for a living! It was cool. I only wish I had taken pictures...
Adam Vaughn
Westford, MA
Contact:
Post by Adam Vaughn »
I did something similar several years back. While looking around in the garage, I found something which looked like a metal outlet plate, but in place of one of the outlets, it had a Edison socket with a metal cover over it, which I realized was meant for an old-style screw-in fuse. Eventually, I needed to build a dim-bulb tester to check out an old TV, and decided to put the fused outlet to work. Connected it to a line cord, mounted it in a junction box, and screwed a 100W bulb into the fuse socket. Sure enough, it worked like a charm. I still have it, though I generally use a current-metered variac for the purpose nowadays.
-Adam
Adam Vaughn
Visit my page at
Post Reply
