It is currently Nov Sat 27, 2021 10:22 am
Post New Topic Post Reply  [ 191 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: Wireless Specialty Triode Type B Amp Photos
PostPosted: Jul Mon 19, 2021 9:49 pm
I'm trying to restore a Wireless Specialty Triode Type B amp (early model, no jacks) and I'm looking for a wiring drawing or photos of the chassis and wiring. Any help would be greatly appreciated.
Dan
Museum Curator
 Post subject: Re: Wireless Specialty Triode Type B Amp Photos
PostPosted: Jul Tue 20, 2021 5:22 pm
I am guessing you have looked at the ones on RM? Post a couple of photos of yours.
Jeff
PostPosted: Jul Tue 20, 2021 5:33 pm
The one on RM with chassis photos is a later model with jacks. I'm looking for photos of the earlier model without jacks. I'll take some photos later.
Dan
Museum Curator
PostPosted: Jul Tue 20, 2021 6:39 pm
Have you tried looking in Worthpoint?. It's becoming a great source for reference information.
https://www.worthpoint.com/inventory/se ... +Specialty
Michael Feldt
www.indianaradios.com
PostPosted: Jul Wed 21, 2021 12:03 am
Here's what I'm starting with, I have two transformers to install. I'll make a sketch of where each of the eight transformer connections come from, then I need to figure out where they go to. Once I have that I can start replacing the existing mix of wiring with square wiring.
Dan
Museum Curator
PostPosted: Jul Wed 21, 2021 12:43 am
Zoom out so we can see the tube sockets. Need a photo of the front panel. Looks like a version with jacks, all missing.
Jeff
PostPosted: Jul Wed 21, 2021 12:58 am
Is the one shown in October 1919 "Radio News" (page 161) the correct one?
https://www.americanradiohistory.com/Ar ... 919-10.pdf
Bob
Everyone is ignorant...
only on different subjects.
PostPosted: Jul Wed 21, 2021 2:07 am
Yes, that's the one Bob. No jacks, no jack IDs in the faceplate. There are three plugged holes (not in the right position for factory). Someone added jacks and they were later removed? Unknown.
Dan
Museum Curator
PostPosted: Jul Wed 21, 2021 5:29 pm
OK, got it. I think this is a later version of this one on RM, https://www.radiomuseum.org/r/wirelesss ... e_t_2.html.
Your panel is marked for a C battery and 90 to 120 B volts, not 6 volts and 40 volts.
I added what I think are the connections to your photo. Some are marked with (?) because I can't see for sure where on the tube socket the wires go.
I am pretty sure that none of the buss wiring or that aluminum panel are original to the amp. I think the original transformers were mounted to the panel with 4 fasteners each.
Jeff
PostPosted: Jul Wed 21, 2021 5:56 pm
I agree, lots of filled holes in that panel.
Andrew
PostPosted: Jul Wed 21, 2021 8:21 pm
Looks like it was pieced together, radio museum has a different tube island
shows the guts of the amp.
Ebay has a FADA tube island which looks similar: https://www.ebay.com/itm/373647370718?h ... Swqy5g7KIg
Andrew
PostPosted: Jul Thu 22, 2021 12:01 am
A paper copy of the October 1919 "Radio News" might show more details of the back side of the amp (Fig. 2.) I looked though my magazines, but mine only go back to 1920.
Bob
PostPosted: Jul Thu 22, 2021 12:25 am
Just the three.
Dan
Museum Curator
PostPosted: Jul Thu 22, 2021 12:49 am
The only extra holes are the three large plugged holes. The different tube platform would make sense with the update for the C battery, maybe for 201 tubes instead of the earlier Morehead tubes.
Jeff
PostPosted: Jul Thu 22, 2021 12:51 am
Just the three.
Had to magnify the front, so I could see that they were actually screws :(
Andrew
PostPosted: Jul Thu 22, 2021 2:08 am
Removed the old wiring and positioned transformers. I'd like to see If I can do a better job of plugging the holes in the faceplate before I go any further. Best way to do it?
Dan
Museum Curator
PostPosted: Jul Thu 22, 2021 1:38 pm
Those transformers you got from me fit right in.
Andrew
PostPosted: Jul Thu 22, 2021 6:25 pm
Looks good. Did two of the transformer holes line up with the panel holes?
I modified a schematic from this page https://www.radiomuseum.org/tubes/tube_vt-class_ii.html.
I think it is right. EDIT: Maybe not. Alternate schematic suggested, below.
Jeff
PostPosted: Jul Thu 22, 2021 9:19 pm
Has the question about the jack (holes) been answered? Are they original holes, factory filled to be without jacks. Are the holes drilled later, i.e. not in good alignment, chipped out, elliptical, wrong size. If it is determined they are original then IMHO seek early jacks and restore with jacks. If they are user drilled then fill or used a machined plug to fill. Unless the intent to use the early AP tube(s) IMHO the bias setup via the rheostat's does not seem applicable to the 201... BTW the value of the existing rheostats will also determine if the amp can tolerate the 201a.
Dan I understand the need to operate but it may require a conversion to move it from 1920 to 1923-4...
Try mixing a measured portion of black dry colorant to a sample cure of J-B weld. If the color is good and it cures hard ++...Chas
PostPosted: Jul Thu 22, 2021 10:25 pm
This uses the VT tubes.
Andrew
Post New Topic Post Reply  [ 191 posts ]  Moderator: sofaslug Go to page 1, 2, 3, 4, 5 ... 10  Next
Users browsing this forum: No registered users and 29 guests
