It is currently Oct Sat 16, 2021 4:47 am
 Post subject: Zenette model L
PostPosted: Sep Sun 19, 2021 1:49 am
Hello, I am working on a zenette model L from 1931? I have a question as to what the knob on the right is for? The left most knob currently is on/off volume, the middle is tuning. It loooks like some has been in the radio chassis before. The switch in question appears broken and looks like a on/off switch. No wires are currently connected. Was it originally the on/off? Was the left switch just volume and the left switch I have has been replaced with a on/off volume switch?
 Post subject: Re: Zenette model L
PostPosted: Sep Sun 19, 2021 2:17 am
A schematic would tell you.
A tone control is a possibility but no more than a guess.
Jim Mueller
PostPosted: Sep Sun 19, 2021 5:39 pm
I don't have a model L to check, but according to the service literature, it has separate part numbers for the on/off switch and the 10,000 ohm volume control.
So its gotta be a rotary on/off switch.
PostPosted: Sep Mon 20, 2021 5:50 am
Thank you for the replies. I came to the same conclusion. It appears the original switch died and the fix used was to replace the original volume pot with a pot with a power switch.
Post New Topic Post Reply  [ 4 posts ]  Moderator: sofaslug
Users browsing this forum: Majestic-12 [Bot] and 9 guests
