Well progress is measured one connection at a time. I have the radio AM/FM/SW working. I replaced the output tube and recapped all paper and electrolytics.
My concern is the high voltage in the circuit. For some reason the prints indicate 225V at the EL84 pin 7.. I am getting $278.. I backtracked most of the resistors and readings from EZ80. My AC on the transformer is 280AC but pin 3EZ80 = 310V .. My 2 ecaps replace with 47UF 350 measure 85 UF in circuit. Should this be higher? Would low Uf cause this issue? Could it be the EZ80? *Note I am testing without the ancillary preamp EC83or phono plugged into the radio.
Am I chasing this in the wrong area. Any suggestion to help bring down that voltage to normal ?
